Technical Aviation Form A Gasket
Discussion in 'Traditional Hot Rods' started by Truckdoctor Andy, Dec 29, 2018.
  1. Hey Everybody! As some of you know, I’m a heavy Diesel Truck Mechanic by trade. Putting modern engines together using modern sealers and RTV type stuff is what I do every day. But, our hot rods and vintage stuff requires different gasketing and sealing. I have just recently discovered Permatex Aviation Form A Gasket and Indian Head Gasket schallac. What applications do you guys use these for? RTV has its place, but looks like s&@t sticking out everywhere. Please o’mighty H.A.M.B.ers, enlighten this 44 year old youngster! Thanks guys!
    Texas Webb and Boneyard51 like this.
  2. squirrel
    I use it to coat most paper gaskets, for things like water pumps, thermostat housings, oil pans, timing covers, ports on intake manifold gaskets, manual transmission gaskets, etc. I use RTV very little, it is good for things like the ends of intake manifolds, or corners of oil pan gaskets, but not much else.
  3. tb33anda3rd
    tb33anda3rd
    I have been accused of using it on everything but my salad.
    Hnstray, nochop, The37Kid and 9 others like this.
  4. Hyvolt
    Hyvolt
    I learned from a gray beard to use aviation seal on flathead head studs. At a coal fired power plant they use it everywhere. Indian Head for paper gaskets.
    Thanks, Dave Maldin RIP. Learned allot from him.
    Sent from my LG-LS993 using The H.A.M.B. mobile app
    1Nimrod, nochop, weeniewawa and 3 others like this.
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    Paper and cork gaskts use permetex , rubber or no gasket use silicone with one caveat , fiber header gaskets with copper high temp silicone .
    Truckdoctor Andy and olscrounger like this.
  6. brigrat
    brigrat
    from Wa.St.
    "I have been accused of using it on everything but my salad."
    If it tasted good it could replace my Ketchup addiction...................................
  7. olscrounger
    olscrounger
    Have used both for many years with great results-use on items as Squirrel mentions--minimum RTV use.
    1Nimrod, Hnstray, zzford and 2 others like this.
  8. Boneyard51
    Boneyard51
    If the RTV is “sticking out everywhere” you are using too much of it. One of the reasons it gets a bad reputation.
    Over the years I have used a variety of “sealants”, including the ones you mentioned. Plus Permatex #2, and 3M 8001 and others.
    Bones
  9. Kan Kustom
    Kan Kustom
    X3
    1Nimrod and Truckdoctor Andy like this.
  10. panheadguy
    panheadguy
    from S.E. WI
    That's funny stuff there
  11. Aaron65
    Aaron65
    from Michigan
    Permatex #3 (Aviation Form-A-Gasket) is good for all kinds of things, PLUS it cleans up easily. I just use a little brake cleaner and a rag.
    1Nimrod likes this.
  12. ronzmtrwrx
    ronzmtrwrx
    It is good stuff, but I like the aerosol K&W Copper coat on paper gaskets.
  13. A7B41A3C-47D0-40A1-B1BB-D1D6486BC96F.jpeg The right stuff works great. It’s very similar to the stuff I used at jaguar and Mercedes ( probably the same as aviation gasket maker
    This stuff is thicker and more stable then regular RTV.
    I hate seeing silicone all spilled out over the edges of stuff and hopped in the corners.
    With this stuff a 2-3 mm thick bead is all that is needed works great
    Gasket shellac is perfect on paper gaskets sealing cast parts . I use it on a lot of stuff.
    I find a lot of folks go nuts sealing stuff with paper gaskets and silicone or the rubber neoprene gaskets and the 3m weather strip glue ( the yellow chicken snot) basically sticking gaskets on gaskets on gaskets ......
    If you have everything cleaned well and the surfaces are flat and not rusted or pitted a regular paper gasket and the correct fasteners torqued down is all you need.
    Only time I run into issues is when sealing surfaces are messed up or I’m forced to use a cheap after market gasket, then I might byp*** the gasket and only use gasket marker or make a gasket maker sandwich either way it’s an means to an end
  14. Boneyard51
    Boneyard51
    Van, like you I use a variety sealants on a variety of things. But never have gobs of sealant squishing out. If that happens, you have used too much.
    I am guilty of using that 3M stuff you talked about, we called it “gorilla snot”. Worked real good gluing valve cover gaskets into the cover, holding it with clothes pins. Then a thin layer of RTV clean surface, stick on while still wet, lightly tighten bolts.... perfect seal.
    There is a variety of sealants for a variety of problems. Just like there is a variety of wrenches .
    Bones
  15. Budget36
    Budget36
    An engine is an engine, be it made 70 years ago, or yesterday.
