Technical Holly/Ford 94 question
Discussion in 'The Hokey Ass Message Board' started by patzfab, Dec 19, 2018.
  1. patzfab
    patzfab
    from Canada
    1 is as per this throat and air jets 17C2ACDF-590C-42DC-8580-23901FED6FFF.jpeg
    3 are like this,.
    I have 4 -94’s, 3 are identical in the throat, 1 is different, see pics.
    Anyone know if this is OK, or should I change the one
  2. flatjack
    flatjack
    The top one is a good candidate for a secondary carb in a multi carb system because the idle circuits tend to be a little on the lean side.
  3. 30tudor
    30tudor
    what are the markings on the sides and ends?
  4. patzfab
    patzfab
    from Canada
    2 have no markings, been polished off! 1 has a Ford in an oval, (that’s the top one) and one has a Ford in a large square.i think they all have 94 on them
  5. patzfab
    patzfab
    from Canada
    The front LH carb is the different one
    These are going on a Man-A-Fre manifold, they are all primary carbs.
  6. alchemy
    alchemy
    Here's a little education. None of them are Strombergs. They are either Chandler Groves, Holley, or Ford.
    Dirty Dug, oj, patzfab and 2 others like this.
  7. 1940Coupe
    1940Coupe
    Holley 94’s
  8. NewToMeT
    NewToMeT
    Def not an expert, but recently adopted my fathers Model T which have 4 Holley 94/2100s so have been doing a ton of research as they needed a rebuild. The attached may help in identification. I understand from my reading that even withing the Holley 94 models there were a few variations.
  9. AngleDrive
    AngleDrive
    from Florida
    Interesting little screws coming out of the access plugs for the jets. I'd take the top of one carb and look-see what they do. The nozzles in the top pic are later design. Can't remember the reason for the change.
  10. flatjack
    flatjack
    They were for a leaner idle. Look at the 3 air bleed holes whereas the other picture shows only one bleed.
  11. brsturges
    brsturges
    from Miami, FL
    Those look like adjustable main jets to me.
  12. AngleDrive
    AngleDrive
    from Florida
    That is what I thought, seems like they might be needles to adjust main jet flow.
  13. patzfab
    patzfab
    from Canada
    Yes, they have adjustable mains. Can the odd carb be retrofitted with the same nozzles as the other 3?
  14. AngleDrive
    AngleDrive
    from Florida
    Yes, need different hold down, bleed screws, idle jets and there is a left and right.
    patzfab likes this.
