Technical Y block in pre war chassis
Discussion in 'The Hokey Ass Message Board' started by DesertRat#1, Nov 21, 2018.
  1. DesertRat#1
    DesertRat#1
    I have been doing my due diligence as my ideal build would be a sweet 292 Ford V8 in my 40 ford pickup. It appears that there a few ford on ford power plants but the bulk of the engines in these rods appear to be "other" to me. I have the truck, I have the motor and I have the motivation. I am just looking for a build thread or someone who has walked the path as I have a few questions. The fabrication doesn't scare me. I get the firewall recess and the pan issues but even after buying and reading the 56 Hot Rod magazine article of the swap I am wondering if I should hold the line or cave and stick a 327 or something else in the thing. Advice appreciated!
  2. jeepsterhemi
    jeepsterhemi
    Go for the ''Y''....
    dana barlow and OahuEli like this.
  3. miker98038
    miker98038
    I don’t know enough about 35’s or 40’s to know what if anything they have in common. But Rono over on the yblocksforever site has a blown y in a 35. He’s over in Meridian, just west of Boise ID.
    http://forums.y-blocksforever.com/Topic80684-1.aspx
    I’ve got an F code y in my 32.
    There’s a Yblock build or two on here also. Go for it
  4. AldeanFan
    AldeanFan
    Go with the y block, be different!
    Fabrication is fabrication, doesn’t matter what engine you put in what if it’s not stock you’ll need to make it fit.
    Post pics !
    czuch, mgtstumpy, OahuEli and 2 others like this.
  5. Jakes38
    Jakes38
    Anything will fit with a torch, a sawzall and a big enough hammer! My vote is definitely for the Y. I’m running a .40 over 292. I love it.
    mgtstumpy and kidcampbell71 like this.
  6. warbird1
    warbird1
    Go for the Y-block; it may be a little more work but you'll be happier in the long run if it's what you truly want. Just follow the A.B.C.'s of hot rodding...
    mgtstumpy and DesertRat#1 like this.
  7. DesertRat#1
    DesertRat#1
    My goal is to end up with a build like someone would do in southern California in the late 50's or early 60's. I know what that is. Fabrication is fabrication and it is what have done for a living so I will auger on for the time being. I don't want another clone magazine build. I am perfectly happy when I get what I want when I want it:)
    31hotrodguy, AldeanFan and warbird1 like this.
  8. RichFox
    RichFox
    When I bought my 32 it had been running a Y block. The PO had cut the tubular engine mount crossmember from a donater car and welded it to the 32 frame. Another guy did the same thing when he put a 292 in a 53 Merc. Don't know why more people don't do that.
  9. warbird1
    warbird1
    I did that when I put a Y-block in a '35 Chev. sedan back in the day; never got it finished but surprisingly it fit quite well.
  10. thirtytwo
    thirtytwo
    That era more often then not would of had a SBC ....and they fit perfect, same size as a Flathead , with a hurst mount you could bolt in a sbc and next weekend bolt a flattie back in it , if you wanted...and nobody would ever know , I know a lot of early ford guys who prefer this motor swap as it means your not molesting the car usally
    Blues4U and DesertRat#1 like this.
  11. 31hotrodguy
    31hotrodguy
    As a die hard Chevy guy drives a 327 as his daily driver I say go for the Y block. We have enough 327’s in hot rods. Plus the Y block just looks good!
    DesertRat#1 likes this.
  12. Boneyard51
    Boneyard51
    Dine at the Y!
    Bones
    Blues4U and 31hotrodguy like this.
  13. pkhammer
    pkhammer
    Definitely go with the y-block. I know it's cheaper and easier to follow the crowd into brand X belly-****on land but the y-block would be so much cooler.
    warbird1, mgtstumpy and DesertRat#1 like this.
  14. 63galaxie406
    63galaxie406
    Check out April 1961-July 1961 Rod and Custom Magazine. Even shows how to make motor mounts and firewall mods.
  15. Not my car, wish it were, but sure looks good in there. 48360735_2061999563880264_4495811614712266752_o.jpg 48364771_2061999720546915_7025687754537172992_n.jpg 48376457_2061999937213560_149711556232347648_n.jpg
  16. DesertRat#1
    DesertRat#1
    I like that a lot! I have both the Y-Block referenced in my OP and also have picked up an early 5 liter. I will look at both but even after reading the "build a Y-Block" book and knowing the expense will be greater I am still leaning toward the Y-Block for my build. I need to fine a machinist knowledgeable about these motors.
    czuch, Bandit Billy and mctim64 like this.
  17. I'm sure there is someone out there that knows how to build them. :)
    OahuEli, warbird1, czuch and 4 others like this.
  18. Bandit Billy
    Bandit Billy
    Your truck has a big engine bay, fill it proudly. That Y block may be more work but worth it in my opinion.
    mgtstumpy likes this.
  19. typo41
    typo41
    Come-on Tim,,, You know some body that can help,,,,,,,
    OahuEli likes this.
  20. typo41
    typo41
    With that said, I believe there was a thread here about someone putting a Y Block in a 36-40 ch***is
  21. fordpatina
    fordpatina
    I had a 1940 lincoln zephyr 3 window coupe with a 312 T bird
    15 years ago
  22. sunbeam
    sunbeam
    Y block and FEs frame mounts are almost the same so speedways tube FE cross member might be the answer.
  23. Bill Nabors
    Bill Nabors
    I had a 55 F 100 with a 59 292 the had 312 T bird heads, intake and isky supercharger cam with a holly 600 cam, holly 600 cam four barrel.
    It had F600 ramhorm exhust, turbos and a mallory 4 lobe distrubtor. It ran fine. You couldn’t ask for a better motor. I commuted between Reno and Carson City for years. Got good gas mileage and I figured I put 160,000 miles on it with
    Cam II 20-50 oil. (Harley 20-50).
    I started with a 3 speed and went to a 4 speed. I could haul *** or pull a car trailer. I wish I still had it.
    OahuEli and DesertRat#1 like this.
  24. Bruce Lancaster
    Bruce Lancaster
    Moriarity likes this.
  25. DesertRat#1
    DesertRat#1
    Today I took advantage of the warm weather and degreased and pressure washed my 64 truck 292 y-block for my 40 build. I have to build a cradle for it and get it home. 291-2.jpg 292-1.jpg 292-3.jpg
    mctim64 likes this.
  26. Roothawg
    Roothawg
    Do a search on here for Elpolacko's 37 Ford pickup build. He had a fellow hamber that wanted a Y block in a survivor truck he found. It was a lot of work, but really neat when he got finished. I'll look for the link tonight when I get home.
    mctim64 likes this.
  27. DesertRat#1
    DesertRat#1
    Yeah, I ordered the April and July Rod & Custom last night, should be here by the first week of January.
    Also bought a Millermatic 211 with all options including spool gun today. Should do anything I want to do.
  28. 6sally6
    6sally6
    I vote for the Ford too!
    My only question is...why the fascination with the old Y block? I 'm kinda new to this site and I know its a lot about the old stuff and retro rods...and I like that but......
    SBF engines are sooo much more plentiful/cheaper/more parts available/more powerful.....on and on.
    Just ask'in.....not wanting a sh-- storm thrown my way!
    6sally6
  29. DesertRat#1
    DesertRat#1
    Because the y block build is seriously cool. I do have an early 5 liter ford in reserve in case my y block is not usable.
  30. Roothawg
    Roothawg
