Hot Rods Cadillac Engines, post a pic of your 331,365, 390.
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Nov 26, 2018.
Tags:
  1. seabeecmc
    seabeecmc
    Really dislike Bendsten's starter, it just doesn't flow with vintage parts. Checked out your cat at Ty-Rods. You nailed it, Ron pcv6.jpg pcv7.jpg
    Deuces and loudbang like this.
  2. warbird1
    warbird1
    The '55 331 in my roadster a few years ago... also have a 390 on the stand.
  3. Roothawg
    Roothawg
    Looks like they have discontinued that bellhousing........everything else I can get.
  4. HOLLYWOOD41
    HOLLYWOOD41
    Found mine on Ebay. Ariel Group International, LLC $35.00, arielperformance
  5. CheatersPete
    CheatersPete
    my 1956 365...
  6. fiftyv8
    fiftyv8
    from CO & WA
    Anybody out there happen to have a copy or a link to a source of bolt torque settings for my 1956 Cadillac 365 engine, please?
  7. RED-EYE-KUSTOMS
    RED-EYE-KUSTOMS
    from CA
    Just a quick ? Regarding these power plants. I have a 390 and was curious as to what radiators you guys are using to keep them cool?
  8. Roothawg
    Roothawg
    I haven’t made it that far yet, but I will bump the thread for ya!
  9. Great thread!
    Here are a couple of Caddys in cars I've built. The first is a 390 with and Edmund's intake and WCFB carbs. It's in the #ElDorodder 32 Tudor.
    More pics are available on Instagram @grays_garage
  10. Roothawg
    Roothawg
    How did those headers fit with the stock steering box?
  11. seabeecmc
    seabeecmc
    hb1.jpg This one in the #Caddyhauler truck. It is a 331. View attachment 4122390
    More pics are available on Instagram @grays_garage[/QUOTE]
    That's the only other Weiand Cadillac 3 carb intake I've seen. I put mine on the Bridgeport to get the carburetor mounting flanges more in line with crankshaft centerline. Carburetors had a drastic forward tilt. I always thought it was a marine application. So now I'm confused. Ron
  12. The truck had custom headers and a vega box. The sedan had Sanderson headers and an f1 box.
    Roothawg and loudbang like this.
  13. Dimadee
    Dimadee
    Cool thread.
    My 390 in a '59 Flat Top Sedan de Ville. Haven't driven it as much as I would like lately :-(
    Isky 262 camshaft, lightly m***aged heads, Triple 2G Rochesters (built by **** York), Pertronix Ignition, hand built 2 1/4" mandrel exhaust.
  14. sigfurniture
    sigfurniture
    hi ..its been a while but for all the cool info i always come back to the hamb..the pix on this thread have been sent to my client who wants to put his 50 caddy engine in the 1928 model a that we have here (in spain..ie..we run with what is available..which is not much)..the mechanix has asked if i can find out any info about the gearboxes..I´m guessing manual boxe are as rare as hens teeth even over there in the states..is there feasible manual box that people use for these engines or does everyone keep the auto?..thanks in advance jonathan
    31hotrodguy and loudbang like this.
  15. Roothawg
    Roothawg
    Only the really early stuff had the sticks behind them. I would think it would be easier to adapt a late model ****** to that bell housing, rather than the later.
    Wilcap makes a nice piece.
    http://www.wilcap.com/cad.html
  16. Roothawg
    Roothawg
  17. TheSteamDoc
    TheSteamDoc
    What y'all using for a charging system and with what brackets? I plan on using Sanderson block huggers.
  18. Roothawg
    Roothawg
    I am planning on fabbing my own generator brackets. I like the idea of chroming the generator housing and voltage regulator.
  19. Automotive Stud
    Automotive Stud
    Here is the '55 331 I put in my '40 earlier this year. I made my own generator bracket and used a '57 Ford generator and voltage regulator. I used two driver's side exhaust manifolds, and I needed two adapter plates to go to the Ford transmission since the '55 does not have the extended bell like the earlier motors. 20200803_213409.jpg
    Deuces, dana barlow, 40FORDPU and 6 others like this.
  20. sigfurniture
    sigfurniture
    excellent tip off mate, thanks..we´ll look for newer ******s whilst we´re at it..it seems obvious that its a "done thing"..changing the gear box
  21. Hank37
    Hank37
    Through it away and made my own oil filler tube , I run an electric fuel pump .
    loudbang, Roothawg and 31hotrodguy like this.
  22. 31hotrodguy
    31hotrodguy
    I got my adapter and flywheel for the 57 engine from wilcap. It wasn’t cheap but I’m happy with the purchase. Good people to deal with.
    sigfurniture and loudbang like this.
  23. 61cad
    61cad
    Great Thread !
    Anyone running a Blown Caddy Engine?
    loudbang and warbird1 like this.
  24. CheatersPete
    CheatersPete
    I do, 365 with 4/71
    loudbang and 61cad like this.
  25. 61cad
    61cad
    Would you post pictures of the drive setup?
    I have a complete 4-71 setup for a SBC.. Considering a different engine.
  26. CheatersPete
    CheatersPete
  27. CheatersPete
    CheatersPete
    here is the setup, I can't find my other pictures...
    61cad likes this.
  28. loudbang
    Deuces, kadillackid and 61cad like this.
  29. One step closer, running the plug leads done. 455901AC-7634-4A89-AC13-DE93BB61C546.jpeg 3BECE213-BEB6-4D96-990E-1BEFAFAEA0D5.jpeg
    Jet96, Deuces, Shadow Creek and 4 others like this.
  30. ss34coupe
    ss34coupe
    Here is the 53 Cadillac motor in my 33 coupe - basically a stock rebuild. Have a 3-2 setup ready to install later on. IMG_3018.jpg IMG_2967.jpg
