Chevy 3spd. manual trans info.
Discussion in 'The Hokey Ass Message Board' started by 54cruzer, Dec 31, 2011.
  1. 54cruzer
    54cruzer
    from florida
    Does anyone know the lengths of 55-64 chevy (car)3spd manual transmissions(open drive,with or without car bellhousing)??
    I did find out that a 55-57 3 spd and 3 spd O/D are the same lengths(whatever that measurement is)?
    Is a 58-64 3spd the same length as 55-57? O/D and reg the same?
    How about later 3 speeds> 65 and up?
    I think I am talking all saginaws?
    Yes I did try a search and a google search 100's of pages, lots of good charts on automatic dimensions, but little to none on 3 spds.
    thanks
  2. squirrel
    The Muncie non-synchro low 3 speed was used till the mid 60s on most Chevys, then they went to the Saginaw. Muncie has 4 bold side cover, Saginaw is 7 iirc.
    Some Muncies used in the 58-64 time was shorter than the earlier ones, but I'm not sure what year they changed.
    THe long Muncie 3 speed, the overdrive, and the Saginaw 3 and 4 speeds (as well as the later Muncie 4 speeds) are all the same length, mostly.
    Cosmo49 likes this.
  3. cavman
    cavman
    5-6-7s all had long trans, the shorter ones came out in 58. Early chevelles also had longer versions but with a provision for a rear mount.
    Hnstray likes this.
  4. 54cruzer
    54cruzer
    from florida
    Here's SOME info I found:(still no measurements except one -24.625)
    The 32 spline output Muncie is 3/4 inch longer than a standard muncie:thumbsup:
    Wally is 100% on the money.
    And, to further expand on this, here is more.
    The following CHEV MANUAL ******s are the same length:
    55-57 Saginaw 3sp (p*** car)
    55-62 Saginaw Vette 3sp
    55-later 1/2ton pickup 3sp (non and fully syncro)
    55-65 Saginaw 3spOD
    66-later fully syncro 3spds (Saginaw)
    REGULAR B-W T-10s (57-63)
    63-70 Muncies
    Saginaw 4spds
    Also, the PG and Turbo 350s are the same length as the above manual ******s (plus bell housing). For example, a 63-70 Muncie + bell housing will replace a Turbo 350 ****** and use exactly the same yoke/driveshaft. A 71-74 Muncie (or Super T-10) + bell housing will replace a Turbo 400 and use the same yoke/driveshaft.
    The 58-64 Saginaw 3spds were essentially the same ****** as the 55-57 3spds, EXCEPT, THEY HAD A SHORTER TAIL HOUSING!!!
    Also, the 58-64 short 3spds as well as the 58-64 3spOD had a ****** mount on the tail housing. The 55-62 Vette 3spds also had a ****** mount on the tail housing, but it was different from the p*** car ****** mount.
    The 71-74 Muncie (and 70 M-22) and B-W Super T-10 are 3/4in longer than the old 3spds, T-10s, Saginaws and 63-70 Muncies. 66-85's
    Sooooooooooooooo, for all practical purposes, the early T-10, Saginaw 4spds and early (63-70) Muncies are the same length. The 71-74 Muncies and Super T-10s are the same length (3/4in longer).
    71-74 Muncies/Super T-10s use the "Turbo 400" type yoke
    ALL 63-later ******s (manual & auto) except turbo 400 types use the "Turbo 350" type yoke.
    The 62-earlier ******s (ALL) have the SAME SIZE yoke as a Turbo 350, EXCEPT they have the co**** splines (16splines).
    pecker head likes this.
  5. squirrel
    Nice write up, but I think it's mistaken about the truck Muncie 3 speeds from the early-mid 60s, they used short ones in some of them.
    Rian likes this.
  6. troylee
    troylee
    The 3 speed munci was it a 351 , You are lookin for info on ?
  7. JohnEvans
    JohnEvans
    from Phoenix AZ
    The 55-64 3 speeds are MUNCIE's not SAGANAW's Saganaw's are the full syncro 3 speeds that came out in 65 ,7 bolt side cover. Muncies are rather frail tore up lots of them back in the 60's
  8. 54cruzer
    54cruzer
    from florida
    I am getting a 235 6 cylinder and 3spd trans out of a 55 chevy or a 61 impala (with O/D)
    I cannot get my hands on them at the moment, and need to know the overall length including bellhousing to tailshaft output.
  9. squirrel
    about 27", same as a normal short tail TH350
  10. 54cruzer
    54cruzer
    from florida
    I cannot find a comprehensive chart listing listing exact MANUAL transmission dimensions, something like that would be useful. (I have found only a chart on ford toploaders)
    I was mainly looking for dimensions of 55 and up 3pds (GM 3 speed w O/D too) Are all of them 27 9/16"(like a short th350)?
