Projects Smallest transmission ever?
Discussion in 'The Hokey Ass Message Board' started by slim tempo, Dec 8, 2018.
  1. slim tempo
    slim tempo
  2. deathrowdave
    deathrowdave
    from NKy
    That’s a little fellow ! I had one years ago from a Crosley that I used in mini pulling tractor , it probably was 1/2 that size . Looked near the same no tail shaft .
  3. tom in nh
    tom in nh
    I like it.
    Could use it to shift gears on a swap meet shopping cart, as it looks light enough.
    More details please.
  4. adam401
    adam401
    You can keep an extra in your glove box just in case. Nice.
    loudbang, Truck64, Bleach and 3 others like this.
  5. blowby
    blowby
    from Nicasio Ca
    Won't need a ****** jack for that one.
  6. sevenhills1952
    sevenhills1952
    Rambler!
    60 years old still going strong!
    What wrong with it?
    Sent from my SM-S320VL using Tapatalk
  7. slim tempo
    slim tempo
    loudbang and Deuces like this.
  8. slim tempo
    slim tempo
    I found that 1960 ****** from a Rambler American and plan on replacing the input shaft with my present ****** as the American is 3/4 to long in the nose and too wide in diameter.
  9. slim tempo
    slim tempo
    Removed the countershaft this morning and fished these out of the transmission case. 003.JPG
  10. Frankie47
    Frankie47
    from omaha ne.
  11. rudestude
    rudestude
    This one I pulled from my 50 Studebaker Champion Starlight Coupe....worked great ..it is small... I also have a over drive unit ...it's a little crusty..but I think it would clean up...the trans worked great but it's a little dirty.... I don't need it ...if your in the area..Oregon ...come by and get it .....it's yours....Ho...Ho...Freakin ....Ho...and back to Rambling you go.... IMG_20181222_124759~2.jpeg IMG_20181222_124824~2.jpeg IMG_20181222_124840_1~2.jpeg IMG_20181222_124901~2.jpeg IMG_20181222_124942~2.jpeg
    Sent from my QTASUN1 using The H.A.M.B. mobile app
    Tim, dan31, chevy57dude and 4 others like this.
  12. vtwhead
    vtwhead
    wow, that is one nasty looking ******! Northwest Transmission in Ohio may have parts if you need any.
  13. slim tempo
    slim tempo
    Got my small parts kit today in the mail. Input and output bearings are on the way.
  14. slim tempo
    slim tempo
    When I examined the parts that came out of the countershaft I noticed there were no washers holding the needle roller bearings in. Could that be the reason it self destructed?
  15. Deuces
    Deuces
  16. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Deuces,
    Where did you find that?
    I want one, too!
  17. BamaMav
    BamaMav
    from Berry, AL
    It was behind a small block. :p:D
  18. tomic
    tomic
    HA! when I saw this thread, before I even read it, in the list I immediately thought "T96"! (then I saw the first pic with those unmistakable door handles...) I've had more than my share of them. behind flathead sixes "you don't hear many complaints" but even then few compliments. the Rambler overhead 6, all 195.6 cubic inches of terror, break them.
    I don't even mind the no synchro first, I'm used to that. but it's a weak piece of junk.
    the only good thing about it is that the T14 three speed (AMC had a p***enger car version, with side shifter) has the same clutch shaft, spline, length, and at least two bolts the same (often all four). different length. anyone wants a nicely rebuilt T14 with 5000 miles on it lemme know.
    Modern Drivelines makes an adapter to bolt a T5 to a T96 bell. I'm driving on one. it's great.
  19. Deuces
    Deuces
    Try TDR innovations.... Tell'em Guido sent ya!... :cool:
    Thor1 and loudbang like this.
  20. gimpyshotrods
    gimpyshotrods
    Itty bitty box, big long output shaft.
    Shown next to what replaced it.
    chevy57dude and loudbang like this.
  21. dan c
    dan c
    that even looks smaller than the one in my gen-1 econoline!
  22. What's interesting is the same Rambler, the automatic transmission although push-****on shared design with 57-58 Ford and was used in some later Willys and Studebaker applications. I'd presume it looks huge next to that manual box. Or at least, some Motors manuals cover the transmissions in the same section.
    I've always thought an enterprising guy could make a push****on Edsel that actually worked like it's supposed to with the right combination of parts.
  23. vtwhead
    vtwhead
    Is the gear machined to accept a washer? If so, I bet they are suppose to be there. Can you locate a ****** breakout diagram? That should show all the parts in the ******. Also, there is a clearance spec on the counter shaft thrust washers. Often the case is worn allowing way too much thrust travel. In the Olds trannies this clearance is around 12 thousands. Might want to check this on ***embly.
    slim tempo likes this.
  24. R Pope
    R Pope
    Jeeps, Scouts, Ramblers, Studebakers, Henry J's all used them.
    studebaker eric likes this.
  25. slim tempo
    slim tempo
    Boy, would I love that for a spare. I wish I was in Oregon right now.
    rudestude likes this.
  26. slim tempo
    slim tempo
    I have the 1958 tech service manual. Yup, there are supposed to be a retaining washer on the outside ends of the bearing stacks. Whoever rebuilt this last time omitted the washers.
  27. slim tempo
    slim tempo
  28. slim tempo
    slim tempo
    I would love a stronger transmission but don't have the wherewithal to remove the torque tube setup for a leaf spring exchange.
  29. junkman73
    junkman73
    I have a tans out of a 63 Volvo that is tiny.If you took the shifter off it would fit into a lunch box.
    saltflats and rudestude like this.
  30. rudestude
    rudestude
    VANDENPLAS and saltflats like this.
