Technical 55 chevy truck manual steering column to auto column swap?
Discussion in 'The Hokey Ass Message Board' started by Unclebrad, Dec 26, 2018.
  1. Unclebrad
    Unclebrad
    As far as I can tell, my truck has an original 3speed manual column, which has been rigged to operate a th350 automatic transmission. (I am thinking of changing that to a 700r4)
    It works.
    Sort of.
    In a very sloppy way.
    But it isn’t what I would call “right”. There are none of the safety features that a “proper” automatic column would have.
    -You don’t pull back on the lever to move it to a new position.
    -There is no Neutral Safety Switch.
    -There is no shift Indicator.
    The only thing that I like about that is that it is an original looking column.
    I am thinking that, IF I can find an original automatic column and swap this column for it, I will be able to take care of those lost features while retaining an original appearance.
    Thoughts? Advice?
  2. vtx1800
    vtx1800
    If I were in your shoes I'd be more tempted to adapt a 67-72 Pickup column to your steering box because finding an org column jacket will be pretty difficult (although that would be the best)
  3. DDDenny
    These are getting pretty hard to find, especially the tilt version like I had, and they are NOT CHEAP.
    In the 90's I put one in my 66 Suburban when I swapped the 283/powerglide for a 350/turbo 350. They were hard to find even back then, but I got lucky when a friend said he had one and had no plans for it. As you said; it will greatly add to your driving pleasure.
  4. squirrel
    I did that once, using parts mostly from a 53-54 car Powerglide shifter, with perhaps a few Hydramatic shifter parts thrown in. Quite a pain to set up, but it worked pretty well. Finding the parts will be fun...
    scott27, mgtstumpy and olscrounger like this.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Too add to DDDenny's post. Don't forget Step Vans.
    low budget likes this.
  6. low budget
    low budget
    from Central Ky
    Seems there should be a kit or a solution out there to fix this problem, Ive done similar riggings as you have now....but this also reminds me of a 57 truck I had, that I put a floor shift in:rolleyes:, I took it to the muffler shop and had a new set of dual exhaust put on it after I got it all together, they got the pipes on and it sounded great, They let it down and I back it off the rack, and out in the parking lot but when I tried to shift it to drive, it wouldnt go because the linkage was hitting the new pipes.....so put it in park and told the guy that put the pipes on what was going on...so he slides under it while the truck is still sitting there running, gets ahold of the linkage and pulls it in reverse:eek: backing the front tire against his chest:eek:, I grab his foot, dragging/slinging him in a circle to get him out from under the truck, then have to run and catch my truck thats heading backwards out into the street:confused:
    ....all was well except for the long haired dude that put my pipes on was still white as a ghost, and my nerves werent that great either....I told him not to worry about fixing the pipes to p*** correctly, I would do something different with the shifter , I unhooked it, started it in drive, drove home and did something different later but Whew!
    So yeah, Things need to be right:D
    Hot Rod Nut and Atwater Mike like this.
  7. DDDenny
    Affirmative on the van column.
    Though they are slightly different ?Length?
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
  9. RICH B
    RICH B
    Maybe look up some posts by olscrounger about how he sets up a stock '40 Ford column shifter with gates, neutral switch, etc for an auto trans. Yours should be somewhat similar with the external shift mechanism.
    Sent from my Nexus 5X using The H.A.M.B. mobile app
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No No No. That's Chevy into Fords not the other way. :)
  11. Eddie
    Eddie
    from Georgia
    I see that you have now placed a wanted ad for an OEM automatic shifter. Be advised that as far as I know, Chevy and GMC only offered hydramatic transmissions for these trucks and that shifter is all wrong for what you want. You need to start with what Squirrel said, a 53-54 p***enger Powerglide shifter in order to look original inside the cab. You could possibly use this as-is with the PRNDL only indicator. If you want the additional 3,2,1 locations, you will need to modify the detent plate and the indicator.
    Eddie
  12. Unclebrad
    Unclebrad
    Thanks Guys,
    Thank you for your input!!
    I have no idea what the difference between the Powerglide shifter and the Hydromatic shifter would be. Kinda surprised that they aren't simlar.
    Squirrel, your adaptation is beautiful. I was guessing that you used the earlier other parts because that is what you had available. I didn't realize that the 55 stuff won't work at all.
