Hot Rods Do I want this ???
Discussion in 'The Hokey Ass Message Board' started by larry k, Dec 31, 2018.
  1. larry k
    larry k
    Is this distributor and coil dependable for the road . Heard lots of bad stuff bout "em".
  2. TrailerTrashToo
    TrailerTrashToo
    The Pertronix II is much more reliable than the original module. The coil resistance (Ohms) must be matched to the stated coil resistance in the Pertronix II paperwork. I don't have that information at my fingertips.
  3. belair
    belair
    I love all of mine. Failures are often linked to mis-matched coils and stuff.
  4. larry k
    larry k
    All of this stuff came on a sbc , in a car I bought, I am a points ignition guy, never had points leave on the side of the road !pretty nice stuff to selling at the swap meet , I will use it if it won't let me down !
    chryslerfan55 and junkman73 like this.
  5. Well you haven't driven points much if you have never had a set of points fail. LOL
    The pretonix unit is good enough for everyday driving. I wouldn't be worried about it. If it were mine I would carry a spare control mod. We used to carry a set of points all the time and swapping out the control mod isn't any harder than swapping a set of points.
  6. upspirate
    upspirate
    If you think it will let you down, sell it or trade for a points dist
    Mine never did, but I matched the coil and wires
    lothiandon1940 likes this.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Mine failed and I had the correct coil but I figured out why my module failed, make certain you use a high quality copper wires. HRP
  8. They want proper voltage (may require a resistor), good wires and a good coil. Find the original information on the distributer, follow the instructions.
  9. wraymen
    wraymen
    Keep the points and sell me the set.
  10. aerocolor
    aerocolor
    from dayton
    Yup.
    Match the parts together .
    My first try failed within a few minutes.
    Wrong coil.
    We use them on all of our Ford engines.
    Never have an issue .
    chryslerfan55 and lothiandon1940 like this.
  11. Gman0046
    Gman0046
    Good thing about points is you can change a set on the side of the road. Nothing you can do with a failed module.
    F&J, chryslerfan55 and lothiandon1940 like this.
  12. You change the module. No harder than changing a set of points, you pop the cap off two screws usually and set the air gap if you are running magnetic. Easy peezy. Actually if you are running a lazer unit (the petronix is magnetic) you don't even set the air gap.
    upspirate, Tim, chryslerfan55 and 2 others like this.
  13. wraymen
    wraymen
    How come everyone carries spare points but no one carries a spare module.
    upspirate, Tim, firstinsteele and 3 others like this.
  14. lothiandon1940
    lothiandon1940
    .............We're trusting souls and know that electronics never fail.:rolleyes:
    warhorseracing and chryslerfan55 like this.
  15. wraymen
    wraymen
    Tongue in cheek, I trust nothin' ......and carry a spare module. Fits my Chevy and my Ford. Keep it in my tool box.
  16. aerocolor
    aerocolor
    from dayton
    I do. Doesn't take up much room.
    Also carry one pushrod, rocker arm, rocker nut, tire plug kit and spark plug.
    Funny, the '35 Chevy is the only old car I own that has a spare tire.
    No room in any of the '32's.
  17. larry k
    larry k
    Is there a web site I can go to and check to see if this coil is the right one ???
  18. fol
    fol
  19. Mr48chev
    I carried a spare HEI module in the glove box of an ot rig for years and had to replace the one in distributor a few times but it wasn't a module issue when I finally got it sorted out As others said electronic mpdule failure is usually because there is another issue that caused the failure.
    I'm not knocking points though. back a number of years ago I helped a young family in a Dodge pickup he had borrowed from his dad to move with get the truck going on the side of the road in Wyoming by filing the points with his wife's side kick's emery board and setting them with a match book cover. They were pretty well fried but we go it going and they made it the 11 miles to Little America and would probably have made the rest of the trip without another issue.
    lothiandon1940 and wraymen like this.
  20. I don't carry a spare tire or parts.{ Limited Space } Just a small tool set, fire extinguisher, duct tape, wire, and some fuses. But what works for me is, to call a friend.;) They know they can call on me anytime also. I had a friend recently help me. When my starter motor failed on my 34 delivery, about 10 miles from home. He brought a jack, tools, and took me to the parts store too. Thanks to fellow HAMB'er, { Oh Henry } THANKS Gene ! :) Ron....
  21. Hotrodmyk
    Hotrodmyk
    I have a Pertronix II with a lot of miles and no issues.
  22. DDDenny
    Just thinking out loud here.
    How many MILLIONS of miles were driven with points type ignitions across all OEMS for X number of years with nary a thought of carrying a spare?
    54vicky, Bugguts, F&J and 1 other person like this.
  23. lonejacklarry
    lonejacklarry
    The only time it crossed my mind was when I needed a set. Funny, how that works.
  24. dirty old man
    dirty old man
    I haven't had a vehicle with points in a long time. Last one with points was an OT '73 GMC 4wd and I put the early MSD that used your points to trigger the box instead of a module on it and went from a new set of plugs and points every 8000-10000 miles to 40000-50000 miles for plugs. )ints only triggered box so all it took was resetting gap and lubing dist cam.
    Folks on here have complained for a long time about only being able to get Chinese made points of questionable quality, but I just don't have any personal, first person experience on that.
  25. vtx1800
    vtx1800
    The only ignition failure I've ever had was on the return trip from the Street Rod Nationals in OKC, about 1984? I was about 15 miles from home and the 38 started missing and then died. The guy that was with me popped the distributor cap off of the Accel Dual Point distributor and s****ped the points with his pocket knife and I drove it a couple of more weeks before I put new points in. The bushings were out of that "high performance" distributor in 20K miles. Sold it at a swap meet with some parts they warrantied me that broke. I am running a Petronix III now. No one (other than you guys reading this and a few other guys) that the rev limiter is set at 5500 RPM to save me from myself.
  26. blowby
    blowby
    from Nicasio Ca
    Pertronix does not recommend solid core wires, especially with the Ignitor II.
    https://www.jalopyjournal.com/forum/threads/pertronix-and-copper-core-wires.391152/
    Because then they couldn't ***** about being stranded by their Pertronix. :)
    upspirate and wraymen like this.
  27. Hollywood-East
    Hollywood-East
    I drove a 61 356 Porsche from NY./ Ca. 3 month's up/down the coast an back to NY. Trouble free.... Run it!
  28. Rusty O'Toole
    Rusty O'Toole
    I've been driving since 1966 and never had points ignition let me down. But, I don't run them until they fail either. Do a tuneup every couple of years and you won't have much trouble.
    I did have an electronic ignition module fail on a 22 year old pickup truck with 160,000 miles on it.
  29. bchctybob
    bchctybob
    The only on the road ignition failure I've ever had was a condenser in my '60 T-bird. I've run MSD and Pertronix ignitions for years with no problems. I have a Pertronix stock appearing distributor and coil in my '56 Chevy and it starts and runs better than it did with the stock ignition by far.
    Go to their website, read about it and follow their recommendations to the letter it'll work fine.
    belair and upspirate like this.
  30. I run Pertronix in all of our tractors, my 1953 IHC dump truck, my O/T Ford Van, and they work great and never had a problem. That’s a total of 8 of them on our farm. They all have the correct ohm coil and correct plug wires for the application. I will never own another set of points.
