Hot Rods Building mistakes you won't repeat
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Nov 11, 2018.
  1. A buddy of mine did the exact same thing on a stock car.
    Except left rail was higher than right.
    Funny thing is that car cornered like it was on rails.
    Boneyard51 likes this.
  2. 62rebel
    62rebel
    Thereby loading the right front wheel! Built in "stagger"! No need to jack the rear axle around....
    alanp561 and Boneyard51 like this.
  3. junkyardjeff
    junkyardjeff
    Me and a friend donated good parts to a car club were were in since we could not help much in the project but they quit on it and sold the parts,never again will I do that.
    classiccarjack likes this.
  4. Mistake? Sink a bunch of money and time into a 429 Cadillac engine. Impossible to find a good oil pump for those. All good for about a year, then the dry starts began, scaring the **** out of me.
    Bearings = toast.
    Motor = boat anchor.
    I still have the mighty switch-pitch trans if anyone is interested.
  5. chev34ute
    chev34ute
    Trying to re- build a 34 Chevrolet Coupe Utility body that had a timber frame that long perished while living in a country where no one makes wood kits for them, because the production figures were too low to justify an aftermarket industry.
  6. RICH B
    RICH B
    ....and back up your pictures, whether on a cell phone or camera memory card, otherwise the original will lost or nowhere to be found when you absolutely can't remember how something goes together.
    Sent from my Nexus 5X using The H.A.M.B. mobile app
  7. Mr48chev
    I sold off a pair of valve covers the other day that I bought in 1990 That had never been out of the box except to look at them about twice.
    I've got a truck load of parts in the sheds both new and used that I bought over the years I'm meaning the past 50 as some of them I hauled from Texas in the 70's when we moved back up here. Anyone have a use for some lavender/purple wire loom. Not sure why I thought that was a good idea but I think I have a few purple wire ties to go with it.
    Build mistake lately? running out and buying a donor rig to use the suspension pieces with a fabricated crossmember that a Hamb member was making for a while and then had a life style change. I didn't get the crossmember before he quit making them but am only out about 80 bucks on those pieces and can probably sell some of them on Craigslist to guys with stock pickups like the donor. I've got three other ways to go sitting out here so it isn't the end of the world but a lesson in life.
  8. HotrodHR
    HotrodHR
    This is a two part screw up...
    (1) Late one school night (at age 16) I dropped a small nut in the top of 4 barrel carb on a SBC... I'll get to it later, buy a magnet and go fishing, pull the carb and intake if necessary....
    Didn't get back to project for several weeks because of work, school, $$$, or whatever. When I did I fired that baby up and heard a snap, crackle, pop... oh **** nut must have blown right out, no harm no foul... not! Drove car around the block, started smoking so I knew it was damaged.
    (2) Pulled intake and heads to reveal nice hole in a piston. Me and a couple of friends replaced the piston with the motor in the vehicle. Head and valves were OK so we put it back together. My one friend (who was in HS Vo-tech for mechanics) says "slap on the old head gaskets and torque it down... it'll be fine." So we did and you know the rest of the story... pull apart and do it again with fresh set of gaskets... Dumb teenagers!
  10. bobss396
    bobss396
    This is my biggest sin. I think the project will run X months, only it actually run 3X months. In that span, you forget a lot of little details and just have a vague idea where that wonton soup container of hardware came from. With my Ford I came to that realization and started taking better notes and marking parts and bags of hardware.
    Then there is keeping track of NEW parts and parts that are painted and wrapped up. I had one copy paper box of painted parts that kept hiding from me, it was all over the garage. I "lost" a box of some NOS parts I bought on eBay, found those in a box of painting supplies. I started marking boxes of new parts as they came in the mail.
    My next trick will be gathering up all my stainless steel trim and culling them to see what goes on the car and what gets sold. I'm famous for buying better items so I can cherry pick the best that will be used.
  11. don daddyo
    don daddyo
    My biggest mistake was:not listen all my friends ,when they tell me to buy a car that you could already drive and work later,30 years or so still have it in the garage completely dismantle , since then they call me (THE GARAGE CRUISER )!?!?Don
    alanp561 likes this.
  12. NWRustyJunk
    NWRustyJunk
    Having a bunch of projects and nothing cool to drive. That's the mistake I keep making over and over and over again!!!
