Technical Rearend question
Discussion in 'Traditional Hot Rods' started by hotrod fozzie, Dec 1, 2018.
  1. hotrod fozzie
    hotrod fozzie
    I am starting my roadster pickup build ( starting with a t bucket project that was running and driving at one point). The question I have is it came with an 8” ford rearend in it , I would like to keep it if possible, I am curious if it will withstand a 300-400 hp small block Chevrolet with automatic transmission? I plan on building a nice driver out, which we all know my have a hard launch ( lead foot) from time to time but not planning a full race car. I am open to suggestions, I know a 9” is more bulletproof but would like to use what I have if it will hold up, even if I have to upgrade it a bit.
  2. F&J
    F&J
    Not likely to get enough tire bite in the lightweight rods we build here. Sure, you could break it with posi, slicks and the right rear setup.. but A/T and just stuffing it won't or shouldn't hurt it. One good thing is that there are lots of ratios you can get for $140 shipped on ebay...and it's lighter than a 9" so it helps a tiny bit on "unsprung weight" which helps the ride.
    hotrod fozzie, Andy, 47ragtop and 3 others like this.
  3. 1934coupe
    1934coupe
    Use it! It will be fine.
    Pat
    trollst likes this.
  4. gimpyshotrods
    gimpyshotrods
    Keep it. Run it.
    Unless you have a set up ch***is, on slicks, on a sticky track, and the axle is already beat-up, it will stand up just fine.
    Even then, it still will probably be fine.
    hotrod fozzie and Andy like this.
  5. BamaMav
    BamaMav
    from Berry, AL
    People discount the strength of the 8". It will hold a lot more than you will be throwing at it.
    hotrod fozzie likes this.
  6. gene-koning
    gene-koning
    It will hold up fine.
    You might just as well have the pleasure of pounding the **** out of it and breaking it before you pull it out and throw it away. Then you will know the limits of that particular rear axle ***embly, but the next one might be different. At least that is my perspective. Gene
  7. X-cpe
    X-cpe
    Mine is out of an early fairlane. It has the skinniest axles I have ever seen. I was running 235/75s at 19 PSI on my A with a 327/PG and a 3.55 gear when I was driving it. All it ever did was spin the tires if I hit it hard. Never hurt the axles. The gears came out of a Pinto/Bobcat 6 cyl. MT wagon. All strengthening a component does is move the weak spot.
  8. As long as you're traction-limited, it'll hold up. And it's not HP that kills them, it's torque. Ford limited these to use behind 302s and smaller motors, once they hit 351" the 9" was used.
  9. BamaMav
    BamaMav
    from Berry, AL
    I'll agree with that most of the time, but Ford is known for some goofy things. I've seen 8" rears in Granada's with 351W's from the factory, as well as Granada's with 9" rears and a 250 I6. The 8" in my car came out from under a 66 Fairlane that was a factory 390 automatic car. These might have been Friday or Monday cars, there might have been a mixup, or it could just simply be they used what was in the parts bin that day.
  10. deathrowdave
    deathrowdave
    from NKy
    Use it enjoy it and never look back , lots of facts are from benchracers ! It will be fine , I have beat an 8 in for years no issues , sold to a buddy still bangin on it today no issues
  11. Yeah, Ford got sloppy in the late '70s and used the 8" behind some 351Ws. But at this point, they were smogged so badly that power was less than what the earlier 289/302s could put out, so they would live behind them.
    If four wheel discs were ordered on the Grenada/Monarch, you got the 9", regardless of engine. And I strongly suspect that the '66 Fairlane had a rear axle replacement before you got to it.
    Too much torque in the 'average' car would kill the 8" pinion bearings if you didn't break it....
    I'd go with a 8.8 these days; if they're good enough for full-size trucks, they'll hold up in a car.
  12. sdluck
    sdluck
    I don't know if you have pick and pull in your area,we bought a 8.8 with posi and choice of drum or disc brakes for less than 150 complete on there deal on 3 day weekends
  13. junkman8888
    junkman8888
    Friend of mine replaced the clutch on a customer car. When he took it out on the main drag for "testing" the enormous torque of a stock 302/manual three speed ripped the 8" pumpkin clean out of the housing. You've already admitted you're going to thrash on the car, do you really want to spend time cleaning 90 weight gear oil off of a public street?