    Tons of data on automatics.
  11. joeybsyc
    joeybsyc
    from PA
    So if you had a "short" tailshaft 3 speed Muncie in a '63 Bel Air, what would be needed to swap in a later Saginaw fully synchronized one and still maintain the column shift? Shorter driveshaft? Different shift linkage? I have a stock 63 Chevy 6 cylinder 3 on the tree and wanna get a sychronized 1st gear and maintain the column shift if it's an easy swap.
  12. Kerrynzl
    Kerrynzl
    Bump please.
    I know the shifter arms need altering. But can somebody enlighten us on drive shaft length.
  13. 56sedandelivery
    56sedandelivery
    IF you have a Muncie 318 3 speed, or the Muncie 319 3 speed with overdrive, those transmissions are the same length. Like squirrel said, roughly 27 inches including the bellhousing (same as a short shaft TH350). The 58-64 X-frame cars used a shorter version Muncie 318, 25 inches including the bellhousing. If those cars came with an overdrive Muncie 319, then we're back to roughly 27 inches, including the bellhousing; the front driveshaft was shorter/longer depending on the transmission. Generally speaking, ALL the GM/Chevrolet manual transmissions, all the transmissions were 27 inches including the bellhousing; that includes Muncie 3-speeds (early and late), Borg Warner 4 speeds (early and late), Borg Warner 3 speeds, Saginaw 3 and 4 speed transmissions including the Saginaw 3 speed with overdrive, and Muncie 4 speeds; 5 and 6 speeds are too new for my own personal concerns, and I have no real idea on them, but I doubt they're really any different as far a lengths go.. Some Pontiac's used l-o-n-g-e-r tailshaft transmissions; and even some Ford manufactured Dearborn transmissions were used in the mid 60's in Pontiacs. 10 spline inputs were used on the earlier transmissions (pre 65), and changed to 17 spines in the later 70's; same with the output shafts; 17 spline output till the mid 60s, then changed to 27 splines. The higher performance transmissions, Borg Warner 4 speed and thge M-22 Muncie 4 speed used the larger, finer spline inputs, and larger, finer spline outputs. Basically, 27 inches including the bellhousing for all Chevrolet cars/trucks, with the exception being the 58-64 X-frame cars at 25 inches including the bellhousing. There were "some" trucks that used the shorter version Muncie 318. And, some differences involving Buicks, Pontiacs, Oldmobiles. I'm sure there are some very minor differences in lengths, over the years and models, but 25 and 27 inches are the norm, including the bellhousing.
    I am Butch/56sedandelivery.
    1Nimrod likes this.
  14. Rickey Van Dyke
    Rickey Van Dyke
    Great topic.
    My Dad and I are pulling out a 3 speed in a ‘58 Chevrolet Delray and putting in a 4 speed Saginaw. The Saginaw is exactly 4 inches longer than the 3 speed coming out. Does that sound like the 3 speed is either a Muncie or Borg Warner?
    Case number on the 3 speed is 3830210
  15. 56sedandelivery
    56sedandelivery
    It's a "short" version of the Muncie 318 transmission. You'll need to shorten your front half of the drive-shaft to use the Saginaw. You'll also need a fine spline, 27 spine count, slip yoke to do the conversion.
    1Nimrod likes this.
  16. Rickey Van Dyke
    Rickey Van Dyke
    Thanks. Yep, drive shaft is going to a shop and I have already bought the yoke needed.
    1Nimrod likes this.
  17. The 55 thru 57 and every one of the 4 bolt side cover transmissions where Muncie 318,s No Saginaw trans where made until the mid 60,s. I repete the stock three transmissions that came in tri five chevys and most every chevy car or truck up until 1964 where not Saginaw transmissions. They where Muncie 318 & with overdrive its a 319. And some chevy trucks used a short tail version. Ive had several 64 & 66 trucks that used the short shaft trans.
    1Nimrod likes this.
  18. Rian
    Rian
  19. Rian
    Rian
    Yes I have a 1966 Chevy C10 3 speed Over all length is 16 and 1/2 inches from mounting surface to and of tail shaft
  20. Your quite wrong no tri five or any chevy had a Saginaw trans before the mid 60,s The original 1950's and early 60's non syncro first & reverse transmissions with the 4 bolt side cover where Muncie's .Muncie 318's and with overdrive Muncie 319's. They where not Saginaws. The Saginaw trans is full syncro and has 7 bolts on the side cover.
    1Nimrod likes this.
  21. Rian
    Rian
    I have to transmissions both Muncie 318 I want to take the short tail shaft off of one of them and put a long tail shaft on the other need to know what is involved thank you
