### Customized 50's and 60's Tonka Trucks ###
Discussion in 'The Antiquated' started by A Boner, Dec 31, 2018.
  1. A Boner
    A Boner
    image.jpeg Drill 2 new front axle holes.....end up with a cool California Rake!
    Deuces, Spooky, VANDENPLAS and 8 others like this.
  2. RidingMechanic
    RidingMechanic
    from Cincinnati
    ya know, that's not a bad idea...I ended up with a truckload of not-very-valuable Tonka and Structo trucks. Would be interesting to test out some custom body work or paint on 'em.
    As a kid I had a similar Wrecker, but it was the slightly later 68-72 GMC style. I wanted to repaint it and replace the broken plastic headlights...got as far as taking it apart and stripping down to bare metal. 30 years later I found it in a paper bag when cleaning out Mom's attic.
    Even back then I could never finish a project!!
    34 GAZ and pigIRON63 like this.
  3. Rolleiflex
    Rolleiflex
    I've got that same truck that someone painted the whole thing green, tires and all. It'd be a perfect candidate for dropping.
    I've found a few online part sources for Tonka vehicles. I haven't ordered from any of them yet though and would love to hear which ones are great to deal with.
    Here's just one I've looked at: https://www.toydecals.com/tonka_parts.htm
  4. A Boner
    A Boner
    image.jpeg I would think if a parts supplier is on Ebay with a good rating, they should be ok.
    If you are missing hubcaps, I made moon disks using the bottoms of aluminum soda cans.
    The blackwall wheel hubcaps pry out of the rubber tires (soak in warm water). With the whitewalls, you have to carefully pry the whitewall out of the tire to remove the hubcap.
    Deuces, Spooky, Okie Pete and 9 others like this.
  5. I like to customize (play with ) the rough ones Too. Here's two Roadster pickups I did. Ron... 20190103_182404.jpeg 20190103_181953.jpeg 20190103_182259.jpeg 20190103_182217.jpeg
    Sent from my SM-G920P using The H.A.M.B. mobile app
    Deuces, Bdamfino, Okie Pete and 7 others like this.
  6. joncrane
    joncrane
    There was a Tonka truck kit to add a steam engine. I have been looking for one for years.
    pigIRON63 likes this.
  7. A Boner
    A Boner
    ^^^^^ Looks good.....all it needs is 2 axle holes drilled to give it the California rake!
  8. CaptainComet
    CaptainComet
    I have restored a bunch of first generation Hot Wheels. I have found that you may get lucky with kiddie painted items by simply dropping them in water for a day or so. Sometimes that extra paint will float off because it is rare that a kid would do actual surface prep. Best of luck with it!
  9. johnnyknox
    johnnyknox
    from illinois
  10. johnnyknox
    johnnyknox
    from illinois
  11. Ohlly
    Ohlly
    Nylint Jungle Wagon
    Deuces, A Boner, Okie Pete and 4 others like this.
  12. A Boner
    A Boner
  13. noboD
    noboD
    Tonka?? Is nothing sacred on the HAMB?
  14. A Boner
    A Boner
    Another red and white Tonka Pickup…lowered+Wisconsin style patina.
    Deuces, Spooky, Okie Pete and 3 others like this.
  15. A Boner
    A Boner
    Borrowed pic off Facebook group…Tonka Rod & Customs
    Deuces, Spooky, down-the-road and 4 others like this.
  16. A Boner
    A Boner
    Latest custom TONKA. Short box conversion…I shortened the wheelbase and moved the rear fenders ahead 9/16”…also moved the axle holes up to lower it!
    Deuces, Spooky, Rolleiflex and 3 others like this.
  17. A Boner
    A Boner
    Another short box.
    Here is a better pic of where the rear fenders used to be.
  18. A Boner
    A Boner
    Hot Rod dump truck?
    1. Before
    2. After
    3. Then lowered the front more, for a California rake!
    Deuces, Okie Pete and down-the-road like this.
  19. D type
    D type
    Try these folks for part's
    Gasoline Alley Toys
    Okie Pete and A Boner like this.
  20. A Boner
    A Boner
    Yep, they have lots of nice stuff!
  21. poco
    poco
    from oklahoma
    Got some that i would like to sell. Don
  22. raymay
    raymay
    A Nylint Econoline truck and a trailer I paired up for this custom build.
