Unusual engine photos
Discussion in 'Off Topic Hot Rods & Customs' started by William Thompson, Sep 28, 2018.
  1. FrozenMerc
    FrozenMerc
    ***mins 1931 Indy Car: Packard Ch***is, Completed the entire race on one tank of fuel. The lineage to the 4BT engine is obvious.
    ***mins 1950 Indy Entry.
    ***mins 1952 entry was even more unique, employing a laydown inline 6 engine. It took complete advantage of the rules at the time that allowed a diesel to be up to 401 ci, and no limits on boost, where as gas engines were limited to 183 ci. The ***mins Special set pole by more then 4 mph over the 2nd place V12 powered Ferrari's. It was leading into the late stages of the race when the turbo inlet became fouled and plugged with rubber debris and starved the motor of air.
  2. willys36
    willys36
    Hot off the press, here is a photo of the next generation blower that the top fuel and Funny guys are prepping for next NHRA season. 68,789-71.
    Stebo27, VANDENPLAS, loudbang and 4 others like this.
  3. 40 Olds
    40 Olds
    Stebo27, wicarnut, loner1 and 8 others like this.
  4. foolthrottle
    foolthrottle
    Alpha
    Stebo27, Speedwrench and Deuces like this.
  5. loudbang
    1910 International Harvester
    Curtiss OX-5 Hemi cross-flow head engine built in 1918
    Stebo27, 1947knuck, loner1 and 4 others like this.
  6. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I did not know that link-belt timing chains dated back to 1910.
    Also, its interesting that Curtis used one pushrod ***embly to actuate both valves. And maybe only one cam lobe?
    I LEARNED SOMETHING TODAY!
    Deuces and loudbang like this.
  7. 1-SHOT
    1-SHOT
    from Denton
    The international has adjustable cam timeing
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Speaking of using one cam lobe to actuate both valves, we had a Reo lawnmower that did just that.
    knucklenutz, loudbang and Deuces like this.
  9. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Wasn't that a Continental engine that drove the mower off the cam?
    I think Dean Lowe could probably tell a lot about those.
  10. The pushrods were arranged one inside the other, the exhaust valve rod being on the inside and the intake valve rod a tube around it
    ottoman and loudbang like this.
  11. saltflats
    saltflats
    from Missouri
    And it looks like the intake push rod pulls down on the valve.
  12. Dan Timberlake
    Dan Timberlake
  13. 1-SHOT
    1-SHOT
    from Denton
    Actually that would be my 204.5 or my 174
    gimpyshotrods, loudbang and saltflats like this.
  14. Deuces
    Deuces
    That's pretty cool.... I wonder if it ever ran.... Probably not...
  15. 1-SHOT
    1-SHOT
    from Denton
    They tried cut in half small blocks in midgets
  16. Speedwrench
    Speedwrench
    There were several different V-4's built for midgets and Ron Hottel of SESCO built a four holer that used a bank of cylinders from a 283 block that was the engine of choice for several years in the seventies.
  17. sidevalve8ba
    sidevalve8ba
    To say that this is a rare conversion would probably be the understatement of the year.
  18. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That is what I figured at first - sort of a desmodromic effect. But upon closer scrutiny I think there may be a secondary rocker gizmo down near the cam bore that turns the pushrod motion around, while still using the same cam lobe. Look closely and see if that is the case, no?
  19. Never cared much for Y blocks, but that Weslake conversion is a thing of beauty.
  20. Fordors
    Fordors
    Harry Weslake perfected the hemispherical combustion chamber?
    Hmmm, interesting. I would think the Smith Collection would have a more astute research team than that.
    Boneyard51, Deuces and loudbang like this.
  21. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    As with many engineering features refinements come with age. I doubt the hemi was "perfect" after Weslake was done. And the definition of perfect has to be taken in context. Perfect for max volumetric efficiency? Perfect for Maximum HP? Perfect for emissions?
    Have you looked at a modern Mopar "hemi" head? Its far from being a dome with valves. More like a hemi in name only.
    Deuces and sidevalve8ba like this.
  22. loudbang
    Ford Cosworth
    Flatty with Stephens OHV Hemi Heads
    Stebo27, 1947knuck, loner1 and 3 others like this.
  23. sidevalve8ba
    sidevalve8ba
    Ford flathead V8 prototype from 1928.
    Stebo27, j-jock, 1947knuck and 8 others like this.
  24. loudbang
    GM X8 2-stroke engine. This was an experimental engine for an economy car that was never used, each head has two pistons, one for intake and one for exhaust. It also has a roots style supercharger
    Gallivan DOHC conversion
    Stebo27, 40two, 1947knuck and 7 others like this.
  25. donno
    donno
    Never saw the Soviet version, but I did ride behind a 5 cyl . Kennerer in a PT-19. Real "putt-putt).
  26. donno
    donno
    Gonna stuff one of those in a Friends Flat head powered '40 coupe. Just waiting on the adapter from J.C. Whitney, it's on back order.
    VANDENPLAS, loudbang and Deuces like this.
  27. Deuces
    Deuces
  28. Boneyard51
    Boneyard51
    Old Harry might have perfected the Hemi, but he sure didn’t invent it. About 15 years ago my Dad and I went to the largest antique farm tractor auction ever, in Montana. Not to buy, just to look.
    I found a 1904 Farm tractor that had: Hemi heads, roller rockers, Roller lifters,dual carburetors, rack and pinion steering, posi-track, and a blower on it! My Dad laughed at my amazement, he told me that “ hot rodders” have not thought of anything new! They just applied to different things and in different ways.
    Sometimes you just got to see it for yourself!
    Bones
  29. Bearcat_V8
    Bearcat_V8
    from Dexter, MI
    a couple from the Henry Ford Museum in Dearborn...
    Stebo27, mgtstumpy, 1947knuck and 5 others like this.
  30. Bearcat_V8
    Bearcat_V8
    from Dexter, MI
