Hot Rods POWERGEN from SPEEDWAY MOTORS
Discussion in 'The Hokey Ass Message Board' started by CARPY, Apr 16, 2018.
  1. try another at $400 plus?
    6.3%
  2. Repair bearing but where?
    93.8%
Multiple votes are allowed.
  1. CARPY
    CARPY
    I purchased a Powergen for the 28 Roadster of mine ******** thing has a noisey bearing, Rang Speedway, they aint interested, waste of over $400, bunch of ****ers.
    Felix 40 and chryslerfan55 like this.
  2. krylon32
    krylon32
    from Nebraska
    Try asking for Dave.
  3. 2935ford
    2935ford
    Like your roadster!
    They won't replace it? Due to being an electric component? or?
  4. Primered Forever
    Primered Forever
    from Joplin,MO
    I bought one from them 5 or 6 years ago that just flat didn’t work and they took it back and sent me another one. It worked!
    dana barlow likes this.
  5. RICH B
    RICH B
    If it isn't under anyone's warranty, put a bearing in it; generators/alternators are not complicated things to repair.
  6. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Did you contact Powermaster about repairing it and if there's any warranty remaining?
    Bigblue61 likes this.
  7. Torana68
    Torana68
    from Australia
    If the reseller doesn’t want to help contact the manufacturer. Bit more info maybe, like how old is it? Should be an easy fix though if it’s just a bearing......
  8. Bowtie Coupe
    Bowtie Coupe
    1. Check with Powergen for any warrantly coverage you may have. If none, then
    2. I wud think there are any number of auto electric shops in the La Mirada area that cud replace it if you didn't want to do it.
    figure8 and lothiandon1940 like this.
  9. Like they said. If it's not covered by any warranty just pull it apart, pull the bearing out. It should have numbers stamped on it, should be cheap and easy to find.
  10. PunkAssGearhead88
    PunkAssGearhead88
    from So Cal
    I think some of you may be missing the point.
  11. wheeldog57
    wheeldog57
    I couldn't afford one of those so I asked around. Turns out there is a local guy that converts original 6volt generators to 12 volts. I called him.
    $90.00 total. Dropping it to him this weekend.
    Good luck bud
    Sent from my E6810 using The H.A.M.B. mobile app
    lothiandon1940 and Hot Rod Nut like this.
  12. wraymen
    wraymen
    Isn't it still a generator? Not that there is anything wrong with them, I have one in my Ford. Just curious. The Powergen is an alternator in generator clothing.
    lothiandon1940 likes this.
  13. wheeldog57
    wheeldog57
  14. How long have you had it ?
    Speedway is usually pretty good with warranty? Unless you have owned it a while
    Try the manufacturer
    If it’s just a noisy bearing it’s an easy fix
    ****s you were told to kick sand
  15. oldtom69
    oldtom69
    from grandin nd
    now the generator and owner have matching whines
  16. seb fontana
    seb fontana
    from ct
  17. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    ^^^ Maybe..... Communication between the buyer/seller...... How long owned/receipt, problem? What are we missing here? Speedway is pretty good of taking care of things. Can't believe after a convo, that they'de say your **** out of luck with no additional direction.....
    Something's missing within this thread........:rolleyes:
  18. tfeverfred
    tfeverfred
    That doesn't sound like Speedway.
  19. pat59
    pat59
    when did you buy it? got proof of purchase? was it outa warranty?
  20. denis4x4
    denis4x4
    from Colorado
    One year warrantee for street use and 90 day for racing applications according to the Speedway website. Five star rating from two buyers.
  21. Torana68
    Torana68
    from Australia
    If the OP’s communication with us is anything to go by it may explain a lot, no answer to a common question “how old is it”
    I give the OP one star ( spelling was ok ish)
    Jet96, shawnsauto1 and 61Cruiser like this.
  22. Kenny P
    Kenny P
    Happy with mine.
    Agreed, doesn't sound like Speedway, they have always been more than helpful.
  23. HIDDEN
    HIDDEN
    I'll give you $100 for it lol
    Frankie47 likes this.
  24. trad27
    trad27
    I bought mine from speedway and been 3 1/2 years and going strong still. I agree with others, there’s more to the storie. Speedway has always been great with costumer service with me.
  25. Ebbsspeed
    Ebbsspeed
    CARPing about it without any details won't get much support here.
  26. CARPY
    CARPY
    I bought it just over the year warranty but was buying parts to build a Hot Rod, so I have only just got it on the road, 200 miles on it and bearing takes a **** ion the power Gen, Speedway will not replace at all, so am dealing with powerbuilt, may have to send it to them, pain in the **** though.
  27. CARPY
    CARPY
    Out of warranty but it took a year to get the Rod Built for the road, and only done 220 miles with that Power gen on.
  28. rusty valley
    rusty valley
    over on the barn there has been several threads about failed bearings in the powergen. i would think they would have made some changes by now. i just bought one from ed whitney, not received yet, but they have a good rep it seems
  29. 2935ford
    2935ford
    That ****s.
  30. CARPY
    CARPY
    I will mate- cheers.
