home made tools and equipment...
Discussion in 'The Hokey Ass Message Board' started by kustombuilder, Jan 16, 2008.
  1. DDDenny
    :rolleyes:
    By the way, 65 Malibu SS uses the same basic cap except the accent color is red instead of black. But you knew that!
    Bandit Billy likes this.
  2. dirt t
    dirt t
    Neat stuff thanks for sharing.
  3. RICH B
    RICH B
    Ran out of room on my air tool hanger; realized the old wall phone didn't need access anymore, so I added a top level. Chinese mystery metal ******s welded well of course.
  4. whtbaron
    whtbaron
    from manitoba
    Oh, I like that. I'm totally going to steal that one...do you think it would be easier to unhook them if each outlet was on a loop that let you swing it forward? Or would it be better to be really solid?
  5. fiftyv8
    fiftyv8
    from CO & WA
    My version of a traditional bead roller using part of a banjo diff as the stand and mostly junk from my stash to make the rest of it.
    It is almost finished...
  6. chiro
    chiro
    ^^^ I like that. More detailed pictures or plans would be great.
    Andy
    loudbang and fiftyv8 like this.
  7. Here's the tool I build to remove the knock-offs from the Roadster. knock off tool.jpg
  8. rwrj
    rwrj
    from SW Ga
    This is pretty simple compared to most of the stuff on here. Early model A wrist pins are held in by a c clip in the middle of the rod that rides in a groove in the middle of the pin. Here one is:
    They tap out easy, but getting them back in is a trick. The clip compresses enough that the end of the pin just ****s up against it, can't tap or press it past without breaking something. I made this little tapered slug. The big end is just a thousandth or so under the pin size, small end has a nice, rounded chamfer. Just get it started and let the pin push it through. Worked fine.
    whtbaron, brEad, David Gersic and 7 others like this.
  9. RICH B
    RICH B
    If you have room for all your air tools hanging downward; there is a formed angle with slots that the male coupler slides into that actually work better. My kid has one about four feet long on the wall behind his brake. This giz started with the four hanging down years ago, then I added the four vertical positions, and finally the new section last week or so.
    whtbaron and loudbang like this.
  10. fiftyv8
    fiftyv8
    from CO & WA
    I might do a short thread on the bead roller in the new year, when it is done.
    No plans, just made from what I had...
    Before I started constructing my homemade bead roller, I scanned several sites and looked at numerous pictures on the internet which eventually had my head spinning.
    I figured a bead roller could be a handy piece of equipment to ***ist with the making of patch panels and floor repairs etc.
    I made a check list of the features I thought might be useful which included, that it be;
    Powered
    On a stand
    Relatively easy to move
    Have a throat of at least 24 inches
    Have a side offset adjustment
    A quick release which holds existing settings
    Run 1 inch shafts which step down to 7/8" for dies
    An adjustable guide
    Made mostly from stuff that I have in my stash
    Run standard 2 inch dies
    Run keyways on all shafts, even if not used
    alanp561, brEad and loudbang like this.
  11. flynbrian48
    flynbrian48
    I made this ugly but pretty functional brake. It inspired me to clean up the bench, and then the rest of the shop. Winning... 48372243_10218718239329748_7025310098062835712_n.jpg 48386074_10218725426229416_4239213230313963520_n.jpg
  12. dodgedifferent2
    dodgedifferent2
    Home built drill vise using the screw from hospital bed (acme thread). The extra bar goes against the column since the vise is never bolted down. The gear drive does not give like the weak pulleys did. 20181227_124221.jpg
  13. dodgedifferent2
    dodgedifferent2
    Tube and rod ring roller. Plan to hook up to hydraulic motor along with the slip roll. 20181227_124200.jpg
    Old propane tank used to fill with compressed air to haul air to a small tire or unplug drains. 20181227_124251.jpg
    Manual tire changer mounted into floor anchor.
    Used to break the bead with jack all jack. Then mounted and a tool (not pictured) is used to spin tire off or on.
    Removal side.
    Home built break
    j-jock, tb33anda3rd, loudbang and 3 others like this.
  14. dodgedifferent2
    dodgedifferent2
    Air blast tank used to blow heavy truck tires on to rims. Fill tank with compressed air 120psi. Cram into bead of tire and crack the tap to give a blast of air to pop tire on to bead. 20181227_124355.jpg
    Home built propane torch cart to roll across gravel and move to where needed around farm.
    Tool benches. Built at home instead of the flimsy tin tool boxes.
    Old oil tank made into fireplace to heat shop up. Garbage and wood used to heat shop
    Built rollin chairs. Seats came from a mustang II
    State of the art wall mount tools.
