Technical Q. What's the difference between a Quick Change and a 9 inch?
Discussion in 'The Hokey Ass Message Board' started by Dreddybear, Dec 13, 2018.
  1. Paul
    Paul
    Editor
    Dreddybear, slayer and loudbang like this.
  2. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    You can use a 9" to get a quickie, but you can't use a quickie to give you 9"!
    Deuces, theHIGHLANDER, slayer and 3 others like this.
  3. DDDenny
  4. fiftyv8
    fiftyv8
    from CO & WA
  5. spanners
    spanners
    Careful or this thread will get 'locked'.
    clem and fiftyv8 like this.
  6. 41rodderz
    41rodderz
    from Oregon
    :D:D me too. Saw ***le in message board and thought is this one serious ? Turned the page and found out not at all:D:D
  7. 41rodderz
    41rodderz
    from Oregon
    I really appreciate a good laugh after a long hard day.:cool:
  8. Paul
    Paul
    Editor
    Locked, open, what's the differential?
    nochop, Jeff Norwell, SR100 and 2 others like this.
  9. deucendude
    deucendude
    from norcal
    Everyone has a pinion on this.
  10. DDDenny
    Does this make my rearend look big?
    GuyW likes this.
  11. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    YOUR REAR END IS BIG!!!!!
    HemiDeuce likes this.
  12. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    Depends on how you like your rear end.
  13. Blue One
    Blue One
    from Alberta
    I like mine like this.
  14. j3harleys
    j3harleys
    No it's your fat axle that makes it look bigo_O
  15. patzfab
    patzfab
    from Canada
    All the owners of 9 inchers have lower pinions of those with a QC with higher pinions.
    That’s what it seems like anyway.
    BTW EX always = Y
    Y did you buy that
    Y are you going racing
    Y do you want another one
    Y did you go to the bar
    Y do you need new wheels
    So X = too many Y’s
  16. sliceddeuce
    sliceddeuce
    Congratulations....That was the worst yoke I`ve ever read.
    kidcampbell71 likes this.
  17. sliceddeuce
    sliceddeuce
    Yes,..I know my in-put has no bearing..………...
  18. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    About 300hp.....
  19. fuzzface
    fuzzface
    I see I am out shafted here so I am going to grab my gears and go to another thread and see if I can spin some wheels over there instead. :)
  20. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  21. patsurf
    patsurf
  22. sunbeam
    sunbeam
    If you are changing ratios about 40 minutes.
  23. clem
    clem
  24. Never2old
    Never2old
    from so cal
    Only one can be played on a banjo.
    Paul likes this.
  25. Lot of that Dual Stromberg 97 "air" floating around here.
