Hot Rods Mustang rad in a model A
Discussion in 'The Hokey Ass Message Board' started by Phil P, Dec 23, 2018.
  1. Phil P
    Phil P
    Happy holidays everyone
    I'm going to order a new rad for my sbc into a model a project. I'm leaning towards the walker cobra rad, it seems to be the most cost-effective rad that looks like a proper A rad. There seems to be some people using a Mustang rad instead but I haven't found any pics, as I will not be running a hood I am concerned about the look. Any pictures please . Phil
  2. F-ONE
    F-ONE
    from Alabama
    Since the Mustang has been made for 54 years....what year?
    With that said, my short answer is......
    Get a radiator made for a Model A or Early Ford , original or new.
    Texas Webb likes this.
  3. bct
    bct
    mustang rad fits width wise but is a bit short so you can see tanks from the front . not ideal but they are cheap.
    LOU WELLS likes this.
  4. bct
    bct
    1964 to 68 I think. 6 cyl. configuration for sbc.
  5. e z i
    e z i
    What's a Rad?
    scrap metal 48 likes this.
  6. raven
    raven
    I use a mustang v8 radiator and covered it with a 28-9 A shell. I place a sheet of perforated steel in front of it. Works great and no one can tell front the front.
    r
    AHotRod, pitman and bct like this.
  7. Dreddybear
    Dreddybear
    Mine has a mustang radiator. Never felt bad about it and I think it looks fine.
    This has a Mustang Rad too.. except he flipped his upside down to make it work.
    AHotRod, Stogy, mgtstumpy and 8 others like this.
  8. ramblin dan
    ramblin dan
    I had a lot of guys in my neck of the woods are using a Volare ,aspen and some new Yorker rad for the deuce shell. The water necks are on the proper sides for a sbc and I believe are the same size.
    AHotRod and loudbang like this.
  9. Raunchy
    Raunchy
    I was just thinking I put a Chevy roundy round radiator in my 48 with a SBF and had to do some creative plumbing because of the outlet & inlet. Did you guys have any trouble hooking up your hoses to the Mustang radiator????
  10. raven
    raven
    No issues.
    r
    bct likes this.
  11. chopped
    chopped
    I had the inlet changed in one for next to nothing, any good shop can do it.
  12. verde742
    verde742
    what year Mustang on the coupes
  13. Dreddybear
    Dreddybear
  14. HOTRODPRIMER
    HOTRODPRIMER
    If you can afford it use the Walker radiator,they have a 10 year warranty and the one in my sedan is 30 years old with no problems. HRP
    dirty old man likes this.
  15. AndersF
    AndersF
    Anyone who knows the size on theese?
    I am looking for a radiator to my build.
  16. gimpyshotrods
    gimpyshotrods
    Yup.
    pitman likes this.
  17. thirtytwo
    thirtytwo
    I used a mustang onece ,because I had it but for the cost of the cheapie aluminum ones online , and a can of black paint I feel like that is the better option... for me anyway .. or if radiator shops are reasonable in your area get a good stocker and have it repaired
  18. Blues4U
    Blues4U
    from So Cal
  19. blue 49
    blue 49
    from Iowa
    Thermostat housing from a 70's Chevy inline six works to get the hose pointed in the right direction.
    Gary
  20. B.A.KING
    B.A.KING
    You know what years on these?
  21. krgdowdall
    krgdowdall
    from Alberta
    1965-66 mustang, Falcon, Comet V8 rad fits a 26-27 T rad shell a bit short, but expanded metal, painted black, will hide most of the gap. The rad cap is under the shell, tight , but is acesable. Inlet and outlet are both on the p***anger side, but changing the outlet will line things up. I also used the mustang rad hoses, which required t******* . The unit is priced at under $200 us ($300 cdn)
  22. Dreddybear
    Dreddybear
    You mean, we'd have to customize some ****? Perish the thought! :p
    For any of these a little trip to the rad shop is likely.
    Bottom inlet was turned up on mine. Cap is under the shell I like it like that.
    On Live Wire they sealed the cap and brazed an extension to relocate it back.
  23. ramblin dan
    ramblin dan
    I believe these rads were late 70s and early eighties. I took one from a 1980 Aspen I had and a buddy of mine gave me one from a new Yorker from the early eighties that was the same size but it had trans cooler built in. I believe these were very common for many model of Crysler products of this time. I'm building a very channelled rod at the moment and am planning on using this early Honda civic rad because of how low the body is. Water necks on same side as sbc and has built in mounting holes, is three rows and came with electric fan.
  24. Blues4U
    Blues4U
    from So Cal
    So if you can buy a Mustang radiator and have it modified to fit the A for less than a radiator designed for a Model A, what the hell, go for it. Keep in mind you need the mounting pads on the bottom of the bottom tank, and the brackets to mount the shell too. Why you'd like having the cap under the shell is beyond me, but hey, it's your car & radiator, so go with what works for you, makes no difference to me.
  25. Stan Back
    Stan Back
    "This has a Mustang Rad(radiator), too, except he flipped his upside down to make it work."
    Must be a ***** to fill.
    Tim, upspirate and alanp561 like this.
  26. tiredford
    tiredford
    from Mo.
    I used the mustang rad for a 6 cyl. Its the exact same as the 8 cyl except the lower hose is on the driver side. And it has a lifetime warrenty at Oriellys
    gimpyshotrods likes this.
  27. Dreddybear
    Dreddybear
    Way less. 40 bucks and a case of beer will usually do the trick. So around 250 bucks for a radiator vs what, like 1k for a 32 or Model A?
    Cap under the shell.. it's hidden. I like that. It's a show car. There's weird **** everywhere.
    I like you. You're a straight shooter.
    Blues4U likes this.
  28. Phil P
    Phil P
    Thanks for responding, I went ahead and ordered the walker cobra. Why: made over here, 10 year warranty, copper construction, and because I am planning not to use a hood I think it will look the best. Phil
