Chevy II's
Discussion in 'The Hokey Ass Message Board' started by Shawn F., Sep 13, 2009.
  1. Nova Thug
    Nova Thug
    from SG Vizzle
    My initial concept was to use an existing GM metric ch***is and fit it to the Nova but the sacrifices to the Nova to accommodate the Gbody ch***is were way more then I wanted to inflict on the Nova. The GM front clip is not going to intrude into the Nova in any negative way. It’s the last part of the original concept that I have lingering on in the conceptualization. I’m actually working on a alternate front suspension option at this time. The core frame from the fire wall back is pretty well set and could be outfitted with different suspension packages as desired. So with that in mind the front suspension should be equally flexible.. The point of this exercise is to fortify the existing Nova unibody from underneath with very little modification to the Nova. The frame accommodates the body.
    1Nimrod and loudbang like this.
  2. cshades
    cshades
    from wi
    800 miles in 10 years, I think it deserves someone who will drive it more. The GF put most of those miles on it, she keeps promising to drive it more but doesn't. I am thinking hard about advertising it come spring.
  3. DDDenny
    Putting a full rectangular tube ch***is under a Gen. I/II car is pretty tough to do without some major mods to the floorpan unless ride height/ground clearance is not an issue. From the firewall forward it's not a big deal so I don't understand why you would graft an oem front stub to a fabricated frame.
    My 67 has about the closest thing to a full frame with a rect. tube back half and custom front crossmember and suspension, as well as round tube subframe connectors and other mods, all with an uncut floorpan, the cars' ride height is at least four inches lower than stock without the use of air bags.
    My pal was a pro ch***is builder and actually built two 66 sedans for himself with full rectangular tube frames but the floorpans had been completely removed and replaced with all new sheetmetal, it sat lower than mine and also did not use air bags.
  4. Nova Thug
    Nova Thug
    from SG Vizzle
    This is a project that is in the works and will evolve as it progresses. I have no interest is cutting up the factory floor. I’ve seen numerous 1st & 2nd gen Chevy IIs with back halves and subframe connectors that require cutting through the floor or complete removal. This is not an acceptable solution for me. It’s an unnecessary path that does not have to be the only way to achieve the goal. Don’t get hung up on the front GM clip. That platform has been around for a long time and is used in all kinds of compe***ion environments. It offers a lot to of benefits for a budget build which is where I started with my initial concept. Ride height is indeed a prime concern for me and is going to be lower then stock but by how much is yet to be determined. I will most likely be running coil overs all the way around. No airbags for me. This is a performance minded build not a parking lot poser..
    1Nimrod, raven and loudbang like this.
  5. DDDenny
    I totally get the whole work in progress deal, my car has actually been through a couple of different iterations in the 35 years I've owned it.
    I'm not hung up on anything someone wants to do on their car, but (just my opinion) using that front stub after building a tube ch***is is like taking a bath and putting on dirty underwear.
    Like you, I too did not want to alter my floor/trunkpan and other than widenining the rear wheel tubs two inches, the only mod were these two small tunnels under the stock rear seat.
    Not HAMB friendly so I won't go into detail. 20170903_112224.jpg 20170903_111808.jpg 20170903_114420.jpg
    1Nimrod likes this.
  6. Nova Thug
    Nova Thug
    from SG Vizzle
  7. Nova Thug
    Nova Thug
    from SG Vizzle
    Think of like this, American Stamping makes reproduction ‘32 frame rails. You can set them up anyway you like from an all original configuration to highly modified suspension and inner framing members. The choice is as your discretion, preferences, and budget will allow. The rails still fit the a ‘32 body. What has been done between them is subject to the desires of the owner/builder.
  8. pragmatist
    pragmatist
    I keep waiting for the HAMB to add a year or two to their cutoff so I can post my 67.:p
  9. I'm Ford through & through, but these 1st gen Novas really check all the boxes for me.
  10. DDDenny
    I'm with ya!
    1Nimrod likes this.
  11. harpo1313
    harpo1313
    from wareham,ma
    call it a 65 ,same body style.
  12. harpo1313
    harpo1313
    from wareham,ma
    My neighbors son has a 66 ss ragtop 6cyl auto , will get some pics next time he visits in the spring , never been touched.
  13. Nova Thug
    Nova Thug
    from SG Vizzle
    ‘63 was the last year convertibles were produced.
    1Nimrod, loudbang and FlyingRN like this.
  14. Nova Thug
    Nova Thug
    from SG Vizzle
    I know you’ve got a lot of work in yours man..
  15. Nova Thug
    Nova Thug
    from SG Vizzle
    BEA43131-6985-4945-939E-5FB4004F84D3.png So I came upon a post recently and thought I’d share it. The circle track crowd has a new cl*** of compe***ion called “Vintage Outlaw” and it uses ‘72 and earlier bodies on modern racing ch***is. Being a Nova enthusiast this build is relavent as it is based off of a 64 hardtop.
    1Nimrod, Roadsir, willysguy and 2 others like this.
  16. harpo1313
    harpo1313
    from wareham,ma
    didn't ask him the year , were backup lights optional 63 and earlier? I was mostly curious about it being a six.
  17. cshades
    cshades
    from wi
    You interested?
  18. Interested but not a player, have too many Ford projects.
    Canadian dollar ****s right now to.
    That is a good looking car you should have no problems selling it.
  19. Nova Thug
    Nova Thug
    from SG Vizzle
    Back up lights were not optional. 62, 63, & 64 the back up lights were located in the two tail light fixtures. In 65 models the back up lights moved to the rear deck lid with 4 light fixtures. 66, 67 returned back to a two tail light fixture configuration.
    62-64
    65
    66-67
    1Nimrod, harpo1313 and loudbang like this.
  20. DDDenny
    In case someone pipes up and says "I've seen some 66/67 Nova convertibles".
    There have been quite a number of them built over the years, some real nice ones that are pretty convincing. The ones I first remember seeing were based on the 62/63 bodies with replaced panels, and if I remember correctly there have been some made directly from the 66/67 style.
    There also have been a number of station wagons converted to both two door wagon and deliveries. They were never offered from the factory though I saw a wagon on the internet that was pretty convincing too some years ago.
  21. If anyone wants the '63 parts of a convertible to build another '65-6-7 phantom rag top, I have the sheet metal in my junk pile (cowl, windshield, top surround and rear quarter tops). Always planned to use them, ain't goin to get there.
  22. 33 cdan man
    33 cdan man
    Not the same. 65 was the last year of the first gen body. 66 & 67 were the second gen style.
  23. DDDenny
    I'm not worthy!:(
  24. 33 cdan man
    33 cdan man
    Me either.I have two 66's
    Deuces likes this.
  25. 29moonshine
    29moonshine
    I have seen a 67 and 63 wagon turned into a el camino both looked good
    Deuces and loudbang like this.
  26. 409deuce
    409deuce
  27. Flamed48
    Flamed48
  28. hog mtn dave
    hog mtn dave
  29. DDDenny
    Very nice.
    And let me say; I'm happy to see more Chevy II activity on the HAMB.
    Deuces likes this.
  30. 40ragtopdown
    40ragtopdown
    1Nimrod, Deuces, AHotRod and 2 others like this.
