Technical Oh crap, now what ?
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Dec 5, 2018.
    GM 10 bolt
    Nothing is ever easy!
    Simple axle seal phone call shows up with an axle that fits in the bearing much like a hotdog fits in a hallway and then this lock bolt leaves 3/4 of itself in the hole thru the crosspin
  2. AngleDrive
    AngleDrive
    from Florida
    Been there, done that
  3. mad mikey
    mad mikey
    I have been on the **** end of that before. That ****s. No wonder I drink.:rolleyes:
  4. razoo lew
    razoo lew
    from Calgary
    hey, but at least you have a lot more room to reflect on your cir***stances now.
  5. saltflats
    saltflats
    from Missouri
    If it was easy, everyone would be doing it.
    I have had some luck with a small pick working it back out.
    trollst, squirrel and mad mikey like this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, I gotten those out with a sharp pick also, just turn it out....
    big duece likes this.
  7. It’s been a long time since I had a gm diff apart but this is that stupid long pin bolt deal that ALWAYS breaks.... corrrect?o_O
    Had luck in the past sometimes blowing air through an air gun with a rubber tip so you get a good seal on the hole, the air works itself around the remainder of the pin and pushes out towards you a bit, then you can wedge it out with two small screw drivers on either side or grab it with a pair of small needle nose and wiggle it out.this works only if it breaks off all the threads and all that is left is the pin part.
    Or get an aviation grade 12” drill bit in the size required ( brafssco sells them about 12 bucks each)
    You need a long flexible drill bit so you can drill out the Center of the pin in the middle , but the drill bit has to “bend” around the housing( if you understand what I’m getting at) then drill and tap in a small extractor and out it comes.
    Usually they break off at the threads and all your left with is the pin part.
    Might get lucky with a Dremel tool and a small burring tool, cut a groove and use a screwdriver.
    Either way it’s a big pain in your left ball easy or not it ****s, as Bluto said in animal house “ now is when you start drinking heavily”
    Good luck.
    lothiandon1940 likes this.
  8. tb33anda3rd
    tb33anda3rd
    loudbang and lothiandon1940 like this.
  9. NWRustyJunk
    NWRustyJunk
    Had that happen in a stock car many years ago. If I recall, we very carefully tacked a piece of welding rod to it and pulled it out.
    DJCruiser likes this.
  10. choptop40
    choptop40
    Worked one out with a sharp pick..whew ...surprised it came out easy..
  11. 57 Fargo
    57 Fargo
    I’ve stuck a welding rod to the end to get them out....I’ve also had to torch the pinion pin out to get them apart. Good luck, I’m sure you will have no trouble.
  12. pete2c
    pete2c
    Welded a nut and came out
  13. 9863B4D6-829B-4E4D-9946-B7060FEE4B4F.jpeg + AFD7AD41-6A0F-4D0E-8520-31917E8AB9CE.jpeg
    = removed cross pin
    warhorseracing likes this.
  14. saltflats
    saltflats
    from Missouri
    mad mikey likes this.
  15. big duece
    big duece
    from kansas
    Yup, that ****s. Ford 8.8 is the same way, broke them on my work van replacing axle bearings. You might try to find a metal comp*** or divider and use it like a spanner wrench. You can walk them out, if patient. HTB1CD0RNXXXXXX8XFXXq6xXFXXXU.jpg
    VANDENPLAS, loudbang and saltflats like this.
  16. Place punch on crosspin
    Strike punch with hammer
    Crosspin can now fall out
    Removing renaming bits of crosspin bolt
    blowby likes this.
  17. saltflats
    saltflats
    from Missouri
    I don't think there is a place for the end of the bolt to go.
  18. The first one I broke I was going crazy. (In my mid 20s).
    My uncle, a much more experienced and patient person, used a punch and 1 hammer blow. The pin was able to fall out. The hit sheared the other side of the retaining bolt.
    The remnants of the bolt fell out
    He fixed in less than a miniute what I spent hours on.
    samurai mike likes this.
  19. I pushed it out because I had bigger fish to fry.
    You're saying striking the crosspin will shear the remnant of the lock bolt?
  20. Roothawg
    Roothawg
    Kan Kustom likes this.
  21. Well
    it worked in a pinch
    Now that was also before I knew there were tools for this
    Didn’t know it this was a last resort situation for you
  22. randydupree
    randydupree
    from archer fl
    drill a small hole in the carrier at the blind end of the broken bolt and use your air gun to blow it out,by blowing in the small hole you drilled.
    belair likes this.
  23. saltflats
    saltflats
    from Missouri
    I always found one thread on the end of the retrieved piece.
  24. Ok, It's out
    I talked to my buddy Terry at Henderson driveline in Westlake, Ohio.
    He said they always break with 1 thread left on it and that 1 thread needs to fight its way back out.
    He hooked me up with 3 little tools and a new bolt. 1st is a Allen drive cap screw with a center hole drilled thru it. 2nd was a 12" long flexible drill bit, and third was an easy out.
    The cap screw pinches the broken part and centers the drill bit. The flexible bit lets the whole thing work. Then it's up to the operator to not break the easy out.
    Took about 10 mins to do and that ***** fought hard coming out.
    My phone went dead at that pic, more pics tomorrow if y'all want them. ??
    Chucky, mad mikey, saltflats and 2 others like this.
  25. loudbang
  26. Mr48chev
    Cool that you got it out without a monster fight. The last one that I worked that had a broken pin the spider pin had wallowed out the hole in the carrier to the point it wasn't usable any more. It could have been that the pin broke first though.
  27. Kan Kustom
    Kan Kustom
  28. Rickybop
    Rickybop
  29. samurai mike
    samurai mike
    did the factory put lock***e on those? if so heat it up with a torch before taking the bolt out.
  30. big duece
    big duece
    from kansas
    31Vicky with a hemi and loudbang like this.
