Projects 1955 Chevy Southeast Gassers Build
Discussion in 'Traditional Hot Rods' started by Zak Hall, Oct 29, 2017.
  1. Hang'emHigh
    Hang'emHigh
    You should be happy, they look great Zak!
    loudbang and Zak Hall like this.
  2. Zak Hall
    Zak Hall
    Thanks!
  3. 6sally6
    6sally6
    Gimme a little "info" on cutting the headers! How long are the primaries now and why did you cut them to that length? Is the collectors the right length and why?! How did you figure what the right length was?
    I'm really into the "technical" side of the whys and why nots.
    Thanks
    6sally6
    Ride keeps getting better and better
  4. Zak Hall
    Zak Hall
    The professionals tend to agree with around 28-31” primary length. Primary length has to do with rpm band. Shorter the primary, higher the rpm band, longer the primary, lower the rpm band (higher torque) we made these 29” primary because of the 1/8” mile cl*** racing with a 4 speed and low rear gears, bottom end isn’t really an issue. As far as collector length goes, the collectors are as long as they came out of the box. We’re gonna use the old school method ofcollector tuning. Paint a white latex paint stripe or chalk stripe down the collector,Running it at the track a few p***es, and cutting them 1” longer than where the mark is burnt away. Collector length isn’t really all that critical.
  5. loudbang
    NICE WORK!! Look to be very close to equal lenght too. :)
    Bowtie Coupe and Zak Hall like this.
  6. saltflats
    saltflats
    from Missouri
    Did you think about a merge collector, or are they not allowed?
  7. Zak Hall
    Zak Hall
    Thought about them, they are legal but they’re expensive. And I talked to a few people and you’re looking at a 2-3hp gain on an application like mine most likely.
  8. Zak Hall
    Zak Hall
    9D25FB09-6239-4022-98AD-E9CE3B53345A.jpeg 949007FE-D599-41B6-B76E-E344D119FF14.jpeg D5F57C99-FB17-4E95-BB41-37E446D953E4.jpeg 5E9105BB-672C-42CB-AE74-10B2657E9B48.jpeg 1BB4FC89-589F-430A-A98F-DBD051DCC72B.jpeg 75C1D923-E6F5-475E-808F-4B0CB0C7532D.jpeg A94138B4-67B7-449D-AFCC-CA913B8FCE2F.jpeg 3612C83F-76A8-409C-894B-4DDE2D92EE3C.jpeg Got the headers painted and bolted on. Gotta paint the radiator but just put it back on to get an idea of the finished product. It’s gonna look light and radical. The list of things to do is getting shorter and shorter!
  9. saltflats
    saltflats
    from Missouri
    Nice job Zak.
    Oh, and H/P ain't always cheap. ;) :D
    Zak Hall and loudbang like this.
  10. Zak Hall
    Zak Hall
    6E2E0F29-E3B5-44BF-AA4B-7F213A32D7CB.jpeg 91057179-0CFE-4054-8415-1EC043B366D8.jpeg
    Headers, ignition, radiator, gas tank, battery, driveshaft, engine is full of oil, and everything on it. 2220lb. Only things left to add is the firewall, brake lines, minimal wiring, lexan, and water/fuel. Should weigh 2270-2300 race ready minus driver. Later on it will get light weight racing aluminum brakes, it’ll be even lighter. Not bad for a big car with a Big block Chevy in it.
  11. Hang'emHigh
    Hang'emHigh
    Impressive! That's pretty darn light for any '55.
  12. southcross2631
    southcross2631
    That's a fine job . Your 55 is as light as my Morris Minor.
  13. Now that is one fine lookin g***er. Great job!
    Bowtie Coupe and loudbang like this.
  14. Zak Hall
    Zak Hall
    Trying to keep it light as possible!
    AHotRod, loudbang and Bowtie Coupe like this.
  15. csf64ss
    csf64ss
  16. seb fontana
    seb fontana
    from ct
    Four hose clamps been holding my exhaust pipes to the hangers for twenty years of street miles..And another clamp for the steering column at the firewall..
  17. Zak Hall
    Zak Hall
    We’re gonna upgrade to the t-bolt style clamps for the final ***embly. But I see zero issue safety wise. 4 hose clamps should hold the column in without any issue.
  18. Zak Hall
    Zak Hall
    84EC10E5-A315-4E07-A18A-FC5F9C09793D.jpeg 1781E161-86B3-46E2-888C-04C2235388F2.jpeg 83A46CE8-8E54-488A-95A3-1D4935EC2B24.jpeg F988C205-FD48-4007-98A5-FB9836FF4D55.jpeg Made an adjustable clutch stop, trimmed the bracket on the throttle pedal, and started making the template for the firewall.
  19. Zak Hall
    Zak Hall
    0C703CF9-3B02-4EC8-A1A7-597D9AAACC42.jpeg 7FAD31BD-03DC-4052-8775-D9D63CE310B8.jpeg A69DE656-5710-4B69-A1B3-61772E15C792.jpeg 742BBB2B-FED6-49B4-82EE-ADA9A853021F.jpeg 5BE85F18-AE12-4738-8DC0-E240A36460DC.jpeg 9F0BEBB7-100D-4F6C-8082-DE0D567635DD.jpeg D1265AEE-4E5D-49AC-8FF4-3D339332D770.jpeg
    Got the firewall pretty well finished. Gonna make the tunnel tomorrow and fit it up to the firewall before we rivet the firewall in permanently.
  20. AHotRod
    AHotRod
    Beautiful job !
    Zak Hall, loudbang and Bowtie Coupe like this.
  21. Zak Hall
    Zak Hall
    91C1380D-248F-4A79-9504-ADD6D6549650.jpeg F65C52AA-FCF6-4F30-82B1-A01FDC2324D3.jpeg 5C3A2896-BFA2-438D-AE59-EA52858A5337.jpeg Made templates for the floor pans and trans tunnel. Seen everything will fit well and work out so we can finish the firewall up and start filling the floor with tinwork.
  22. Those cardboard floors should save some weight.
  23. Mike Colemire
    Mike Colemire
    Looking good Zak! Merry Xmas.
  24. Zak Hall
    Zak Hall
    B8B67659-8103-425F-8C87-26E808EA2080.jpeg D37F927C-FE6A-4B3E-8F45-52BAE720AE49.jpeg E47C9239-61FA-4FCD-84B3-3029CBFC5726.jpeg
    Firewall is done and we got the pieces made and in that conceal/box in the door hinges. Starting on the floors tonight.
  25. bobss396
    bobss396
    Agree... drill a bunch of 2" holes to let the residual pizza sauce run out.... pizza boxes as templates, very traditional.
    Just Gary, loudbang and Zak Hall like this.
  26. Zak Hall
    Zak Hall
    88D519CC-B9DF-4E0C-8D79-30F413484031.jpeg 3E151416-6AFA-44C9-A8B7-CB954950BA2C.jpeg EEA6E3D5-DC4D-444B-A869-B200C9A130AD.jpeg 6456993D-B0F9-46F8-A652-806E016D4A81.jpeg Got the floor pans cut out and installed today. It’s starting to look like a car. Gotta make up the tunnel over the weekend.
  27. loudbang
    Going to use the twisted intake? Looks a tad SMALL :rolleyes:
    Oldioron, Bowtie Coupe, brEad and 2 others like this.
  28. Zak Hall
    Zak Hall
    Yeah it’s just on there to seal up the engine. Too hard to work around the tall tunnel ram, but it’s going back on once we’re finished lol
  29. Zak Hall
    Zak Hall
    75EAF954-7F31-42B7-B180-94FC07E3CAF0.jpeg AE7F52F9-8F11-4BBB-802D-BD3FD1FD7373.jpeg 069201B0-6BB3-4F77-AAE4-7698856DC4B2.jpeg 94E1DE13-364D-4DD1-8382-34935F921DD6.jpeg EC3223B5-D48B-4E00-A92F-E14A6B51FE3A.jpeg Got the last of the floors knocked out today. It’s gonna look pretty clean. Gotta start the tunnel next.
  30. DDDenny
    Really nice work there guys!
    Zak Hall likes this.
