Technical Fuel Pressure regulator
Discussion in 'The Hokey Ass Message Board' started by B.A.KING, Dec 11, 2018.
  1. B.A.KING
    B.A.KING
    I'v been following a thread about a tri- power set up. I've talked myself into putting a regulator on my car. Its 348 tri power.With that said. I really dont like the look of regulator setting out there. Just me, pet peeve .I'm getting one that will set at about 2-4 . But are there smaller ones and can/where can i hide it.It just will not look right on my 348. Any ideas?
  2. kaspar
    kaspar
    On my Model A w Cadillac 390/tri power I put the regulator under the floor (approx where the p***engers feet were). I also had a fuel pressure gauge in the engine compartment, plumbed from a port on the regulator.
    In my case, it was a full return fuel system so it was a bit of a h***le to make all the hard lines, but with a no return system it should just be to "splice in" the regulator on the existent fuel line.
    Just remember to mount the regulator so you can easily adjust the pressure if necessary.
  3. Mike VV
    Mike VV
    from SoCal
    For the "system" to work correctly, the regulator needs to be as close to the carburetor inlet as possible.
    That said, I suppose, you could put it at/under the firewall, understanding that the farther it's mounted from the carburetor, the less accurate it will be..!
    Here's where I mounted mine -
    Mike
    Max Gearhead and mad mikey like this.
  4. the-rodster
    the-rodster
    A fuel presssure regulator made a world of difference for my two strombergs.
    Put it in plain sight, it let's people know that your keeping an eye on things.
    Rich
  5. olscrounger
    olscrounger
    mine is bolted to a bracket at back of carb. It is a Holley-hard to see under air cleaner--has been there and worked well for 10 years.
    mad mikey likes this.
  6. catdad49
    catdad49
  7. mad mikey
    mad mikey
    Should be mounted close to carb like Mike stated. Here is mine. WIN_20170423_12_34_39_Pro.jpg
    catdad49 likes this.
  8. saltflats
    saltflats
    from Missouri
    If you have the factory air breather, you should be able to hide it under it.
  9. Bandit Billy
    Bandit Billy
    Tuck it behind the blower where no one will see it.:cool:
    chevy57dude, catdad49 and Rich S. like this.
  10. 56premiere
    56premiere
    Some things are just too hard to hide , so just mage a clean setup. Necessary stuff is what it is. With a 348 people really shouldn't notice a small addition
  11. vtwhead
    vtwhead
    On my 348 I built a bracket and mounted it in front of the head. Here is a pic of when we were setting up the fuel lines fwiw. Sold the car to a friend and he drove it in 100 degree summer weather last year without any heat soak issues if you might wonder.
  12. B.A.KING
    B.A.KING
    Well where you have it ,it doesn't stick out like sore thumb.I guess like 56 said above. Some things you just gotta have/do.
  13. Bandit Billy
    Bandit Billy
    ^^^^^X2. What's the point of looking cool if it doesn't run right?
  14. Beanscoot
    Beanscoot
    In a lot of cases, can't you just use a mechanical fuel pump and skip the regulator?
    If you use a rebuildable type pump, you can replace the main spring with a lighter one to get the desired pressure.
  15. rjones35
    rjones35
    Probably not the look you're going for but here's what I did. FB_IMG_1521479111686.jpg
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
  16. rjones35
    rjones35
    Texas Webb likes this.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    I know it is wrong but I hated the look of the regulator so I mounted it way back by the fuel tank just in front of the electric fuel pump. Set it for 2 psi... that was 8 years ago. Completely trouble free since
  18. 2OLD2FAST
    2OLD2FAST
    from illinois
    So in other words , you have no idea what your pressure at the carbs is ??
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    I used a temporary carb mounted gauge while I set it to 2 psi. then I removed the gauge and forgot about it. no issues in the 8 years I have been driving it
    Stogy and olscrounger like this.
  20. vtwhead
    vtwhead
    so what regulator did you use?
  21. TrailerTrashToo
    TrailerTrashToo
    I'm going to go with Moriarty on the fuel regulator mounted near the tank. The regulator mounted in the engine bay gets much hotter, a recipe for vapor lock. I fought vapor lock for several years (OT 392 CID IH engines - I had to avoid Tucson and Phoenix in warm weather) before going further OT (the dark and smokey side) with diesel trucks.
    Moriarity likes this.
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    It is an edelbrock 1789 1-4 psi.... I didn't want any modern looking stuff under my hood.. worked out for me but your results may vary. I know they say it is not a good idea. but my carbs don't flood and it runs great
  23. hudson48
    hudson48
    I think it was my thread that got B.A.King started on this. I have always had the regulator just before it goes into the fuel block on the firewall and then the three lines feed to the carbs. Did the changeover with the Holley regulator and put the lighter spring in and set at 2.5 lbs and looks like my problem solved. The car idles better and smoother on acceleration.
    TrailerTrashToo likes this.
  24. Blues4U
    Blues4U
    from So Cal
    Use a Malp***i Filter King pressure regulator and you won't mind it being visible in the engine compartment at all.
    They also make just a regulator without the filter bowl, it looks great too:
    You can find them on the bay.
  25. Max Gearhead
    Max Gearhead
    from Wisconsin
    I got one of those regulators. Very nice item.:cool:
    Blues4U likes this.
  26. Beanscoot
    Beanscoot
    I like the gl*** bowl, mine is aluminum.
    Max Gearhead likes this.
  27. B.A.KING
    B.A.KING
    I think i like that ....a lot!! MANY THANKS!!!
  28. clem
    clem
    Did you set it up with a return line or without ?
    Thanks
    Clemens.
  29. big duece
    big duece
    from kansas
    What is the pressure range, and how is it adjusted?
  30. Jmountainjr
    Jmountainjr
    A few years ago oj on here was taking a br*** Hilborn pop off body and changing the spring and provided shims so you could get 2.5 / 3 / 3.5 PSI. Could mount on fuel pump outlet, but would need a return. I can't find the post where he showed one installed. I bought one for a slightly different application. You might PM him for a picture and see if he still makes them.
