Technical 32 gas tank 30 rail
Discussion in 'The Hokey Ass Message Board' started by dutchrod, Dec 8, 2018.
  1. dutchrod
    dutchrod
    I like to have some more room in the trunk of my 1930 coupester so thinking about a 32 gas tank.
    I got a 30 body on a 30 frame , the frame is stretched to put the crossmember behind the axle for my 1940 rear end.( stock model A wheelbase)
    I dont know if i can put a 32 tank under the body with the spring behind set up( i believe 30 body is a bit shorter then a 32)
    Somebody got a set up like this ?
    (I will raise the tank a bit intonthe rear body to compesate height for not having the higher 32 frame rail)
  2. patzfab
    patzfab
    from Canada
    7A7359D0-C836-47C8-B8B1-E0B95BD8CC52.jpeg Buy a pair of 32 rear frame repair pieces and add them to your frame and just bolt in the tank. I did mine in about 4 hours.
    catdad49 likes this.
  3. missysdad1
    missysdad1
    red roadster 44.jpg I'm removing the '32 tank from my current fenderless '30 roadster project (this is a "before" photo) because it just doesn't look right back there. The body on this car was not modified to allow the tank to sit higher like on a '32 and I considered raising it but don't think I'd like it even then. Makes the car look too "heavy" in the rear. I also had concerns about safety. So I am going with a Tanks behind-the-seat tank instead.
  4. 3banjos
    3banjos
    from NZ
    Missysdad1, I've seen a few examples that look a lot worse than your's. Will you shorten the rails also.
  5. 3banjos
    3banjos
    from NZ
    For example.
    Bandit Billy likes this.
  6. HOTRODPRIMER
    HOTRODPRIMER
    There are just no words to state how wrong this looks, and a 32 at that. HRP
    da34guy and Bandit Billy like this.
  7. GordonC
    GordonC
    Thats an interesting photo. It looks like the guy did a decent job on the car except for the dual antennas, 4 bar, choice of wheels, and the placement of the tank. How can you be tuned in on the rest of the car and miss the point so much on that tank? Think thats a foreign plate on it?
  8. missysdad1
    missysdad1
    Yep. They had been cut off before, lowered in a very shoddy manner and welded back on to mount the tank. So I just cut 'em off and stubbed the rear of the frame rails. At some point I'll use the back sections of the cut-offs to mount the spreader bar up close to the body. I might get to mock that up next week and if I do I'll post some photos.
  9. clem
    clem
    New Zealand !
  10. clem
    clem
    The problem with all the above illustrations, is that the tank sits too far back.
    On a stock ‘32 ford the tank is further forward.
    fiftyv8 likes this.
  11. Texas Webb
    Texas Webb
    Flathead Dave likes this.
  12. Toner283
    Toner283
  13. Toner283
    Toner283
    On a fenderless car they look screwy. Kind of like a duck dragging its ***. On a fully fendered car the rear fenders balance out the look of the tank. They also fill up the gap between the fenders below the body that some people fill with a louvered filler pan of some sort. IMO, if you have a fully fendered car the tank looks pretty good back there. And it's got to go somewhere.
    fiftyv8 likes this.
  14. Mr48chev
    Well that pretty well decided that issue on my 31 Vic. Not much caring for that fat bottom lip look.
  15. HOTRODPRIMER
    HOTRODPRIMER
    This car is owned by a hamber but I don't remember his name, he did a excellent job adding a deuce gas tank to a mocel a frame, looks like it was originally built like that. HRP
    Shadow Creek and fiftyv8 like this.
  16. dutchrod
    dutchrod
    Thats what i’m afraid of with the spring behind set up the tank can not get forward enough.
  17. dutchrod
    dutchrod
    I like how this one is lifted into the body.
  18. fiftyv8
    fiftyv8
    from CO & WA
    They can be installed to look reasonable, but from the look of things it does take some effort to get it right.
  19. sloppy jalopies
    sloppy jalopies
    The reveal running across the tank's top is 1.75" forward of a '32- 5 window's lower panel...
    I also moved the tank ahead 1/2 of the difference in wheelbases … 1.25" as I was figuring in that the A body is shorter...
    memory says tank moved forward 2.75" total... will check soon with pix...
  20. Blues4U
    Blues4U
    from So Cal
    Maybe mount it underneath, like so?
    clem likes this.
