Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. greaser
    greaser
    Another awesome job from the shop of many tricks and talents. You never cease to amaze me!
  2. roseville carl
    roseville carl
    Thanks but its just that ol saying "jack of all trades, master of none"
    loudbang and Gammz like this.
  3. roseville carl
    roseville carl
    well well, ugly but just another one of those days
    and got a little done on the other head, now to pull this ***** apart and see what else we have to enjoy........
  4. 64 DODGE 440
    64 DODGE 440
    from so cal
    Ya need thicker sleeves Carl.
  5. roseville carl
    roseville carl
    need better block
  6. greaser
    greaser
    Sometimes they fight ya, but your determination will overcome.
  7. 64 DODGE 440
    64 DODGE 440
    from so cal
    Ya gotta kiss a lot of frogs before you find the princess.
    loudbang and RidgeRunner like this.
  8. roseville carl
    roseville carl
  9. blowby
    blowby
    from Nicasio Ca
    Carl, does that LED light setup on your helmet help much?
  10. roseville carl
    roseville carl
    A lot and it was free at HF, now ifn I can only get rid of the shakes I get lately...........
    rpm56 and loudbang like this.
  11. roseville carl
    roseville carl
    OahuEli, 48fordnut, j-jock and 5 others like this.
  12. blowby
    blowby
    from Nicasio Ca
    Nice, I'll give it a try. I have 14 of those...
    Did you preheat the head before welding? Argon or mix?
    OahuEli and loudbang like this.
  13. roseville carl
    roseville carl
    welded the outside before the inside which preheated the inside, worked well, Argon, Miller 200 Syncrowave,
    now on to da sleeve............ Ug
  14. roseville carl
    roseville carl
  15. Looking good Carl . . . get that ****er back on the track! Hey - was out of town when you left a message, just saw it yesterday - give me a call when you have time!
  16. roseville carl
    roseville carl
    well still at it...... 20190109_133357[1].jpg 20190109_135945[1].jpg 20190109_140001[1].jpg 20190109_171523[1].jpg 20190109_171547[1].jpg 20190109_171550[1].jpg
    greaser and loudbang like this.
  17. roseville carl
    roseville carl
    update...... cleaned up a little
    took old sleeve out. Hammer and chisel method ..........
    guess i figured out wha happened, looks like block rock didn't rock block...... will fill voids with aluminum this time
    but bearings and lower look great so thas a good thing....... 1 10 2019 1 (3).jpg 1 10 2019 1 (4).jpg
    on to new sleeve bore and hone and put er back together!!!!
    blowby, loudbang, Gammz and 1 other person like this.
  18. Aside from WOW, I can't think of anything to say..............Good luck on the fix.
  19. roseville carl
    roseville carl
    Oh **** did I say there were two sleeves cracked??? another place where block rock failed me........plus crack repairs ug this **** ****s 1 14 2019 1.jpg
    hole for aluminum fill
    and some cast welding............think maybe its time for new block next time.....................
  20. Ebbsspeed
    Ebbsspeed
    Keep on keepin' on Carl! Ain't retirement great?
    I like the gear reduction drive on your engine stand, need to do that to mine.
  21. roseville carl
    roseville carl
    OahuEli, 48fordnut, UNCLECHET and 2 others like this.
  22. patsurf
    patsurf
    prob killed you to use chevy parts.....
  23. roseville carl
    roseville carl
    Na besides boat anchors they do have their uses...........
    OahuEli, loudbang and rpm56 like this.
  24. roseville carl
    roseville carl
    sleeves in, block poured, ready for re***embly.............sort of 1 19 2019 (1).jpg 1 19 2019 (2).jpg 1 19 2019 (3).jpg 1 19 2019 (4).jpg 1 19 2019 (5).jpg
    loudbang, Johnny Gee and Gammz like this.
  25. RichFox
    RichFox
    Somebody stole your idea. And I'm not sorry. I love it. Lincoln Y block gears. US winch. Thanks. DSCN0001.JPG
    OahuEli, 48fordnut and belair like this.
  26. RichFox
    RichFox
    As long as you are filling it up with Hard Block anyway. I wonder if it would be better to hole saw 3 or 4 holes in the outside of the water jacket to get a better shot at filling all the nooks and crannies?
    ottoman likes this.
  27. roseville carl
    roseville carl
    probably would have been better Rich, but block isn't worth it have another block ready to go, just need to port it bore it ect will do all that while using this one one more time..........
    Yesterday was a good day, hope to start her today........
    1 21 2019 (1).jpg 1 21 2019 (2).jpg 1 21 2019 (3).jpg 1 21 2019 (6).jpg 1 21 2019 (8).jpg 1 21 2019 (9).jpg
    j-jock, loudbang, ottoman and 5 others like this.
  28. roseville carl
    roseville carl
    Oh Oh.............
    OahuEli, jimmy six, j-jock and 5 others like this.
  29. Nice repair job, disappointed to learn this happened after all the beautiful craftsmanship on the first build. I hope the rebuild is going to do the job for you. I'm looking to hear it run.
    Bob
  30. Sounds great!
    Bob
