Technical Oh crap, now what ?
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Dec 5, 2018.
  1. Atwater Mike
    Atwater Mike
    ...And THAT'S why people use 9" rears, children. Genuine Ford Parts. Bronco rears, 5 on 5.5" circle, overall width 56". Craigslist.
    Did you know that all Broncos are patterned at 5 on 5.5"?
    Small AND large brg. ALL 28" spline. 8" and 9". Just for info...
    Truckdoctor Andy and loudbang like this.
  2. BamaMav
    BamaMav
    from Berry, AL
    Yep, but they are getting harder and harder to find used anymore, they haven't been made in what, 35 years or so? I know there are aftermarket ones out there, but big $$$....
  3. lo-buk
    lo-buk
    from kcmo
    Had one that the bolt broke and center pin came out at 55 mph, destroys the inside housing and gears. Ended up replacing the whole rear end. Always best to check the bolt to not have that problem.
  4. Here's the tools
    Here's why I was in there
    Results of overloading
    Making noise for a "couple days"
    The axle is supposed to be smooth
  5. loudbang likes this.
  6. So "a couple days" driving from Alaska to your shop with a dead moose in the trunk?
    31Vicky with a hemi and loudbang like this.
  7. Yeah something like that.
    Making noise louder than the radio could cover up for a couple days lol.
  8. saltflats
    saltflats
    from Missouri
    Did you use an axle saver bearing, or replace the axle?
  9. I replaced the axle, and replaced the standard bearing.
    I figured the worn area on that axle was a great place to snap.
