1947 Ford COE build
Discussion in 'The Antiquated' started by jackalope, Nov 8, 2018.
  1. jackalope
    jackalope
    So, I recently finished a 1930 Ford Model A coupe and had every intention of building a 1930 Roadster, but something else nudged that project out of the way. The encroachment of a 1947 Ford COE happened upon me and now takes precedent over other personal projects.
    It’s in remarkably good shape give it’s age and life as a work truck.
    First step was to pull off the fenders and straighten them up. That required a lot of hammer and dolly work coupled with welding up several years in the metal.
    Once those were relatively smooth, they each went into planishing hammer for further smoothing. They then were set aside.
    Next was the lower door patches. Started with a paper template slightly oversized so that I could throw it in the brake and bend it to wrap around door frame. Once I had the General shape they went into a shrinker stretcher to get the correct contour and bend of the original door.
    Cut the old out and as to be expected the internal structure was gone so I had to make that first. So, I made that and then put the new panel in place. Did this for both sides. Just tacked the panels in place. At this time I also realized that the original door gaps from factory were an afterthought at best. Body stampings at the door seam are curved and not even side to side. I will correct that later.
    The latest progress is the lower perimeter bead. I am a bit stumped over this but reached out to Matt at Iron Trap Garage for ideas. Simple answer is there are no easy ways to make this piece.
    I machined a die to use in a hydraulic press to form the bead profile which works but over such a long span it deviates from straight. So, it looks like I will machine some dies for the bead roller to start the profile and the. Run it through the die press and then again through the bead roller.
    For the corners it looks like I will machine a big thick piece of plate with the bead profile and bend it like the corners. I’ll use this plate as a buck to form.
    Fingers crossed. [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Fyresq, livertucky, Okie Pete and 2 others like this.
  2. jackalope
    jackalope
  3. ckdesigns
    ckdesigns
    from Ogden,Utah
    Nice work so far!
  4. jackalope
    jackalope
    I had a little time this evening and got up to the shop. I made a set of dies for the bead roller. By making a bead first, it allows the piece to seat easier and straighter in the die. Getting there. [​IMG][​IMG][​IMG]
  5. E46
    E46
    I love COEs and will watch this build. It's clear that you have the skills to pull this off.
  6. kscarguy
    kscarguy
    Looking good so far. Before you s**** the stock bumper, let me know. If the price is right, I'd be interested in buying it from you.
    jackalope likes this.
  7. jackalope
    jackalope
    Only had a few hours to mess with it today so I went after the grill. [​IMG]
  8. jackalope
    jackalope
    I’m not able to attach any more pics?? Well this ****s.
  9. jackalope
    jackalope
    Only way I can add images is through Web. H.A.M.B. app isn’t allowing me to
  10. jackalope
    jackalope
    Had a couple hours. First bead rolled the lower piece to the correct profile. Then tacked it in place. Then it was on the the center spine. I had to remake it because something was a hair off.
    Gettin’ there.
  11. modelkitbasher
    modelkitbasher
    Damn nice work.
    willysman
  12. jackalope
    jackalope
    Had about 3 hrs to play this evening. Welded up the grill, hammered some high spots and low spots and set it in place. Then got started on lower bead along entire lower cab.
    Ace61, warhorseracing and Okie Pete like this.
  13. jackalope
    jackalope
    I got a few more hours in at the shop. Hoping to have all the body sheet metal repaired and/or replaced by next weekend.
  14. iwanaflattie
    iwanaflattie
    *****ing project.. Love them coes
  15. jackalope
    jackalope
    A little more time to peck away at it. Straightening the step on driver side. Also got the remaining lower bead all the around to driver side as well. The nice thing about these big trucks is they were built with thick metal and higher quality metal it seems. Yes there is some rust in spots but the good metal is a mother to cut through compared to the newer steel these days.
  16. jackalope
    jackalope
    Lower bead is complete. Gas filler hole closed and started lower door jambs. Have work tomorrow but should. E back at it and finished with body sheet metal by Friday.
    warhorseracing likes this.
  17. livertucky
    livertucky
  18. jackalope
    jackalope
    livertucky, RMR&C and warhorseracing like this.
  19. jackalope
    jackalope
    Hard to stay on this while I build a mobile coffee truck for a friend. Made some cold/fresh air mesh screens to replace the old rusted ones. [​IMG]
    Al's.C.D.T and warhorseracing like this.
  20. The37Kid
    The37Kid
    Nice project, good to see you have the tools & skills to get this moving along. First time I've noticed the later cabs kept the three ribbed belt mounding like the 38-39 pickups. Bob
  21. jackalope
    jackalope
    Yep, the cabs are all the same from 38-47 for COEs. Only variance is in the grill shell for 38/39. Those had the oval insert but all interchange between years.
    They also look good with the matching baby brother regular pick up with the same belt line as you eluded to.
  22. 1940Willys
    1940Willys
    Nice work I'm enjoying this. Ok, Carry on
  23. jackalope
    jackalope
    I had the 47 media blasted which did show a few minor pinholes in random locations. Likely due to the inconsistency in the metal 70years ago. Rather than cut out I leaded the small spots. Also had some time to repair the irreparable steps that had rusted through the bead area. Finally, last night I made a few mi or repairs to the driver side fender and gave it a mock up. Gap needs work lower front but should be straight forward. Then on to the other side.
  24. jackalope
    jackalope
    Found some more rot that needed to be removed. Also a pic as I left the shop. Other fender mocked up.
    R A Wrench and Crusty Chevy like this.
  25. jackalope
    jackalope
    Fixed the rot. Found a couple other spots I will tackle next time.
    Peanut 1959 likes this.
  26. redzula
    redzula
    Nice build so far..... Maybe I missed it but what is your plan for the finished truck? Flatbed car hauler, truck bed, camper box. What are you wanting to end up with?
    Sent from my rotary phone using The H.A.M.B. mobile app
  27. Al's.C.D.T
    Al's.C.D.T
    Seeing this brings back loads of memories, stripping down and rebuilding my 41 COE
    Looking really good best of luck with it, and have fun.
  28. jackalope
    jackalope
    I actually haven’t had a chance to mess with this since my last post with the door.
    The plan is to use a toronado front end with a transaxle. This will eliminate the need for a rear drive shaft. I have bogies from a 12k lb motorhome and they will serve as rear “axles”. I will have a bed “look” but the inside deck will tilt like a flat bed. I want my cake and eat it too. Not gonna be easy but I have the idea based on Denny’s Hot Rods but with some additional tweaks.
    Shadow Creek likes this.
  29. KCTA Chris
    KCTA Chris
    Happy to see another COE project! Looks good.
    I've been killing myself on the other side of the state for a 2 speed rear axle and a few original (lock ring, not 2 piece split rim) wheels for my flatty powered '39 COE project. Do you s**** the ch***is?
