Technical Gorilla Glue vs Loctite vs JB Weld vs Flex Glue
Discussion in 'The Hokey Ass Message Board' started by blowby, Jan 4, 2019.
  1. blowby
    blowby
    from Nicasio Ca
  2. junk yard kid
    junk yard kid
    Deuces, robracer1 and loudbang like this.
  3. tubman
    tubman
    I'm not gettin' in that guys boat!:eek:
    Elcohaulic, XXL__, belair and 5 others like this.
  4. WB69
    WB69
    from Kansas
    I've had the most luck with JB Weld.
    Deuces and lothiandon1940 like this.
  5. blowby
    blowby
    from Nicasio Ca
    Maybe not the best comparison, two part epoxy vs. flexible but interesting non the less.
    Great back story on JB Weld
    https://www.jbweld.com/pages/about
    HOW IT ALL BEGAN: A MOM AND POP OPERATION
    The J-B Weld Company was founded in 1969 by Sam and Mary Bonham. Sam had discovered a need for a “cold weld” product to use in his truck service garage, instead of traditional torch welding. Working with a Texas A&M chemist, he formulated an original “tougher than steel” two-part epoxy and named it J-B Weld. Sam and Mary soon went from selling the product out of their car to auto parts jobbers across Texas, to selling it in stores throughout the U.S. and internationally.
  6. Texas Webb
    Texas Webb
    If I ever put tile in the car,JB for sure:D
  7. In general, any 2-part epoxy will outperform any "1-part" sticky.
  8. williebill
    williebill
    Haven't watched the video yet, but I can tell you from first hand experience this past week that if you have Gorilla tape on the holes in your jeans side pockets, TSA will take a serious look at you in the Phoenix airport. The guy wasn't impressed when I told him it held up to multiple washings, either. That was about the time he was rubbing his hands all over my pants, and not in a way I cared for.
  9. Always had good luck with jb-weld
    Once worked in a shop where the customer really pissed off the mechanic for some reason.
    Mechanic was doing a diff service on a full size Chevy pick up and job-welded the cover on after the service !! Gave him **** for that as your not ******* anyone off except th next guy working on the diff and real easy for the owner to pin it back on us. Reall ***hole thing to do. But after watching this video probably better off to s**** the diff then even try and pull the cover off.
    blowby likes this.
  10. mark latham
    mark latham
    The guy that did this video has a whole series on You-Tube testing lots of things like seafoam, Marvel Mystery Oil, pouring water through the carb to blow out carbon deposits, and so one. He's no scientist but he does a god job destroying lawn mowers for our entertainment and education.
    belair and blowby like this.
  11. Rickybop
    Rickybop
    Oddly enjoyed watching that. I must be easily entertained.
    Thanks, blowby.
    Tell me, guys. Does JB Weld hold up to high heat? Would you, for instance, use it to patch an exhaust manifold?
    blowby likes this.
  12. pitman
    pitman
  13. blowby
    blowby
    from Nicasio Ca
    Cool, I'll look forward to checking them out. thanks!
  14. Depending on what your gluing, I've had really good luck with "GOOP" adhesive.
  15. Hank37
    Hank37
    JB stopped coolant leak from headgasket at front edge of block on customer's car , he didn't want to replace gasket .
  16. Rickybop
    Rickybop
    Thanks for the link, pitman.
    Ok, so even though the "high heat" JB is recommended for exhaust manifolds, anything above 400* is questionable.
  17. rwrj
    rwrj
    from SW Ga
    Hahahahahaaaaaaa. I just laughed out loud at that. Made my day.
  18. RonaldStevens
    RonaldStevens
  19. Torana68
    Torana68
    from Australia
    Any contact is better than none?
    Testing a two part epoxy against flexible glues seems a bit odd to me , if I get the urge to stick a bolt to a piece of metal I’ll get the mig out.
  20. lostn51
    lostn51
    from Tennessee
    Honestly I have never had any luck with the quick fix stuff so I just toss the part or break out the welder. :oops:
