Projects 31 ford build
Discussion in 'Traditional Hot Rods' started by Omarsvette, Dec 1, 2018.
  1. Omarsvette
    Omarsvette
    from Arizona
    image.jpeg I hope everyone joined there holiday. I'm now back to work on the coupe after a very busy couple weeks.
    My question is, there's is no washers that go between the perch, axle, rod, and shock mount right?
    brEad likes this.
  2. Omarsvette
    Omarsvette
    from Arizona
    image.jpeg image.jpeg image.jpeg Got up to the spindles installed today. Hopefully I'll have the wheels on by Sunday.
    Sergeant82d and brEad like this.
  3. Rocky
    Rocky
    Classified Editor
    Right....the nuts that go on the bottom of the spring perch are conical. The perches should have holes for cotter pins to keep the nuts from backing off.
  4. gimpyshotrods
    gimpyshotrods
    The fronts of the ladder bars are too far apart. This will cause early bind. The fact that the coilovers are straight up and down will disallow any natural body roll control that a coilovers installed at an angle have.
    The coilovers should be at a 30 degree angle, at most, the ladder bar should be no more than 8 inches apart at the front. They should be as far apart at the rear as is practical.
  5. Omarsvette
    Omarsvette
    from Arizona
    Finished my ch***is before we put the body on. Just waiting on tie rod to come in the mail. Also went with different wheel, more traditional I think. Also added some photos of the windshield and interior 3D754FE0-0CC2-4502-B710-DC441637E212.jpeg A9290993-4873-448E-8D11-22BF9EB07F66.jpeg E51BC527-5634-4396-A048-53982DBFC812.jpeg 563216F0-705B-49F6-BDFC-6034E27AEF12.jpeg 8CC03A4A-A663-4F1A-A4E9-1361E78EA348.jpeg F7AEE3D3-BB53-493F-9D32-8EEA3EE27FF5.jpeg
    nor6304, waxhead, Stogy and 6 others like this.
  6. Omarsvette
    Omarsvette
    from Arizona
    Hey fellas finally got the body on. Very exciting to see this come together.
    So on trying to decide where to mount the body, I ***ume following th contour of the frame? I plan on bolting it where it sits, you agree?
    Stogy and Sergeant82d like this.
  7. Omarsvette
    Omarsvette
    from Arizona
    0A9434CD-006F-4764-84F7-73DAD22079FF.jpeg I’m going to lower the rear more. And I’m using the gas tank in it’s intended location. Does that spacing look right?
    Ron Funkhouser likes this.
  8. Omarsvette
    Omarsvette
    from Arizona
    7F8AE3B4-C703-41EB-A23F-DC398601F06F.jpeg D41BE913-7E9F-42F9-B70A-F45D994E6935.jpeg 319095B9-9FA2-4BAC-8424-E94E99C308D1.jpeg Here are some close ups of the frame and body. The front sits closer to the frame than the rear does. I plan to use different thickness of rubber for my mounts?
  9. Omarsvette
    Omarsvette
    from Arizona
    B72AF3BD-63B4-41D6-8606-1F5D9AC76748.jpeg I just noticed why the rear doesnt sit flush. So do I cut of the horns and mount the tank inside? Or follow the original plan and use the horns with think rubber bushings for body mounts?
  10. gimpyshotrods
    gimpyshotrods
    I guess you decided to not fix the rear suspension.
    King ford and B Bay Barn like this.
  11. Omarsvette
    Omarsvette
    from Arizona
    Well to fix is to imply my coil overs are broken, which there not. I understand the theory why the coil overs should be tilted. In my practice of that theory with the last two model As I have built, my coil overs have been tilted like you say and I was not very impressed with the ride. Not to say it was bad but I felt it could have been better. Of course there’s other factors. But take in consideration this is by no stretch a race car or slalom track car. most of the weight is towards the front of the car. All of my driving will be in straight lines with some turns at less than 8mph, i figure there’s no hurt in experimenting with the angle of coil over theory.
    If my ride is less than comfortable, I will admit with confidence that my experiment lacked better angles. I hope you don’t think I’m brushing you off, even in my career there has been exceptions to theory’s.
    King ford likes this.
  12. 31Apickup
    31Apickup
    On a Model A on 32 rails, if you want to keep the rear frame horns you'll have to notch or remove that rear body crossmember to get the body to sit right. If look at the back of a 32 coupe, that rear panel is shorter. The other option is to cut the frame horns off and run a tank in the trunk, that's what I'm doing on my coupe.
