Projects 1946 MERCURY HUBCAP ON EARLY HOT ROD
Discussion in 'Traditional Hot Rods' started by dlw1932, Nov 11, 2018.
  1. dlw1932
    dlw1932
    from Nebraska
    Can someone post some photos of a 32 Ford or Model A hot rod with 1946 Mercury Hubcaps, or 47-48 mercury hubcap, preferably 1946. I did a search on the forum and on google and couldn't find any photos, but think these caps might look good on a hot rod. Thanks
    lothiandon1940 likes this.
  2. missysdad1
    missysdad1
    Not mine, owned by lothiandon1940 here on the HAMB. I thought about using them too.
  3. not sure....never asked the uncle about the cap's....they looked good to me....about 1955 in front on my pop's shop.... Scan9_0009.jpg
    Surfcityrocker, TagMan, 51box and 5 others like this.
  4. I like 'em, but it's a personal thing.:) 20171112_180732.jpg FB_IMG_1525008048923 (1).jpg
  5. sloppy jalopies
    sloppy jalopies
    memory says the '46 merc hubcaps are deeper than most... they clear the model A rear hubs/axles...
    $0.02
  6. ..................They do have a deeper dome than say '46 Ford caps. 12019836_1246272985398185_3439067659535294387_n.jpg
    Hnstray and Ron Funkhouser like this.
  7. These two similar views show better the dome difference.. 20160823_184325.jpg 20160830_193647 (1).jpg
  8. dlw1932
    dlw1932
    from Nebraska
    Great thanks for the photos. Keep them coming if you got them.
  9. sloppy jalopies
    sloppy jalopies
    deeper... and larger diameter... DSCN3429.JPG DSCN3428.JPG DSCN3427.JPG DSCN3430.JPG
    dlw1932 and lothiandon1940 like this.
  10. i.rant
    i.rant
    1. 1940 Ford
    Never realized the diameters were so different. o_O
  11. [​IMG]
    slv63, dlw1932 and lothiandon1940 like this.
  12. dlw1932
    dlw1932
    from Nebraska
    The T tudor looks good with them!!
  13. How can folks not like a deeper dome?:D;)
    lothianwilly71 and dlw1932 like this.
  14. oldsman41
    oldsman41
    I had a set on my roadster i liked the way they looked.
  15. x77matt
    x77matt
    Best looking caps for a hotrod steel wheel IMHO! 46 or 48- can't go wrong either way!
  16. ........Even though the overall diameter is larger the mounting rings are the same 8 and 1/8 inches.:) 20181115_061449.jpg 20181115_061515.jpg
    i.rant and Hnstray like this.
  17. dlw1932
    dlw1932
    from Nebraska
    Just found this pic on another thread of a 34 Tudor with 46 Merc caps. :cool:
  18. ^^^^Love it^^^:D
    lothianwilly71 likes this.
  19. Looks great dlw32:D 34 ford hamb.jpg
    dlw1932 likes this.
  20. LUTHER99
    LUTHER99
    [​IMG] Here,s mine , 48 merc caps , from donor in back round , black merc inscript takan off , a bit dented up fits the car.
    dlw1932 likes this.
  21. If I remember correctly you must use a Mercury wheel to be able to use a Mercury hub cap.
  22. LUTHER99
    LUTHER99
    same mounting ring , dia of cap is larger
