Technical Another cracked flathead question
Discussion in 'The Hokey Ass Message Board' started by Willynichols00, Dec 17, 2018.
  1. Willynichols00
    Willynichols00
    image.jpg image.jpg I know the cracks around the water jacket to head bolts ain't a big deal, but what about theses?
  2. flatford39
    flatford39
    It doesn't appear you have any making there way to valve seats or cylinders so I would think you are good to go.
    warhorseracing likes this.
  3. Willynichols00
    Willynichols00
    No there none between the cylinders and valves just the usually water jackets to head bolts and theses two places.
  4. FrozenMerc
    FrozenMerc
    I don't think you have anything to worry about. Proceed with the rebuild.
  5. 51504bat
    51504bat
    Old timers would say that those cracks came with a Ford part number. Like the previously posted, no worries.
    sidevalve8ba, deucemac and Hotrodmyk like this.
  6. Willynichols00
    Willynichols00
    I didn't think they were a issue, just needed re***ured. Any need to helicoil them or just use studs and sealer?
  7. ebfabman
    ebfabman
    Most "no cracks" flat heads will have those cracks. It's like a car with "no rust" just means most of the panels are still there. Edit, don't use a tap to clean the threads and don't over torque.
    sidevalve8ba and Casey Riley like this.
  8. flatford39
    flatford39
    Just use a really good sealer on the studs so it doesn't weep out the head.
    sidevalve8ba likes this.
  9. Willynichols00
    Willynichols00
  10. sunbeam
    sunbeam
    I thought those were factory.
    Budget36 likes this.
  11. dan griffin
    dan griffin
    Is there any other kind ?
  12. 51504bat
    51504bat
    Used number 2 Permatex per my machinist's recommendation. No leaks but I'm sure others will have other suggestions for a sealer.
  13. willys36
    willys36
    Early Hemis rarely crack.
    Beanscoot likes this.
