TH350 to TH400
Discussion in 'The Hokey Ass Message Board' started by FireBurb, Dec 4, 2018.
  1. FireBurb
    FireBurb
    Alright so my 350 went bad so i thought instead of fixing the 350 i’d just get a th400. when i got it i didn’t notice that it has a tail housing for the trans brake thing. so now i am completely confused as to what yoke to get or if it’ll even work. if you need pics just lmk. the th350 has the short tail shaft. i think i’m good as to figuring out the how much driveshaft to cut.
  2. Mr48chev
    That's a trans out of motorhome or something like a 1-1/2 or 2 ton truck.
    I'm not sure that you can remove them without changing the tail shaft housing and tail shaft.
    Hnstray likes this.
  3. gimpyshotrods
    gimpyshotrods
    That is not a TH400. It is a TH475.
    You need a 2wd TH400 tail housing, and yoke that goes with it. It is a bolt-on, fixed yoke.
    You will need a slip-spline drive shaft. Your existing shaft will not work.
    Also, unlike the helical gears in a TH400, a TH475 has straight cut gears. Strong, but noisy.
    What might be the deal killer: a TH475 does not have a parking pawl. You park it in neutral, and use the ring and pinion multiplied parking brake, on the tail housing.
    Jalopy Joker, XXL__, Hnstray and 2 others like this.
  4. 1934coupe
    1934coupe
    I didn't know that Gimpy, good info there. Thanks.
    Pat
  5. Hnstray
    Hnstray
    from Quincy, IL
    You didn’t mention the vehicle type or hp you are dealing with. One thing to consider is that a TH350 uses less hp to operate than does a TH400.....I have seen the number 16% more required for a TH400. That is not a criticism of the 400, only pointing out that in lighter to medium duty applications, a 350 may be a wiser choice for that alone plus it weighs less.
    On the other hand, if your application is high hp and/or a heavy weight vehicle, or often used for towing, etc., the 400 is great.
  6. FireBurb
    FireBurb
    [​IMG] would i be able to use a normal short tail housing and then this yoke? i found it in another thread and they said that should solve the problem
  7. Jmountainjr
    Jmountainjr
    Solves the driveshaft issue. You still won't have a park feature in the transmission.
    gimpyshotrods likes this.
  8. Hnstray
    Hnstray
    from Quincy, IL
    The bolt on output yoke is common on GM lighter duty trucks that do not have the external parking brake ***embly you have. I suspect that is far more common than the RV/medium duty truck TH400 etc. that you have. That alone would justify the modified yoke design Neapco offers.
    “Park” position aside for the moment, I suggest you research this further to find out if the output shaft of the transmission you have, with the output mounted parking brake, is the same as the standard TH400 truck shaft that uses a bolt on yoke, but without the external brake.
    It may be as simple as changing the tail housing...or it may not. The time to determine all that is before you buy any parts.
    FireBurb likes this.
  9. Last one I had, ( 1988 P-30 , 454) had a park in it. The P-30 was the "bread truck " ch***is used for Cl*** A RV 's.
    ( discs all around, 19.5 rubber)
  10. FireBurb
    FireBurb
    okay thanks. so i just need to find out if the output shafts are the same and if so that would mean i can use that yoke and then what’s the issue with just swapping the tail housing? what are some things i would have to look out for regarding the tail housing?
  11. oldsman41
    oldsman41
    Rebuild the 350 you will come out ahead.
  12. 56sedandelivery
    56sedandelivery
    I "think" you'll be alright using a "regular" short extension housing, and the counter-bored slip yoke. I have never heard of this transmission not having a "Park"; in fact, this is the first time I've heard this, but I don't know everything. I did have an old Dual Range, cast iron, 4 speed Hydramatic once, that had an extension housing mounted, drum style, parking brake. It had a "Park", and used a bolt on "trunnion"; came out of a dump truck. You will have to shorten your drive shaft, unless your TH350 had the 9 inch long extension housing. When I got tired of the TH350's my DD truck had going out, I swapped in a TH400 from a p***enger car, used a longer slip yoke, and kept the stock 2 piece drive shaft. You might call up a transmission shop or two, and ask them what you'll need to do in order to use your TH400/475 transmission. What's the trans going into? If needed, do you have the available resources to have a drive shaft made up with the "slip" made into the shaft, if an extension housing/special slip yoke won't work? I am Butch/56sedandelivery.