    Has been there since 1983. Metric one side. Imperial the other 20181227_124628.jpg
    tb33anda3rd, enloe, loudbang and 3 others like this.
  15. dodgedifferent2
    dodgedifferent2
    Screenshot_20181227-134007_Chrome.jpg Bead roller started out as a princess auto model.
    loudbang and whtbaron like this.
  16. dodgedifferent2
    dodgedifferent2
    Spare d2 tool steel made into english wheel anvils. Heat treated to 58 Rockwell. These should never wear out. 20181214_144314.jpg
  17. fiftyv8
    fiftyv8
    from CO & WA
    I have a piece of 1 inch plate that I use for a work surface from time to time.
    Due to space limitations I don't have it set up all the time and so need to move it.
    I used to use two pairs of big vice grips and a rod between them as a lifting point, but one day with too much time on my hands I decided to go fancy.
    I copied this from a PlateLiftClamp (3).jpg PlateLiftClamp (2).jpg PlateLiftClamp (1).jpg PlateLiftClamp (2).jpg PlateLiftClamp (3).jpg YouTube site and it works a treat.
    tb33anda3rd, loudbang, RICH B and 2 others like this.
  18. Mart
    Mart
    I like what you've been doing there, Dodge.
    loudbang and dodgedifferent2 like this.
  19. Nostrebor
    Nostrebor
    Mr. Dodge must have bought a drum of blue paint at an auction!;)
  20. dodgedifferent2
    dodgedifferent2
    Blue. It defines what was homebuilt in the home shop
    tb33anda3rd and loudbang like this.
  21. RMR&C
    RMR&C
    from NW Montana
    I built some heavy duty wheel dollies to move large vehicles around the shop. Just some s**** steel and some casters rated at 500 lbs each. Good excuse to use the old stick welder!
  22. bct
    bct
    I like the stick welder for stuff like this too . makes it more fun. no need to waste argon.
    RMR&C and loudbang like this.
  23. bigheadbaxter
    bigheadbaxter
    My planishing hammer. 1”-14 all-
    thread and a variety of dies from an air hammer. And big ball bearings welded to the 1”-14 nuts work well
    dadz34, j-jock, Corsa and 12 others like this.
  24. jaw22w
    jaw22w
    from Indiana
    This provides the fuel for the shop wood stove, so I think it is kinda on topic. I built the splitter almost 40 years ago. Yesterday I finished up putting a lift arm on the splitter. Those big diameter logs are at least three times heavier than they were 40 years ago. Now I can split the big stuff by myself. Just roll 'em up on the lift arm and pull the lever. It uses a 2" x 8" stroke cylinder plumbed with 1/4" lines. It is powered by the splitter pump using two open center control valves. Not an original idea, but I am a good copier.
    alanp561, whtbaron, brEad and 5 others like this.
  25. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    This is another simple one. Screwdriver to remove and tighten GM light switch nut.
    The blade is a wall section from a piece of 1" square tube. The handle is a genuine Snap-on!
    My Grandson was the hand model :D
  26. vtx1800
    vtx1800
    I am always amazed as I scan through this thread, lots of creative genius! A few days ago I got the latest copy of Hemmings "Cl***ic Cars" and they featured several pages of neat garages. Polished floors, benches you could eat off of, auto related decorations, most looked like museum displays. I wondered if anybody actually worked on their car in these "decorator" garages. I like what I see in this thread, your shops are messy because you are actually doing something, at least that's the excuse when I show people my messy shop:)
    Boneyard51, whtbaron, brEad and 4 others like this.
  27. '51 Norm
    '51 Norm
    from colorado
    I cleaned up my shop because I had a visitor coming by. It'll be messy again tomorrow.
  28. whtbaron
    whtbaron
    from manitoba
    Blue is good... just check my avator. I needed a big Easy Out to remove a piece of broken 1" tubing, but my biggest one was 5/8" . I grabbed a chunk of good quality 7/8" square steel, the 4 1/2" grinder and the die grinder with a 2" disc and this is what I came up with. I probably should have ground it further up the shank and made a shallower gripping area to catch more steel. I debated between a fluted style and the threaded version, so it got one flute up the middle of each side.
  29. chrisp
    chrisp
    Partially home made tool, I took a hospital bed and modified it to be able to work under cars, I lift it with 2 floor jack or the 2 post lift.
    I tried to make one with a hydraulic jack but I just bent the frame... I added the front and rear legs for safety.
  30. BJR
    BJR
    That doesn't look strong enough that I would want to get under it with a car body on it.:eek:
