My shoebox is back on the road again!!!!
Discussion in 'The Hokey Ass Message Board' started by crusader, May 27, 2006.
  1. crusader
    crusader
    Thanks to the help of some great friends she's back on the road where she belongs a lot sooner than I thought and I will spend the next two months making her strong enough for a daily driver. There is a lot to fix and do still to have a finished Kustom but I'm happy as hell to have her this far! I think my pinion angle is wrong because I hear a grinding noise when she is not underload but at traveling speed. Any o-pinions?:D
  2. hiway7
    hiway7
    from Socal
    Mike,
    It looks amazing bro. And to think a few weeks ago it was in pieces.
    Can't wait to see it in person.
    ~J
  3. BadLuck
    BadLuck
    Bad *** ride......just my o-pinion!!
  4. crusader
    crusader
  5. SanDiegoJoe
    SanDiegoJoe
    Nice!
    - I can't wait to see it rolling all over So Cal.
    Joe
  6. squigy
    squigy
    from SO.FLO.
  7. You my need new u- joints .The u- joint may be rubbing on the bottom of the floor when just sitting an the drive shaft is spining.When you are under load it may not hit then.Or like I said you may have a few bad needle bearings bad in the u-joint.How much is the chop front to back?Post a side picture with out the skirts. I think it looks more sinister with out them .When you show how low the wheel well is droped over the tire.I also have a shoe box.Yours gave me a woody,What is the grille made of what piece? What make are those chrome rims .Nice work
  8. crusader
    crusader
    Thanks Grinder. I looked underneath and didn't see any scratching on the floor but I suppose it may be too little too notice. With paint I should be able to tell. I don't think it's the trany.
    Chop is 4-1/4 up in the front and laid down until the right look was achieved. The grille I took a '63 Buick Riveria bumper and cut off the ends to make the grille. The bends were used to make the ends of the current piece. Needs a little more work in the back but the front came out great and no need to cut up 3 expensive '51 Ford grilles. The rims are chrome reverse standard offset in front with spider caps and no offset in the rear.
    I don't have a pic without the skirts or lowered all the way yet, but I'll definitely put it on the "to do" list!!
  9. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Check, as suggested, your front and rear U-joints, than if ya find nothing,
    jack up the rear of the vehicle and with the *** end off the ground and on
    jack stands, start the car and put it in gear. Get a buddy to run it through
    P R N D 1 2 and look and listen for clunks and whines. Is your pinion on the
    same plain as the tail shaft of the trani? If it's off more than six degrees,
    it's going to vibrate'n' *****. Does this have a rubber snubber above the
    third member/u joint, attached to the frame, and is it installed?
    Great lines to the chop, by the way,
    S****ey Devils C.C.
  10. BICKFORD
    BICKFORD
    from CA
    looks good.now get a hair cut you ****ing hippie!
    j
  11. crusader
    crusader
    Soon Jason, very soon! It's motivation brother....:D
  12. crusader
    crusader
    Thanks for the advice! I'll do just that. From my understanding the angle of the pinion should be opposite of the tailshaft to equal 0 under load. I will check it again. I do not have a snubber above the u joint as I have two C10 trailing arms as a four link set up. Here is a few pics...
  13. mazdaslam
    mazdaslam
    Good looking car.Do you have any better pics of your truck arm installation,like the foreward mounts and crossmember?I have a pair of these arms that I am going to use on my 39 Merc.
  14. Chaz
    Chaz
    Thats as nice looking as a shoebox can get.... JUST RIGHT!
  15. crusader
    crusader
    I don't have more pics right now but the mounts are right next to the exhaust on one of the pics. You can only see half of it with the bolt. I'll try and get some more later!
  16. droplord49
    droplord49
    from Bryan, Tx
    Beautiful, very nice profile on the roofline
  17. rockabilly_bass
    rockabilly_bass
    ha ha love the striping and lettering on the back , bad *** ride man , whats the final color going to be ? i know how it feels to always be behind on everything , so getting ahead must be awsome !
  18. poorboy
    poorboy
    looks good man!
  19. Very frickin killa ride.
    Mine shoebox is so close to being on the road too I can taste it:cool:
    Your chop looks great,as does the stance too.
    Howsa bout some more details?
    The grillbar treatment is perfect.....Shiny
  20. crusader
    crusader
    Thanks for the comments guys! Running an s-10 clip with s-10 rear end, '68 327 with Turbo 350 (until I change it to a 700). The color is going to be HOK Deep Organic Green with white tuck-n-roll interior, stay tuned...
  21. Dam man your killen me given me all these woodys.Started looking at the pictures first.Said dam thats not ford under their.Looked closer dam c -10 .You need to caulk the top and bottom seam in those arm or they will rot when water gets between them . Looks sweet.
  22. rockabilly_bass
    rockabilly_bass
    sweet , i was thinking green would be sweet on it , as long as its not another flat black ride im good !
  23. CyaNide
    CyaNide
    from Texas
