My shoebox's gas tank is full of rust particals..Carberater keep on over flowing with rust particals..so i dropped the gas tank and man is not pretty inside..Any one cleaned there gas tanks at home or a shop in the los anges area clean gas tanks for a reasonable price..or any one local have a good tank for a shoebox (1950) for sale..i also need the hose that connects the gas tank to the neck filler and the sending unit ..any where i can buy this new?any help will be greatly appreciated..
drain it, rinse it out, dry it out, put 3 feet of chain in it, shake it like crazy, and dump it out. repeat as needed. The chain will knock all the rust loose. Then, when you reinstall it, put a clear plastic fuel filter(NOT a gl*** one) in an easily accessible location so you can change it when it gets clogged.
I've used a handfull of roofing nail and about a half a gallon of kerosene. Put the nails in the tank add kerosene and shake then shake somemore, might take two people to really agitate. Then remove the nails, not hard, rince and shake again with just kerosene. It worked well for me.
I just took mine to pacific radiator on colorado blvd.They are next to the glendale galleria.I had them clean and boil it, and paint it.It came out killer for 130.00.Mac's antique auto parts has all the parts you need for your 50.The hose is about 5 bucks and the sending unit is 30.00.
for the sending unit and the gas neck piece try c & g early ford in escondido i belive.760-740-2400 i got that rubber piece for my 51 and sending unit there.
Another variation: Drop it, drain it, flush it good with a water hose, put three gallons of muratic acid in it & spend a 1/2 day tilting it side to side & top & bottom. Drain it, flush with a water hose for an hour or so, once it dries dump a quart can of tank sealer in it. It won't give you any more trouble. JH
Use the Eastwood kit for about $50......it will do the complete job and Presto Change-o............no more problems......at least for me since I did it a couple of years ago......good luck.... Brucie
I've had problems with the Eastwood stuff. Cleaned the tank with muriatic acid, shook it with nuts in it, did what I was supposed to do, but still had stuff peeling off the sides (the sealer) of the tank and clogging the fuel filter. Finally heeded an article in a mag about GasTankRenu. Now I've done six tanks that way and have had no problem with any. Jaguar I did seven-eight years ago is still fine. Car sits a LOT, no problems. Cost was between $175 and $200, but since all I did was onbolt and carry it over, I saved on aggravation (ever tried shaking a 26 gallon tank from a Cadillac?? Not easy). Guaranteed for life. Impervious to all but nitro (don't use on a Top Fueler...). Available at many radiator shops. Cosmo
Replace Tank And Quit Screwin Around. Check "tanks" They Have Poly Unrustables It Will Be At Night On A Lonely Road That It Will Haunt You. Be Done And Drive It Fuel Is Too Expensive To Be Spillin It All Over In- Out Don't Put That ****py Gas In The Mower! Do Run A See Thru Filter Tho Good Luck Paperdog
VonMoldy is the Winner! After cleaning it out, use POR-15 gas tank sealer. It is the best there is! Its about $25. If tou are rich, you can follow those other suggestions. and regret it. Even a brand new steel tank should be sealed with POR. I am sure I dont want a plastic tank!
You need to try & figure on just how bad the rust is inside the tank. I yanked the tank out of my latest distraction (non-HAMB material Toyota on 35's) & cleaned the tank by dropping a few handfuls of pea gravel in it & shaking it around real good. Then I reinstalled the tank & put fuel in it. Too bad I knocked a few good sized rust flakes off in there & created several pinholes for the fuel to escape from. If your tank is scaled up w/ rust real bad inside, I'd look for a replacement before I went thru the trouble to clean it out.
I'd say pull it and powerwash it with the drain plug open and just keep blasting it until the water comes out clean. Of course you can do that with the tank still mounted but you can't move the powerwasher around enough to blast a larger area inside the tank. The chain and roofing nails ideas are also awesome. I'd almost suggest some media blasting but man it would be hell to make sure every single bit of it was out of there so me personally, I'd just use my powerwasher. Or you can take it to a car wash but that sure would take a lotta quarters. Then change fuel filters every 10 or so miles for a few times.
I'd replace it. Why chance a breakdown. How many carb kits are you gonna go through when it starts again. You're off on a cruise with friends and they have to pull over with ya. Worried about the plastic tank? Paint it. Mix up a bare steel lookin color, wash the new tank really well with soap and water 1st then some good solvent. Spray it with Bulldog adhesion promoter (or similar) then paint it. Problem solved forever at that point.
I just went to the carwash and sprayed mine for about 10 minutes until everything seemed to come out clean. This got most of the loose rust. Added a see thru filter and had to change it after about 700 miles. Now have about 500 miles on the 2nd filter and it still looks good. I used nuts on a cushman scooter tank and they worked great also. It just too hard to handle a large tank this way. The muric acid sounds good also. Just hope you don't end up with pinholes, then you have to use a sealer for sure.
Dude..pull i t out.. and throw it away.. its ****in 56 years old for christs sakes.. Mustang tank. Cheap, easy and BRAND FREAKIN NEW. check eBay for em.. http://cgi.ebay.com/ebaymotors/1969...ewItemQQcategoryZ34198QQitemZ4639224843QQrdZ1 150, plus it gives you more room underneath the trunk, if your car is super low.. you can shave that ugly *** gas door, and fill er up in the trunk... Good luck.. Gable
I read somewhere (probably here) about someone putting chain or nuts&bolts in one and st****** it to a tractor wheel and letting the tractor idle in low gear to agitate. I thought it was prety ingenious. I just got done cleaning mine with plain gas and me agitating, the clear filter is still clear after 300mi, where it was clogging after 2-300 mi before. I suggest in the following order 1) Free methods above 2) New tank if available 3) Comercial sealers if new tank not available. Brett
since the car is driving, my super secret method is to put a powerful magnet near the outlet, then keep driving. this has been my proven method on some of my stock model A's-
i used shotgun shell shot in my amx...it was heavy as heck, but a 25 pound sack of it and a little gas will work real good with no chance of knockin holes in it....buy beer and bring a freind..takes awhile!!!
That was it! I was real close to asking my neighbor with a tractor to give me a hand with mine , but I think I got most of it by hand. Brett
i took mine to the radiator shop on nordoff just west of reseda bl 120.00 super clean and then he tested it for leaks it doesent matter how old it is mine sat for 40 years and was very bad vola its like new now.......
I know if it was a Chevy you could just buy a new tank for $200. I'd be surprised if no one is making a shoebox Ford tank in the same price range. Save the hard work that costs the same money for cars like Packards or Studebakers or anything else that you can't just go buy an off the shelf tank for.