    Do you think a Model A would puke itself if you sprayed a bit of copper spray on it's head gasket?
    Just do what you do to get paid;)
  16. Hud I
    Hud I
    from Tennessee
    Use it on all head gaskets. Never fails
  17. Once again I am humbled by all of your knowledge and willingness to share and teach. Thanks to each one of you for taking the time to answer my questions.
    VANDENPLAS and 1Nimrod like this.
  18. deathrowdave
    deathrowdave
    from NKy
    The Right Stuff , has become my go to stuff , in recent years. This has been discussed and argued in the past . Bones, is so correct if you are having it showing up everywhere you are using way to much . If you have to much work it’s way into to an oil pickup screen , you will learn more is not the answer , fast . I always put the RTV on and allow it to skin over for a few minutes before ***embly . I never use RTV on a rubber part , unless I can see the ***embly , chances of the rubber gasket shifting because of the RTV is super good . Then you have to tear down and do it all over for nothing , but being in to much of a rush . I have used a thin layer of paint on Harley gaskets for years , very similar to Indian Head sealer . Everything has its place , the directions for application is your friend in this case . I have noticed for years , everything is the same “ it’s not near as good as it used to be “ , same for gaskets them seem to be about the thickness of newspaper anymore. Take your time clean , clean the surfaces and read the sealer directions , don’t rush the job. An old timer ask me years ago “ Boy , if you ain’t got time to do it the right way , how in the hell do have time to do it over again ? “ this has always stuck in my mind , burned deep into the memory bank .
  19. partssaloon
    partssaloon
    Having sold and used Permatex for many years I've moved over and used Gasgacinch , seems to work just as good and a lot easier to clean up. RTV for end pieces
  20. bobss396
    bobss396
    The Right Stuff is quite good for sealing the front and back of aluminum intake manifolds, it does have a short working life and mask off where you don't want any excess. 3M 8001 weatherstrip adhesive, also the old yellow gorilla snot was good for the edges of intake manifold and old pan gaskets. I used to use Indian Head and the Aviation sealer on bolt threads, but now use an ARP product that is less of a mess.
    1Nimrod, mad mikey and Boneyard51 like this.
  21. sdluck
    sdluck
    I use gasgacinch and rightstuff
    partssaloon likes this.
  22. Boneyard51
    Boneyard51
    Dave , I see where you and others let the RTV “ skin” before ***embling the parts. I always ***embled real quick after application of the RTV, so that it would adhere to the gasket and the metal. Did this method on a AMF Shovel, that I still have, and it would get dusty. Pertty proud of that. I did this back went the RTV made its big splash in my part of the country.
    I guess either method works, just different strokes for different folks.
    Bones
    VANDENPLAS likes this.
  23. zzford
    zzford
    For my sealer needs, I have been using Polygrip Denture Adhesive for years.
  24. :rolleyes:
    Now that there is funny!
    mad mikey likes this.
  25. paul philliup
    paul philliup
    from ohio
    On race car we rtv one side and use gease on the other that way we can reuse them. We put head gaskets dry and have reused them when needed.
  26. deathrowdave
    deathrowdave
    from NKy
    Bones , keeping an Early Harley dry is a chore in its self . I have an AMF Shovel myself at this time , 2nd owner , 13K miles . It drips from the breather tube , but bone dry for the most part also. I did change from dry to wet clutch plates , sealed the primary with RTV and a gasket many years ago . I probably did as you did , tightened it up wet and never looked back . Sealers have came a long way in recent years , any of them are better than what we had to work with years ago . Clean surfaces are a must or you will be after the repair again in short order
    Boneyard51 likes this.
  27. seb fontana
    seb fontana
    from ct
    I figure many here are familiar with the various T5 transmissions..No gaskets are used, just rtv..To get a T5 in or out of my car I have to remove the shifter..Have to beat it off which I don't like to do..Can anything else be used in place of rtv to seal the shifter for easier removal next time?
  28. deathrowdave
    deathrowdave
    from NKy
    Anaerobic Sealer is what I use and have used on many trans and transfer cases for years . It is made by Lock***e the brand I use . I’m sure there are many more different brands on the market . This is a sealer that will not dry until , it’s tightened between 2 pieces of metal . It is available at OEM dealers and recommended on NV4500 . Google this and see if this may be what you are in need of instead of RTV .
  29. jimmy six
    jimmy six
    Permatex #2..... Some of the best **** ever put in a tube.
    1Nimrod, Hnstray and VANDENPLAS like this.
  30. Fireball Five
    Fireball Five
    Me too, besides,that 3M stuff don't qualify for Medicaid !
    Fireball 5
    seb fontana likes this.
