Hot Rods Traditional style 32-34 ford fiberglass cars - Any pic's?
Discussion in 'The Hokey Ass Message Board' started by Fordor Ron, Aug 20, 2015.
  1. hiboyroadsterboy
    hiboyroadsterboy
    from Mass
    This is what I started with. It was $200 and made in the 70's. 14680560_10154580850748088_610481083521431688_n.jpg
  2. tub1
    tub1
    from tasmania
    ive had 2 gl*** 32 and was proud of them even though I never finished them , that was what I could afford at the time but both builds were flathead /traditional style second one ended up chevy powered but traditional style 283 manual if it wasn't for repro fibre gl*** repro steel or a new type of composite body being built here in aus there wouldn't be half the nice cars on the road in hotrodding and hot rodding would of been the looser . so open your mind you guys please and I will try to open mine about those injected motors and overdrive trans . if ive upset some one I'm sorry we cant all have steel early cars there isn't enough of them and not every one can afford or repair a rusty one
    robracer1 and 26 T Ford RPU like this.
  3. DDDenny
    And...................
  4. CA. 280
    CA. 280
    Kind of surprised nobody's fooling with carbon fiber repro's even if it's just a Track-T.
    Lighter, stronger and maybe wouldn't require as much internal bracing??
  5. X38
    X38
  6. Atwater Mike
    Atwater Mike
    How many '32 'Vehicle I.D. Numbers' are there, (were there?) vs. the number of '32s (real and 'gl***) that are 'harboring' them?
    Both my former Gennie '32 frames are registered as '32 Fords, so one wonders...
    lucky ink and loudbang like this.
  7. chop job
    chop job
    from Wisconsin
    SORRY!
    pprather likes this.
  8. Kan Kustom
    Kan Kustom
    Carbon fiber is stupid expensive and you use epoxy resin which is also stupid expensive. I have it in my shop but I wouldn't waste the expense on my own car. I keep it around for when I get an itch to build an airplane.Its great stuff if you have deep pockets and weight and strength is more important than practicality . People think your getting rich off of them when building bodies with polyester resins and fibergl***. Ask me how I know. Most guys that build fibergl*** bodies and stick with it when they find out it is not the most profitable way to make a living keep going because of their p***ion to do it kinda like musicians and artists with monetary gain not being priority. People don't realize what a bargain they are getting when they get a gl*** body even though the purchase price is large to a guy buying one. Every piece is made by hand one at a time and each piece has to sit and cure in the molds overnight before being worked where on the other hand sheet metal parts are stamped every few seconds with countless parts being made every day. Have you ever seen the pictures of the stacks of quarter panels on a pallet ? Tack them together and done. Fibergl*** has to be sanded and gl***ed together. Again let sit over night before working again . Way more time and labor consuming than a steel body and yet sold for half or a third the cost of a quick built steel body. O.E.M. auto manufacturers do much of their short term high end research and development parts in fibergl*** but in production they stamp steel because its fast an less labor intesive. Think the price of a Corvette compared to stamped steel cars.
    loudbang and robracer1 like this.
  9. LM14
    LM14
    from Iowa
    New Age Motorsports 'gl*** body sitting on a Pete and Jakes Ch***is. Started tearing it back apart to get the bare metal in primer.
    SPark
  10. ramblin dan
    ramblin dan
    MO_JUNK, UNCLECHET, AHotRod and 2 others like this.
  11. CA. 280
    CA. 280
    You might want to look into these folks https://www.sollercomposites.com/ I pay around $18.50 for a yard of 50"
    3K carbon plain weave at 5.9 oz as opposed to $12.05 a yard for 50" plain weave, 4 oz fibergl*** cloth. 50" x 36"
    is a lot of carbon fiber. Your right about the epoxy though, 820 is $36.00 a pint with hardener and pumps. You can buy a gallon of 3M poly for that price. West System epoxy is somewhat cheaper.No comparison in strength though.
  12. Hey guys, as the OP of this thread let’s keep the gl*** car debate out of it.
    I started this thread saying I don’t care if you like gl*** cars or not. I just want to see what some creative folks have done with what they’ve had to work with.
    Feel free to talk about the car and what’s been done to it but let’s keep the opinions to ourselves.
    Less words more pics!
    slv63, ramblin dan, loudbang and 5 others like this.
  13. MO_JUNK, AHotRod, 31hotrodguy and 5 others like this.
  14. Dennis D
    Dennis D
    MO_JUNK, Tjompen, Murphy32 and 22 others like this.
  15. DDDenny
    509garyd and 26 T Ford RPU like this.
  16. Dennis D
    Dennis D
    Thank you. Still some detail work to do, but it's getting close. Just in time for winter......D
  17. pragmatist
    pragmatist
  18. Jeff Norwell
    Jeff Norwell
    MODERATOR
    34ford 001.JPG I had a 34 3W gl*** body ...original Henry Ch***is and grill,hood,etc,etc..... Best damn car I owned.
    Lives somewhere in Ohio ..... unchanged.
  19. hd1084
    hd1084
    thumbnail_IMG_0502.jpg My new ride. Traded my gl*** '33 for this one....
    Downs gl*** body on a Lobeck Ch***is powered by a Ford 347 Stroker.
  20. hd1084
    hd1084
  21. D.Conrad
    D.Conrad
    Built this in the mid 70s. Body made by John Brown in northern Ill. Body made before Wescott's 32 roadster. Then I built the black one in the early 90s, it is a Wescott. done right before MY OLD ROADSTER 002.JPG ROADSTER 2015 001.JPG Brookville came out with there metal body.
    MO_JUNK, Willy Lee, AHotRod and 2 others like this.
  22. DDDenny
    <<<<<<<<<<<<<Wescott
  23. roddin-shack
    roddin-shack
    Downs Body, Still retains Gel Coat finish, super staight body and fitment.
    A little different look with wheels.
    MO_JUNK, Willy Lee, AHotRod and 3 others like this.
  24. shortypu
    shortypu
    Rod Action body on Kiwi conection frame,Body had great fit and finish.I do wish it had outside hinges. 6 point rollbar in it because 383,super T10,3.73's I was worried it would crack and twist but with 3,200 miles on it so far no problems. IMG_0937.JPG IMG_0693.JPG
  25. Rramjet1
    Rramjet1
    Picked this up last year. Red Neck body. 400 sbc with Vortec heads. 700R4, 9” rear. AC, pwr windows, heated seat.
    MO_JUNK, AHotRod, Fordor Ron and 4 others like this.
  26. DDDenny
    We need more shots of this *****'n 3W.
  27. 26 T Ford RPU
    26 T Ford RPU
    x2 on that !! JW
  28. I like that Rramjet1. Is that full height top?
  29. lurker mick
    lurker mick
    Looks like the coupe that Tony Price built some time ago in Salt lake City.
    Mick