  13. Bill Rinaldi
    Bill Rinaldi
    Mistakes, I've made a few, but then again, to few to mention................... SORRY, --FRANK SINATRA----My 2 biggest (HOT ROD)mistakes I made----- TWICE-----First time when I built my first complete Hot Rod-----A 23 T track roadster, Hot 327, 400 turbo QUICK but never bothered with a neutral safety switch. "nobody will drive it but ME" Friend starts it-----puts it THROUGH the back wall of my garage. Also put a big dent in my wallet. Second time, I buy a decent 56 F100, 390 Ford, C6 trans. Bring it home, parked in the drive way. Next day I go to start it, cranks , trying to start, pump it , floor it, STARTS--- like scaulded CAT---IN REVERSE-----WHAM--- Right into the front end of my 2 year old BUICK ----- You guessed it ---NO NEUTRAL START. yea-----EVER SINCE all my cars have working neuteral start switches. (name withheld to protect my stupidity)
  14. ...Laughing, man I can relate!!!
    Hnstray and classiccarjack like this.
  15. rockable
    rockable
    Having two cars dis***embled at one time and losing interest in one after I spent a bunch of money inbuilt parts and rechroming. I just "sold" it in pieces at a huge loss. At least I finished the Plymouth. Sigh.
    Hnstray, 47ragtop and classiccarjack like this.
  16. classiccarjack
    classiccarjack
    I love listening to my engines... My wife and kids are all about the radio. I can live without it. Just drove from San Diego, to Idaho Falls, to Denver, to Kansas City, and back to San Diego in a truck with no radio in it.... Didn't notice
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
    greaser likes this.
  17. lake_harley
    lake_harley
    Realizing part way through a project that the car I'm working on isn't what I really, really wanted to build. I'll keep going because I won't quit on it and in the end it'll probably be a fun car to drive. Sure does kill some of the enjoyment of the build though.
    Guess I have to build another after this........
    Lynn
  18. oldiron 440
    oldiron 440
    Mistakes are the tuition for school of hard knocks, you just have to learn from them.
  19. Rocky
    Rocky
    Classified Editor
    All the more reason to go all the way to the top of your list and get that one you really want! I bought a piece of **** old stock car racer 34 ford because it was the only way I could afford to get my dream car....took 10 years but I'm driving it...finally. In my avatar
  20. mgtstumpy
    mgtstumpy
    Building 2 x cars simultaneously, never again !o_Oo_O
    47ragtop and Chavezk21 like this.
  21. 62rebel
    62rebel
    Building too fast because the DD is falling apart on me.... last '63 took me two years; if this one takes two, so be it.
  22. Spent a whole 6 weeks redoing a fender for my (off topic) 1968 Camaro in high school paint and body cl***. I striped it, patched a rust hole in the bottom, bumped out a couple of small dents, and primed it. It came out really well, and I was proud of the work I had done. I put it in the bed of my El Camino to take it's home and install it. Probably should have tied it down, because halfway through the 1.5 mile trip home, it blew out and got hit by another car. All that work down the tubes for a moments stupidity!
    Sent from my SM-G955F using The H.A.M.B. mobile app
    Hnstray likes this.
  23. TrailerTrashToo
    TrailerTrashToo
    We need an "OUCH!" ****on,
    Hnstray likes this.
  24. HOTRODPRIMER
    HOTRODPRIMER
    The beauty of building traditional rods & customs is you don't get caught up in the current trends.
    Thank God I didn't get caught up in the splash graphics, Easter egg colors, tweed interiors or get bit by the billet bug, I always liked the resto rod look and liked the cars simple.
    I will admit I did fall victim to the monochrome fad and dislike the finished product so much I sold it within a couple of months. HRP
    David Gersic likes this.
  25. woodbutcher
    woodbutcher
    :D Ohhhhhhhhhhhhh brother.Does this thread bring back some memories.
    Good luck.Have fun.Be safe.
    Leo
  26. jazz1
    jazz1
    don't forget Woodruff key when replacing the cam and lifters. The engine won't start no matter how many times you set timing marks. After a day of wondering WTF a mechanic friend dropped by, said it should start then he saw Woodruff key on work bench. Pointed out I had missed something:D
  27. Bert Kollar
    Bert Kollar
    Didn't pressure test the block for my hemi and after ***embly of a completely printed engine all the coolant ran into the oil through two rotten holes in the cast iron. These don't show up during magging and weren't obvious to the naked eye.
  28. Oldbill51
    Oldbill51
    Make sure when you are mocking up the location of the engine that you get it high enough to center the water pump at the radiator. I like things as simple as possible and do not want to have to deal with an electric fan or some other cobble to make up for poor planning.
    gearhead1600, trollst and jazz1 like this.
  29. jazz1
    jazz1
    That's what I'm finally doing after building truck 10 years ago. Cooling not a issue as I got a big honkin' rad that requires no shroud but my oil pan will not be suffering any more road rash
    Shallower pan also getting installed.
  30. 5window
    5window
    Bought '32 rolling ch***is that was really set up wrong for more money than it was worth when I had absolutely no idea how to build the rest of the car. Watched it gather dust for three years, then bought something s bit further developed that I could build on.