    I just did some checking on a few other sites, and there was only one mention that "SOME" TH475's did not have a "Park" position, and some did, so you'll just have to run it through it's detents, and see if yours has a "park" or does't. Learned something new today! There's another thread here, TH400 to TH475, that's been resurected, that may answer some of your questions also.
    Elcohaulic and Truckdoctor Andy like this.
  13. swade41
    swade41
    from Buffalo,NY
    I've never heard of one not having park either, I was surprised to read that and thought I read something new. I have a trans out of a cube van that has the bolt on yoke, no parking brake garbage and I also have one of those slip yoke conversion yokes.
  14. 4tford
    4tford
    I have the turbo 400 with the bolt on yoke and you need the slip yoke machined to allow the slip yoke to slide in all the way. I had Denny's driveshafts do my driveshaft it fit good they knew the slip yoke I needed.. A portion of the spline must be removed to allow it to engage properly on the yoke style tailshaft that's what is shown above in " neapco" yoke in post #6
  15. Jalopy Joker
    Jalopy Joker
    - or find a replacement or get a upgraded 200R4
    gimpyshotrods and Hnstray like this.
  16. oldsman41
    oldsman41
    Jalopy yeah but he has to watch his ratio in the rear end. That od ****** wont like a 3;08 or higher. It could live with a 3:54 or 3:70
    Atwater Mike likes this.
  17. saltflats
    saltflats
    from Missouri
    There are two short tail housings, the difference is in the yoke bore hole, some use the 350th size.
    Hnstray likes this.
  18. Hnstray
    Hnstray
    from Quincy, IL
    ^^^^^^^yep, stumbled into that issue a couple years ago. Easy to fix once you know....and find the correct tailhousing...;)
    saltflats likes this.
  19. Crosley
    Crosley
    from Aridzona
    Easy enough to check for the function of parking pawl parts with a pair of slip jaw pliers. Place unit in park.. check for rotation of the output shaft.. Some added info; Military equipment with a 4L80E in them like a HumVee do not have parking parts in them either. With the age of the T-400 , it may have been swapped out decades ago for a unit with parking bits & pieces inside
  20. ClOckwOrk444
    ClOckwOrk444
    We used a TH400 from a 2wd fullsize van and it had normal park, short tailshaft, and slip yoke. Broke the bellhousing off with transbrake, Upgraded to reid case now. Good luck
  21. 56sedandelivery
    56sedandelivery
    That's the "TH375"; a TH400 with a TH350 output. There's one of those currently for sale in the Seattle area Craig's List. Why GM did that, who knows? There is also a "regular" TH400 that does take a different bushing, and therefore a different slip yoke; thankfully, they're not real common. But, if you do get one, and don't know about that oddity, it will drive you nuts trying to figure it out. I am Butch/56sedandelivery.
  22. Probably an o/t car. That's okay ..A quick learner ;-)
    I'd say fix the T350 unless we hear more detail.
  23. elba
    elba
    The 350 is a great street rod ****** . I would keep it .
  24. FireBurb
    FireBurb
    was gonna drop all of this in my 71 monte carlo now im not sure if i wanna go through the h***le of getting the yoke and tail housing and driveshaft cut for a “maybe it’ll fit”. i found another 400 hopefully this one has the short tail i need and slip yoke that would be perfect. if not then guess i’m stuck with this thing. welp thanks everyone for the help. learned a lot lol idk just got overwhelmed i rather just sell this and get something a little more compatible
    Elcohaulic likes this.
  25. Good luck, and read the rules for this site , before you post again;)
  26. Atwater Mike
    Atwater Mike
    TH 350 is a repairable automatic transmission. A strange 400 is a **** shoot.
  27. FireBurb
    FireBurb
    where can i find them?
  28. I don't know . I know I've read them. I can see how you might have missed them.
  29. FireBurb
    FireBurb
    oh the cutoff year thing?? sorry i had no idea. they should make a rules section or something i just kept seeing people asking things for newer stuff and people telling them the cutoff year is 60 something and i figured that’s what the problem was. sorry bout that
  30. I'm with jalopy Joker on this thing. I've had pretty much every GM ****** that they make. If you going through all that work to swap out a different transmission, why not bump it up a notch? Go with a 200 or 700. You'll be worlds ahead at the end of the day
