Projects Final chapter in the crummy chop
Discussion in 'The Hokey Ass Message Board' started by Thommyknocker, Aug 20, 2009.
  1. Thommyknocker
    Thommyknocker
    from Colorado
    I think it's more of a question of if the upper ball joint can take the additional force.
    I'm thinking it's not a good idea now. Those uppers are not very beefy, and those little bolts arnt that strong
  2. Thommyknocker
    Thommyknocker
    from Colorado
    I totaly forgot I had a sticker!!!!
  3. Thommyknocker
    Thommyknocker
    from Colorado
    Dang Nebbit!
    Coolant leak.
    I Really hope it's a freeze plug. If not it might be a head gasket.
  4. Thommyknocker
    Thommyknocker
    from Colorado
    It apears to be worse than just a freeze plug
    Sure looks like a crack
  5. Thommyknocker
    Thommyknocker
    from Colorado
    at first I was like :(
    then I was like :rolleyes:
    It's dad's 327 out of his Chevelle that's been sitting under the bench, patiently awaiting it's turn
    low budget and chryslerfan55 like this.
  6. Thommyknocker
    Thommyknocker
    from Colorado
    Kustom doesn't end with the body[​IMG][​IMG]
    I'm adding pully so I can run the york air compressor and a/c on separate belts
    Full Kustom, drunk mobile posting
  7. Thommyknocker
    Thommyknocker
    from Colorado
    A quick update. I sourced a 8.5 10 bolt to replace the goofy large 8 7/8.
    Then practiced a new skill. Installed 4.10 gears and a limited slip, because I could LOL
    And since the axle is out I inspected my crossmember I made to use the GM 4 link IMG_20181013_201229_164.jpeg 20181017_191309.jpeg 20181017_191340.jpeg
    Full Kustom drunk mobile posting
  8. Thommyknocker
    Thommyknocker
    from Colorado
    The fiddy has been suffering from a high speed cooling problem. Grabbed this aluminum radiator for a c4 Corvette.
    Spending s bunch of time on air flow management. Air dam and side panels are done. Next is a top cover.
    Cat scan approved IMG_20181207_191609_347.jpeg IMG_20181206_192050232.jpeg 1544328592442.jpeg
  9. low budget
    low budget
    from Central Ky
    Wow, Nice ride! Any recent pics of just the car?
    That orange engine sitting by the car makes a fun contrast against the green, a red or orange wheel lip showing might be cool too, or not???
    chryslerfan55 and robber like this.
  10. Thommyknocker
    Thommyknocker
    from Colorado
    Thanks @low budget
    My wife's handywork on the teardrop at a local show this summer 20180825_114229.jpeg
  11. robber
    robber
    Just for grins, Thommyknocker... :) cp 816.JPG cp 868.JPG
  12. Thommyknocker
    Thommyknocker
    from Colorado
  13. Thommyknocker
    Thommyknocker
    from Colorado
  14. Thommyknocker
    Thommyknocker
    from Colorado
    Final test fit.
  15. CruznArt
    CruznArt
    from Germany
