Drag Racing with Ford Y-Block
Discussion in 'The Hokey Ass Message Board' started by Hollow Head, Sep 5, 2012.
  1. Hollow Head
    Hollow Head
    from Finland
  2. teddyp
    teddyp
    much love for the y-block
  3. rob lee
    rob lee
    from omaha,ne
    Nice!,Thanks for posting.
  4. Very cool! What length track is that?
  5. Hollow Head
    Hollow Head
    from Finland
    Full 1/4 mile. We run 6.05 at 1/8 mile couple of months ago, but then we had no so much boost and start was with only 3500 rpm. Now we had 4500 rpm and a stage limiter working.
  6. Heo2
    Heo2
    God work neighbour
  7. danielpreciad
    danielpreciad
    from london
    Now we had 4500 rpm and a stage limiter working.[​IMG]
  8. Hollow Head
    Hollow Head
    from Finland
    Sorry, if I was confusing someone. We have 4500 rpm at the staging line to get boost raising and revs are limited by Crane HI-6 ignition control unit simultaneously as trans brake is applied. Our max rpm was limited to 7000 rpm by Crane Xr-i module inside of the distributor.
    And neighbour, God will never get a chance to touch our ride :D.
  9. 57Custom300
    57Custom300
    from Arizona
    Way cool! Yblocks are awesome even if they're running sundown times.
  10. Modest
    Modest
    from Loomis ca
    Nice!love y blocks!
  11. ynottayblock
    ynottayblock
  12. Marty Strode
    Marty Strode
    Hollow Head, Who holds the world record? This dragster belongs to Bob Lindsay from here in Oregon. It is shown here with the injected engine, when he installs his "blown alcohol" Y-block, it has run in the 7's at almost 180!
  13. Normbc9
    Normbc9
    Y-blocks have great potential. Even in this era they are real compe***ors if the engine work is done correctly and the drive train matches the power/torque out put. There is even a Y-block group that meets annually and has racing events. Fun time, good compe***ors and a lot of enthusiasts too. These 312's and 340's are just a sample.
    Normbc9
  14. Hollow Head
    Hollow Head
    from Finland
    Bob Lindsay drove 7.966 with that dragster and our goal is to beat that record some day. Will it evr happen... who knows. But we sure have some more power to come after we get our heads O-ringed....
  15. Hollow Head
    Hollow Head
    from Finland
    Here is the dyno sheets from last spring. We had to pull back when boost started to raise unexpectedly as we openet the turbo screw for 1/4 turn :D
  16. Hollow Head
    Hollow Head
    from Finland
    After couple of disappointing years we finally got little progress. 8.644 / 245.03 is now new European Ford Y-block record. Still with E85 fuel.
    10474121_541375635961939_2007557210997820520_n.jpg 10576960_541375732628596_631118084539203872_n.jpg
    loudbang and RichFox like this.
  17. ronnieroadster
    ronnieroadster
    Very nice your dedication has payed off.
  18. Yfreak57
    Yfreak57
    from Finland
    Update!!!
    Our new record is 8.253s @165,5 on 1/4 mile and 60f 1.187s!!!
      614.7 KB
  19. Saxxon
    Saxxon
    This is my Scout running against the Y Block powered Thunderbird roadster. The roadster ran well but it was the phase on the back of it that got my attention - "Y Blocks - The trailing edge of technology"
    Good thing the roadster ran well as a minute later I almost landed on top of it when the wheelie bars broke and I swapped lanes with the front end 4' in the air.
  20. jimmy six
    jimmy six
    "World" records are only important to 2 people. The one that has it and the one that wants it. To the rest it's great information. This is from someone who has a "World" record at Bonneville in a cl*** only a few care about. :rolleyes:
  21. Hollow Head
    Hollow Head
    from Finland
    And then the freeze plug flied on the right....
  22. Atwater Mike
    Atwater Mike
    Bless the 'Y' block!
    When a young 'teen still in high school, Chevies were all the 'rage'..."Ford??? You drive a Ford???"
    I was 'shamed' in the San Jose area for working hard on one, a 292 'Y' in a '56 Ford convertible, T86 3 speed overdrive.
    I turned pistons around, c.c.'d heads, matched ports, selected a Cal cam/set cam timing, and a slew of other things, all with a factory intake & teapot carb. (lotsa work on carb)
    In 1959 my Ford was a Chevy Eater...Torque and RPM. Seems like light years ago...
    Fremont digs turned 92 in low 14s...mufflers & street tires...(C/stock)
    Got protested, wasn't s'posed to go that fast...
    Compe***ion may not have been as 'stiff' then, but in 'popularity' it ranked right down there with Al Gore, whoever he was?
    Ex wife called it the 'White Rat', she loved Chevies and didn't even drive... (blind faith)
  23. Yfreak57
    Yfreak57
    from Finland
    2016 first record run... After that we improved to 8.134 s and 274 km/h (170 mph)!!!
    chryslerfan55 and cactus1 like this.
