Projects 1940 Desoto coupe project
Discussion in 'Traditional Hot Rods' started by txturbo, Nov 25, 2018.
  1. choptop40
    choptop40
    Hey TX , looking good...great start...car looks straight...
  2. txturbo
    txturbo
    Ordered a tuneup kit today.....another thing checked off the list. Still need to find a starter and order some plug wires.
  3. txturbo
    txturbo
    That’s the good side...lol. It has a rust spot at the bottom of the cowl and a dent in the roof from a tree. But it’s a pretty solid body. The floor and trunk pans aren’t rusted out.
  4. choptop40
    choptop40
    I'm starting to be ok with defects...still...deep down there's the other side..always improve...Desotos rule.....
  5. gatz
    gatz
    Great start, txturbo; 'will be watching.
    Amazing how a minimal chop can affect a car's look.
    BTW, is there a name for that "paint", moose?
  6. gene-koning
    gene-koning
    Plymouths were the smallest and the cheapest of the Mopar brands. They were coupled with Chrysler at dealerships, and Chrysler's were the biggest and most expensive of the Mopar offerings. Dodge and Desoto were also paired at the dealerships. Dodge was the bigger and more expensive of those two, and the Desoto were the smaller and less expensive cars at the Dodge dealers.
    Biggest size and, and highest price range in large to small were, #1 Chrysler, #2 Dodge, #3 Desoto, and at the bottom, #4, Plymouth. Body parts interchange was pretty limited, but if parts would swap, Plymouth and Desoto were both smaller then Chrysler and Dodge. Not much will interchange between the 3 versions of the Hemi motors, Chrysler, Dodge and Desoto. A dist might be an exception, shaft length is a big deal, as might be the drive end match up, and how it mounts in the motor. Gene
  7. j hansen
    j hansen
    ^^^^^^MoPar range is Imperial,Chrysler,De Soto ,Dodge,Plymouth.
    vintage6t, Stogy and Lucky667 like this.
  8. choptop40
    choptop40
    That's what I thought
  9. txturbo
    txturbo
    I have two of these to put on the front. Just need to find two for the rear. These are on a 37 Ford frame I have.
  10. txturbo
    txturbo
  11. plym_46
    plym_46
    from central NY
    Bodies are the same from cowl back. B body 8 3/4 rear ends are a relocate the spring perches deal. 3.55 and 3.73 were the common ones with the 3.5 on automatic cars. If you need space to clear the steering box, do what Chrysler did, offset it to the p***enger side a couple inches.
    The hemi isn't that much heavier than the six , springs shouldn't be a problem. A lot of folks put Ford Aerostar van front springs in if you want newer metal. You can lower the front about an inch and a half by moving the spring pocket to the bottom of the lower A arm.
  12. plym_46
    plym_46
    from central NY
    Also you will notice the shock absorbers are mounted between the upper and lower A arms. You can add Ford F 100 style upper shocks mounts to the frame if you want a bit less floaty ride.
  13. txturbo
    txturbo
    Thanks for the info.
  14. txturbo
    txturbo
    I have a ch***is that came from a 37 Ford Coupe that was hot rodded back in the 70s. I did a frame swap for the guy who drove the car in high school. He didn’t want the old hacked up frame and paid me to swap it out with a good all original ch***is. I saved it and just dug it out of the bushes when I moved to my new shop. I’m using the torque thrust wheels off of the front and just remembered it has a later model Ford rearend. I don’t know if it’s an 8” or 9”. I’ll have to check it when I get back home at the end of the month. So I will probably use that in the Desoto.
  15. dumprat
    dumprat
    from b.c.
    I have an extra 4 barrel intake for that engine
  16. txturbo
    txturbo
    How much?
  17. GeeRam
    GeeRam
    Nice.
    There's a nice '41 Desoto coupe (rare RHD version from South Africa) here in the UK also running a hemi, although a much later version IIRC.
  18. shivasdad
    shivasdad
    from Texas
    Subscribed. Love that nose!
  19. Rickybop
    Rickybop
    Surfcityrocker likes this.
  20. txturbo
    txturbo
    Picked up a starter today......the same guy has a 4bbl intake for it.
    j hansen likes this.
  21. txturbo
    txturbo
    Has anyone else noticed that Mopar and Cadillac V8 motors of this era have the same motor mount attachment design on the blocks?
    If this hemi doesn’t work out I have a spare Cadillac 429.
  22. 73RR
    73RR
    At casual glance, all of the 50's Hemi and poly distributors look alike but there are subtle differences.
    The Chrysler 301-331-354 shaft projection, from the base of the distributor housing, is accepted as 4.250" and the DeSotos are 4.150 so using a Chrysler is possible as long as the shaft does not bottom out in the intermediate gear.
  23. choptop40
    choptop40
    Ok , I want that Desoto........to be on the road .....I wouldn't mind owning one those puppies....
  24. txturbo
    txturbo
    Me too.....just not enough time
  25. 30dodge
    30dodge
    from Pahrump nv
    If I remember right the 318 distributors will fit right in.
  26. txturbo
    txturbo
    I don’t know how we got on this distributor discussion but it has nothing to do with my project.
  27. Lucky667
    Lucky667
    from TX
    It started because of your post #11. We are all trying to help, . . .
    kbgreen likes this.
  28. txturbo
    txturbo
    I just needed tuneup parts.....not a distributor
  29. Did a similar build a few years ago. 40 dodge coupe. 392 hemi, torqueflite, 8 3/4 rear, 83 mirada front torsion bar suspension. You'll have fun with that project! P6200163.JPG
  30. txturbo
    txturbo
    Ordered some plug wires.....another thing crossed off the list.