  14. gimpyshotrods
    gimpyshotrods
    Pics, or it didn't happen.
  15. gimpyshotrods
    gimpyshotrods
    Which reminds me, I need to get another one.
  16. gene-koning
    gene-koning
    I think I've broken at least one of just about every rear axle a car company has installed in a car or light truck. My motto used to be "If you haven't broken it yet, your not trying hard enough."
    The odds are the 8" will be fine, and its already in the car. If it isn't, after he brakes it, he can choose something tougher that will move the weak point to somewhere else.
    Oh, and for the record, I never had to clean up a public street after something broke. Gene
  17. whtbaron
    whtbaron
    from manitoba
    Broke two 8.8's, a 9", an 8.25 , a 7.5 and whatever that POS was in my 62 Comet with the 170 6cyl. Oddly enough, I haven't broke any since I p***ed my 40th birthday about 20 yrs ago. I guess they're building them better now...
  18. You're traveling through another dimension, a dimension not only of sight and sound but of mind. A journey into a wondrous land whose boundaries are that of imagination. That's the signpost up ahead—your next stop, the Twilight Zone!
  19. gimpyshotrods
    gimpyshotrods
    Exactly.
  20. Rocky
    Rocky
    Classified Editor
    I used a maverick 8" [3:00-1 open differential] in my 49 ford coupe with a 300 HP 355/350 turbo with a shift improver kit. Car was about 3100 LBS and had fairly skinny tires. Never had a problem. Rockybox.jpg
    figure8 likes this.
  21. Lionheart
    Lionheart
    My '65 Mustang had a 289 4 speed, and 8" rear end.
    When the car was about a year old, I was giving a couple friends a ride. One was in the front and the
    other guy in the back seat. Wound it up in 1st, speed shifted into 2nd gear, and all hell broke loose.
    We coasted to a stop, walked back down the road, and there, close to the ditch, laid my twisted up drive
    shaft, pinion gear, all still attached to the pinion housing that had busted out of the 3rd member housing.
    It happened to me, so I Know it can happen. Maybe that is what happened to junkman8888's friend.
  22. okiedokie
    okiedokie
    from Ok
    8" in my 40 behind 330HP and after 30,000 miles of fun driving, no problems whatsoever.
  23. sloppy jalopies
    sloppy jalopies
    ran a few but with basically stock 302's, no problems... the mavericks were about 49.5" between backing plates... good fit in a model A...
  24. Now this is possible . I've seen plenty of 9" pinion flanges break. I'm sure you could break an 8 " with a stick shift car.. I know I could.
    Lots of folks on these forums don't quite understand what breaks rears, driveshafts , transmissions, and what doesn't.
  25. lumpy 63
    lumpy 63
    Run it, unless you got slicks and a 4spd it will work just fine.
    hotrod fozzie and Mark Yac like this.
  26. LUTHER99
    LUTHER99
    plenty strong , use it , break it , then go to a 9 inch !!
  27. init1
    init1
    The 8" will be more than enough.
    9" Fords are huge and will look too big.
    Something to think about.
    Sent from my SM-J727V using The H.A.M.B. mobile app
  28. deathrowdave
    deathrowdave
    from NKy
    He’ll be a man step up to a Rockwell , I have broken them . Maybe you can break on in a Rod
  29. 97
    97
    Some people have no mechanical sense!
    8" is plenty strong enough for a hot rod with a mild 400hp motor and
    the type of tires we use on real hot rods. AND it will have less parasitic drag/friction than a 9".
    A drag car /slicks etc or something with stupid looking 20inch wide tires, that is another story.
  30. Bandit Billy
    Bandit Billy
    I just had built a nice little 9" posi 3:70 gear . 31 spline. Centered pinion, out of a Maverick. 57" mounting surface to mounting surface. Hemi coming aboard. Salute!
