Technical Concentrated Chelating Rust Remover on Jay Leno's Garage
Discussion in 'The Hokey Ass Message Board' started by MrCreosote, Nov 29, 2018.
  1. MrCreosote
    MrCreosote
    from USA
    I remember what I forgot about mol***es that I read elsewhere: it doesn't really start working until the mixture turns rancid - hence the "put it in a field because it stinks."
    Any confirmation on that?
  2. 56don
    56don
    I have used the mol***es bath before. Put 8 parts water to 1 part mol***es in a 55 gallon drum. It does work, but it does indeed stink. Works better in summer when it can heat up. If I had very crusty parts, I would take them out after a week or two and clean the crud off of them then put them back in. Its a slow process. I found out with a set of heads though that the process will leave pits in some machined surfaces. But done properly, parts come out as clean as a baby's ****......you know, before the diaper thing happens.....
    alanp561 likes this.
  3. MrCreosote
    MrCreosote
    from USA
    The pits in the machined surface, I'm hoping that is because it was a rust pit and not an attack on good cast iron?
    So you wouldn't recommend me doing this in my home's heated ba*****t, huh? Hum, maybe I could find a 5-gal with a lid where I could make an exhaust hose and run out the window.
    I do keep my garage at 45* and I have one of those electric dip sticks that might keep it a little warmer. (could still do the "exhaust" hose too)
  4. 56don
    56don
    No way would I put that mess inside my house. When it stinks, it smells like an overrun septic tank.
  5. MrCreosote
    MrCreosote
    from USA
    Yeah.... I think I'm going to try electrolysis
  6. noboD
    noboD
    Keep that thought buddy. You are probably the only one in America that thinks that way.
    Squablow, The37Kid and gimpyshotrods like this.
  7. The37Kid
    The37Kid
    X 1,000+
    Squablow likes this.
  8. MrCreosote
    MrCreosote
    from USA
    I was thinking about the mol***es not workig "until it went rancid." I wonder if putting some yeast in it would speed up the process? (I'm guessing that mold is a good thing actually - does the bacteria eat the rust???)
  9. Lone Star Mopar
    Lone Star Mopar
    stanlow69 likes this.
  10. I haven't tried it on anything automotive related, but at work we periodically have to clean crud out of our boilers. We bring in a tanker full of tetraammonium EDTA, which is a chelating agent. Its fairly benign stuff because it is used in foods, but has to be 300 degrees to activate. It leaves a white metal surface. Occasionally we use citric acid for cleaning, but it is more for oil residue. I've never looked into buying smaller quan***ies, but its not that expensive. Now you've got me thinking...
  11. Los_Control
    Los_Control
    from TX
    I have tried the mol***es and works great. Not real fast but very thorough.
    As I understand it, you need 70 + degrees temp for it to activate.
    So winter time is not ideal. I had a small plastic barrel out back in my uncles yard.
    I kept a lid on it, skunks kept getting into it and eating the stuff.
    A article I found on the net, talked about kids that got a large hot tub for free off of craigs list, they pooled their money and for $300 worth of mol***es from the feed store, they were dipping body panels all summer long.
    And it is environmentally friendly when time to dump it. The sugars will act like a fertilizer on the ground.
    I give mol***es a thumbs up.
  12. stanlow69
    stanlow69
    Works for me. And doesn't stink. The second pic was rinsed off at the car wash and left to dry. And the metal was left untreated for 4 months. Scan0492.jpg Scan0784.jpg Scan0785.jpg
    Lone Star Mopar and The37Kid like this.
  13. gnichols
    gnichols
    from Tampa, FL
    Just wondering, what is the post-mol***es life like on the metal? I mean, does the citric acid actually stop oxidation, too, or just change the rust to another color? Gary
  14. stanlow69
    stanlow69
    ^^^^^ ? For light surface rust, this was in my tank for 15 minutes. Scan0491.jpg
    gnichols likes this.
  15. Joe H
    Joe H
    Watch this, very informative,