    I think I am ok modifying an indicator, and may even be able to figure out how to modify the detent, once I see the parts on the workbench.
    But I guess I do need to change the wanted ad .
    Before I do that, let me ask if I need a complete column, or just the shifter hardware for the 53-54 car?
    Anything else I need to be thinking of?
  13. RICH B
    RICH B
  14. squirrel
    The shifter and the column are separate items. The column is the same for all the different transmissions.
    Sent from my Trimline
  15. 32fenderless
    32fenderless
    I am building a ‘58 for a friend of mine and his truck had the hydro. He is changing to a manual trans. I saved all the automatic parts attached to the column. I could ask if he is willing to part with it.
  16. Black_Sheep
    Black_Sheep
    After an unfortunate incident I added a Lokar neutral safety switch to my '58. It would probably be a prudent addition for your hybrid column set up nsswitch.JPG
    olscrounger likes this.
  17. The best source I've found for those is old van nosed campers, almost all I've seen are tilt. And they are still relatively easy to find.
    Johnny Gee likes this.
  18. squirrel
    on the one I did I used the original NS switch. Although I think it's only a Park switch, it doesn't engage in Neutral.
    looks sort of like this, if you can't see it in the earlier pics I posted
    olscrounger, scotty t and RICH B like this.
  19. Unclebrad
    Unclebrad
  20. Unclebrad
    Unclebrad
    Thanks!
    I definitely want a Neutral Safety Switch.
    I'll look into both types when I get closer to putting things together.
  21. Unclebrad
    Unclebrad
    Lots of good ideas and advice.
    I didn't know how clueless I was regarding this project.
    I don't know how to thank you enough.
    B
  22. Unclebrad
    Unclebrad
    Not sure how the reply got caught up with the quote.
    Technology is great but ...
    No wonder that I like old cars better than the new stuff.
  23. rustythumb
    rustythumb
    does limeworks have a kit for this?
  24. Unclebrad
    Unclebrad
    Didn't know about Limeworks.
    Very nice stuff.
    It looks like they DO have a kit that will solve the problem, but I REALLY like the "original" look, like squirrel has done, (Do you prefer "Jim" or "Squirrel"?) so I am planning to go through the pain to make up something like that. Pretty sure I am going to be asking a lot of "dumb questions" as I go. Please bear with me.
  25. squirrel
    beware that doing something like this requires that you know about safety issues that you have to deal with....you can kill yourself and others if you mess up the shifter design or installation.
  26. Different dog but same basic program. I have a 700-R-4 in my 51 Vicky and connected the Stock 51 Auto shifter that was a 2 speed unit to it and have full range of gears. Took some work and a bell crank to change the travel ratio from shift lever to trans arm travel. It works grate, locks in P and N, as well as drops into 1st gear when pointer is on L on the crown. I also have the stock N safety connected. You can do it too with the Glide or Hydro unit. I think the Hydro has R on the bottom of shift travel where the Glide is just out of P location. The Crown is just Plastic so maybe a new make over for that piece for yours. When the Stock look is what looks best it's hard to go late model just to get one job done. No way would a tilt column and late steering wheel would be Okay in this driver or yours.
  27. RICH B
    RICH B
    Good job. Those early Ford-O-Matic columns make really slick hot rod columns, if you want turn signal and a column shift without looking modern. Too bad most all of those cars were stick shift.
  28. 325w
    325w
    I have the top piece for a GMC hydro.send me your email and I'll send you pictures.
  29. Unclebrad
    Unclebrad
    Hi Guys,
    I finally got my shifter done, after way too many setbacks, unforeseen issues, and stupid mistakes, but it looks like it came that way from the factory, and it works like it should.
    Many, many thanks to all of you who gave advice and pointed me in the right direction.
    Part of the issue was that I was also incorporating the Limeworks detent kit into the project. Lots of little custom fixes needed on both the shifter part and the detent part.
    I wrote the process up with lots of pictures, and would be happy to share it with anyone interested. It's kind of long (27 pages) so I'm not sure it would be a good idea to "post" it.
    Thought you might like to see a couple pics though...
    Johnny Gee, X38, swade41 and 3 others like this.
  30. squirrel
    Wow, that came out nice! And it clears the huge W motor
    57tailgater likes this.
