Technical ***December 2018 Banger Meet - What Will Santa Bring***
Discussion in 'Traditional Hot Rods' started by Jiminy, Nov 30, 2018.
  1. winduptoy
    winduptoy
    Thanks John, you were partially to blame for the T-5, that and Woody shifting his like an automatic.
    Christmas is knocking on the front door isn't it.
    Looking forward to a fun 2019 you and yours have a fun one.
    Larry
    Sent from my XT1254 using The H.A.M.B. mobile app
  2. Binger
    Binger
    from wyoming
    HAHA I didn't even take you for a ride in the coupe! If I would have done that or let you drive it, you would have had one much sooner! It will take a lot of work to be able to catch that 1243 coupe of Woody's haha. By the way what is that shifter on that transmission? Is it a jeep trans? I cant remember.
  3. Merry Christmas everybody!
    My box of parts from Macs should be coming any day now
    waxhead, winduptoy and ROCKER77 like this.
  4. winduptoy
    winduptoy
    Jeep transmission, shifter has throw stops do as not to bend forks from getting carried away speed shifting oldFashionedChristmas_edit.jpg
    Binger and GuyW like this.
  5. winduptoy
    winduptoy
    You know how it is... working thru new ***embly items on the Vicky. Used Charlie Prices adjustable main jets on the 97's.
    I don't know why he supplies a nylon washer that doesn't fit, thus doesn't seal. Drips fuel like crazy. Wrong material in my mind for the application. IMG_20181225_102208.jpg The part he provides is made so it has a shoulder on the sealing area and won't accept the fiber washer off the stock plug.
    Turned down the shoulder and used the washer off the plug. IMG_20181225_103602.jpg Problem solved.
    Shutter Speed, Dannerr and JT1930 like this.
  6. winduptoy
    winduptoy
    Broke down and installed am electric fuel pump. Fits in the frame nicely and no pressure regulator. We'll see how it lasts
    12volt
    Jet96 and ROCKER77 like this.
  7. RussTee
    RussTee
    Good luck with that I have had no luck with those kept going out of adjustment.
  8. winduptoy
    winduptoy
    I'll keep that under advi*****t...
  9. RussTee
    RussTee
    It is interesting that the new 97 site does not recomend adjustable jets mine was set up with a O2 meter went out of adjustment and bore washed a new motor
  10. JT1930
    JT1930
    Out banging around Christmas Day.
    FC9C2BB7-F25D-426D-8D50-CCB64CCC6552.jpeg BCE9C8DC-A73B-411D-8E8C-09DD2D2DB64E.jpeg
    Old Dawg, Jet96, Kopperhead and 8 others like this.
  11. ^^^Good to see you out and about, JT1930. Have a good New Year!^^^
    Art
    JT1930 and Retson the Racer like this.
  12. Ed WIndfield stuff will do the trick!
  13. GuyW
    GuyW
    Well, Santa didn't bring it - but I bought back my grandfather's welder which has a good Model A engine, as a spare for my T roadster. Don't have any room or use for such a large welder, so I'm preserving the engine and the frame and axles (for an OT project).
    Old Dawg, Jet96, barrnone50 and 5 others like this.
  14. V4F
    V4F
    from middle ca.
    jt1930 ……………. nice coupe
    JT1930 likes this.
  15. cw
    cw
    from Midland
    bondojunkie, Old Dawg, Jet96 and 8 others like this.
  16. railcarmover
    railcarmover
    Fitting up something different..single barrels @ 82CFM each,baby webers.we'll see how they do,if they dont do the job Ill put them on the Vw. Got a 97 and an ansen intake as backup..
  17. jim1932
    jim1932
    Picked up another diamond block. Nice one.[​IMG]
  18. jim1932
    jim1932
    More interesting marks[​IMG]
  19. V4F
    V4F
    from middle ca.
    *** maybe need a mixing plenum chamber
  20. RussTee
    RussTee
    Happy new year all from the south seas.
  21. V4F
    V4F
    from middle ca.
    and happy new year to you
  22. RussTee
    RussTee
    Mid summer here overcast and warm a good driving day beaches will be crowded
  23. mramc1
    mramc1
    Been working on the banger for my AA doodlebug. It's an old .045 over rebuild I got out of a parts 31 AA I bought. It looks like it should run ok. Its hooked to two 4 speeds and an early top drive truck rearend. 20181216_141603.jpeg 20181209_204343.jpeg 20180923_214023.jpeg
    Sent from my SM-G930V using The H.A.M.B. mobile app
    Old Dawg, Jet96, rwrj and 3 others like this.
  24. sdroadster
    sdroadster
    Do those Webbers have an application or part number?
  25. railcarmover
    railcarmover
    Not as far as I know,they dont use them in other applications..3" short tube type intake manifold. That being said your guess is as good as mine.I am going to tie the two small vacuum ports below the throttle plates together to help equalize vacuum at idle,might have to go bigger with an equalizer tube between the two runners...say 3/8ths or so,only if necessary.Ran on the other application without it..
  26. railcarmover
    railcarmover
    Weber 34 ICT's..Vw aircooled aftermarket carbs.about 82 CFM per carb,I figure it should work as well or better than a single downdraft.They have a way more refined diaphragm style accelerator pump and offer multiple main jet combinations for tuning,a simple emulsion tube style carb.Figure they will spool up a little quicker being closer to the cylinder than the Stromberg,the refined accel pump will help limit the overfueling .Putting them on a stock A bottom end on babbit,sleeved to stock, B cam,B flywheel B distributor. Put on a milled snyder 5.5 (no piston reliefs,but no protrusion either) converted to 12v and hung a fuel pump over the weekend..ran it with the Stromberg,which woke up with adequate fuel pressure.Still going to finish the weber carb lash up just to see the difference..or it it will work..this is low horsepower stuff, moderate compression flathead.Still sorting out exhaust..
    Dannerr, Jet96, GuyW and 2 others like this.
  27. Jiminy
    Jiminy
