Projects '33 5w Build Thread
Discussion in 'The Hokey Ass Message Board' started by CTaulbert, Oct 27, 2018.
  1. Can't believe that grill is in such nice shape!
    CTaulbert and loudbang like this.
  2. nunattax
    nunattax
  3. classiccarjack
    classiccarjack
    What's the progress on the 365? Or did I miss that part?
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
  4. CTaulbert
    CTaulbert
    from Detroit
    It's just in mock up form for a while. I may be looking for a 390, for the obvious displacement, but also for the full flow filter setup.
    brEad, loudbang and classiccarjack like this.
  5. CTaulbert
    CTaulbert
    from Detroit
    I've been pretty busy lately, so I haven't had a ton of time to work on the car. I'm still plugging away on the chop, mainly on the drivers side before moving over to the p***enger side.
    When the a-pillars laid back, with a section removed from the chop, a gap opened up between the door top and pillar. In addition, the details/stampings on the jamb side of the door inner no longer lined up, so everything needed some m***aging to look factory.
    I wanted to cleanly fix this, and I decided to remove the outer skin in the area. This allowed me to get access for reshaping the jamb side of the inner, and also allowed a clean way to extended the inner:
    Once that was welded and finished, I made a new outer skin from 18 gauge, and rough cut it to fit the new door opening. The new outer was welded and finished, and then I ground both the inner and outer to a consistent door gap. From there, I made a new hem for the back side based on the new shape. I clamped it in place, and welded the edge of the door to formally join it:
    With the door edge welded, I took a file to the edge to dress the welds, and cut a consistent radius on the edge of the door to match the factory profile:
    47358952_10100134950455539_3487296166251462656_n.jpg 47321087_10100134950505439_2843526623515377664_n.jpg
  6. classiccarjack
    classiccarjack
    Very nicely done!
  7. qzjrd5
    qzjrd5
    from Troy, MI
    Just saw this thread. Dude, I think you qualify as a sheetmetal guy now. Looks wonderful.
    catdad49, CTaulbert and loudbang like this.
  8. Damn Son!
  9. loudbang
    Going to be one more of your HIGH QUALITY builds. :)
  10. brady1929
    brady1929
    Very nice.
  11. greaser
    greaser
    Looks like Henry did it. Have you been taking lessons from Flop?
    CTaulbert, brady1929 and loudbang like this.
  12. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    The chop turned out awesome!!
    loudbang and CTaulbert like this.
  13. brEad
    brEad
    X2 - Looks fantastic!
  14. As beautiful as your roadster is (and I have only seen pictures), you are on your way to another killer ride. Beautiful work from a "non" metal man? It looks pretty professional to me.
  15. dirty old man
    dirty old man
    Wow! Some fine work going on here for sure.
    Crusty Chevy and CTaulbert like this.
  16. AHotRod
    AHotRod
    Really sweet Hot Rod you have Cory
  17. catdad49
    catdad49
    Looking Fine! Your sheet metal skills are progressing Nicely. ( That's an understatement).
  18. terry k
    terry k
    from toledo oh
    For a guy who" doesn't do metal work", you make it look easy and well done.
    CTaulbert, loudbang and kidcampbell71 like this.
  19. terry k
    terry k
    from toledo oh
    Any photos of how they did the A pillars to lay that area back to the roof. Usually you see the cowl being layed back. I like the looks of yours better. More smooth.
  20. HEMI32
    HEMI32
    Cory @CTaulbert -
    I've been following your '33 Coupe build on Facebook / Instagram, but am glad I stumbled upon it here on the H.A.M.B. ... a build thread is so much more comprehensive than looking at pics on FB/IG!
    Your '33 is gonna be yet another *****in' Hot Rod!
    Please keep us updated on your progress.
  21. HEMI32
    HEMI32
    Cory rolled it outside on Sunday (December 16th 2018) for a "look-see" from afar:
    brEad, Tjompen, LOWDUG37 and 14 others like this.
  22. pigfluxer
    pigfluxer
    He is killing another one, the guy has the eye.
    CTaulbert, flatheadpete and loudbang like this.
  23. x77matt
    x77matt
    Perfect dude.
  24. UNCLECHET
    UNCLECHET
  25. 383deuce
    383deuce
    Sure looks good to me Cory.....I* like it!
    CTaulbert likes this.
  26. CTaulbert
    CTaulbert
    from Detroit
    Thanks guys - still chipping away at the finish work for the chop. Fortunately, I'm off for a couple weeks from work, so I should get some more time with it.
    HEMI32 and loudbang like this.
  27. CTaulbert
    CTaulbert
    from Detroit
    We just relieved the back side of the a-pillars enough for them to lay back to the header. Cuts across the whole cowl are usually unnecessary.
    brEad, Shadow Creek and loudbang like this.
  28. terry k
    terry k
    from toledo oh
    I chopped mine by cutting and sectioning the roof. Now, I wish I could lay the windshield back just a little the way you did it. Great work.
  29. 57tailgater
    57tailgater
    from Georgia
    Thank you for sharing ANOTHER one of your awesome builds!!!
  30. rustednutz
    rustednutz
    from tulsa, ok
    You definitely nailed it with that chop! The epitome of a bad *** hot rod!!!!