  13. Gotgas
    Gotgas
    from DFW USA
    Looks great, man. I have to echo others' thoughts about the angle of the shocks. You'll want to get them at an angle so they are effective in turns too. But run em like you got em, and give us a report.
    Brian B*** put a '32 windshield header on his '28/9 coupe.
    osage orange, Stogy, FlatJan and 4 others like this.
  14. Omarsvette
    Omarsvette
    from Arizona
    I understand. I looked at the diffence between a 32 and 31. I will probably cut the horns. We’re did you cut?
    Stogy likes this.
  15. Omarsvette
    Omarsvette
    from Arizona
    Yeah thanks man. Some Buddys are curious to see how well vertical shocks run, especially cuz that’s how a couple of them run em on their tubbed street cars. Plus it’s not like it’s permanent.
    I really like Brian’s car. That is one of my inspiration. Maybe that’s were I saw the windshield mod
  16. sloppy jalopies
    sloppy jalopies
    spiff...
    the coil over's angle makes the shock travel further for the same distance of vertical travel... slightly changing the weight rating...
    I like to cut the '32 rear horns off...
    flip a pair of model A front frame horns upside down and weld them on as to let them curve upward, [ kind of leveling off] … bolt in a stainless tube as spreader bar...
    you can set them up at the angle you need to let the body sit right...
    '38 plate / trunk handle was a little gaudy... decided to run the plate off the 2 lower spare tire mounting bracket bosses...
    woodsnwater, Stogy and mkebaird like this.
  17. Omarsvette
    Omarsvette
    from Arizona
    BRO!!!!!! Money, that’s exactly what I’m doing.
  18. 31Apickup
    31Apickup
    Mine are cut just short of the rear body crossmember. I have a build thread 31apickup builds a coupe that has photos.
    Stogy likes this.
  19. Omarsvette
    Omarsvette
    from Arizona
    Just read through it. My last two As were fender cars so there was no need for floor mods only firewall mods. My coupes floors have been modified already. I can see it’s a lot of work. Keep postin, What power train you using ?
  20. 1946caddy
    1946caddy
    from washington
    image (4).jpeg My only comment is to secure your argon bottle either to a cart or the wall. Sitting in the open and it could get knocked over and if the valve were to get knocked off, you would be in for some exciting times.
    BradinNC, Stogy and lothiandon1940 like this.
  21. sloppy jalopies
    sloppy jalopies
    I remember the episode of the "A team series" when they would knock the valves off gas bottles as torpedoes... I have anchored mine well just in case...
  22. Omarsvette
    Omarsvette
    from Arizona
    Thanks for the cart suggestion. I’m getting tired of Lugging it around. I’m making it a priority since I didn’t know about the safety issue.
    Stogy likes this.
  23. Mike Colemire
    Mike Colemire
    I know of a tank falling over, knocked the valve off and it went through a concrete block wall.
  24. Omarsvette
    Omarsvette
    from Arizona
    5AB9BD3C-1F54-4AF8-8520-E7464DB916C9.jpeg D48DB500-ECE4-4060-866B-09F9DBBE164C.jpeg Cut the horns off, I think it looks better. Workin on lowering the rear then I’ll make some rubber mounts.
    Stogy likes this.
  25. wackdaddy
    wackdaddy
    Curious what you used to paint your ch***is and suspension components? They look good
  26. Omarsvette
    Omarsvette
    from Arizona
    Thanks. It’s a product called por-15. Extremely durable. And sticks very good. It’s a rust preventative product or if it’s already forming. They recommend to brush it on first then use an aresol for top coat. The brush comes in flat, satin, or gloss. I used gloss on the wheels, rear end, x member, bones, axle, and calipers. I used satin aresol on the ch***is only.
    You must wear gloves, it stains the skin for days. Can be mess to brush on especially if it’s a ****py brush. Best to apply in a couple coats. Is used satin on the ch***is because I might paint the car satin black....or gloss. Can’t decide. But I really recommend this product for those things
    wackdaddy likes this.
  27. Omarsvette
    Omarsvette
    from Arizona
    Mock set up. How high should I set the motor up? Also considering different valve covers. Or having mine chrome. I’m going to order a new pump from HH. getting my radiator today to see were I’m going to bolt the motor down. image.jpg
    Ron Funkhouser and AHotRod like this.
  28. Omarsvette
    Omarsvette
    from Arizona
  29. Moon50F3
    Moon50F3
    Stogy likes this.
  30. Moon50F3
    Moon50F3
    Well that post came out kinda weird. Guess I need more practice. That was me blabbering about por15, but I made it look like Omar said it.
    Pat
    lothiandon1940 likes this.
