29 coupe jalopy project Australia
Discussion in 'Traditional Hot Rods' started by Vonkackler, Feb 16, 2017.
  1. sloppy jalopies
    sloppy jalopies
    if you want a molding between the roof and quarters, try using [2] '30-'31 ford one ton truck cowl bands.
    they are stamped steel not stamped stainless... radius is very close...
  2. Vonkackler
    Vonkackler
    Bout to chop another 3 3/4” out and drop the rear window down a little to keep it useable. Already has a 2 1/4” chop.
  3. cool tail light brackets, they look good. what is that sticker on the rear gl***?
  4. Vonkackler
    Vonkackler
    Thanks. It’s a Hoods CC sticker. I’m a member of the Australian chapter
  5. oldsman41
    oldsman41
    Great i like it something a guy would have done after ww2. Run with it.
    Vonkackler likes this.
  6. Vonkackler
    Vonkackler
    Braced the body and chopped the top off yesterday. Went pretty well for my first time and working alone.
    [​IMG][​IMG][​IMG][​IMG]
  7. Vonkackler
    Vonkackler
    Got the roof tacked back on and did a relief cut up the rear corners to get it lined up. Gaps are pretty good and will be easy to tig.
    The rear window panel was installed by a previous owner as it’s a special coupe. Will take a bit of work to clean it up.
    [​IMG][​IMG]
    Ron Funkhouser, woodz and Stogy like this.
  8. sloppy jalopies
    sloppy jalopies
    I post this feeling a positive nostalgia...
    these aussie builds remind me of the old days when we yankee rodders had to build our own parts as there were very few re-pop parts...
    we had it good as when we were there the yards were full of donar cars …
    the aussies are building 20 years after the donars have been donated...
    scrounging and fabricating are the needed skills... GO AUSSIES GO !
  9. sloppy jalopies
    sloppy jalopies
    I listed the Aussies…
    but most rodders not in the USA and Canada are fishing in the same pond...
  10. ROADSTER1927
    ROADSTER1927
    Looking better all the time!:D:D:D
  11. Vonkackler
    Vonkackler
    Got the top all welded up and windows aligned on the weekend
    [​IMG][​IMG]
    Ron Funkhouser and 1934coupe like this.
  12. Vonkackler
    Vonkackler
    My wife touched up the paint on the roof to. Really happy with how it turned out and the rear window looks nice after dropping it in line with the side windows.
    [​IMG][​IMG][​IMG]
  13. sloppy jalopies
    sloppy jalopies
    I've posted this before but if you don't have the roof to quarter molding check out the '30-'31 one ton truck cowl bands... they are steel not stainless so you can work them... they fit the radius well and should be cheap... you will need [2]… HIH.
  14. Vonkackler
    Vonkackler
    My wife bought me a beautiful new burns intake for our anniversary
    treb11, murf 32, bondojunkie and 2 others like this.
  15. sloppy jalopies
    sloppy jalopies
    beautiful… does she have a sister ?
  16. Vonkackler
    Vonkackler
    Cut the header panel down and mounted it about 2” higher than standard to keep the front gl*** larger
    [​IMG][​IMG]
    Shadow Creek and bondojunkie like this.
  17. Nice work , true hot-rodding ....
  18. Vonkackler
    Vonkackler
    Finished off and got a few nice pics. Made a push bar as well. That’s all for this one as it’s now sold. Time to build the wife’s roadster.
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    Asphalt Demon and Shadow Creek like this.
