Projects New build for TROG
Discussion in 'Traditional Hot Rods' started by Lucky77, Jan 5, 2019.
  1. Lucky77
    Lucky77
    I’ve been flogging my roadster on the sand in Wildwood for the last four years. It’s time to build a new one so I grabbed some steel and a ****py old ‘27 T roadster body I had. Here’s what I have so far. TROG May be ten months away, but the Detroit Autorama is in less than 8 weeks so I’m gonna be busy. IMG_0434.JPG IMG_0435.JPG IMG_0436.JPG IMG_0437.JPG IMG_0438.JPG IMG_0439.JPG IMG_0441.JPG
    Latigo, chriseakin, mctim64 and 25 others like this.
  2. Lucky77
    Lucky77
    IMG_0443.JPG IMG_0442.JPG IMG_0446.JPG IMG_0447.JPG IMG_0448.JPG IMG_0449.JPG
  3. Lucky77
    Lucky77
    Latigo, chriseakin, mctim64 and 24 others like this.
  4. flatford39
    flatford39
    What a shop... I am here to stay.
    nunattax, Stogy, Texas Webb and 2 others like this.
  5. Lucky77
    Lucky77
    It belonged to a HAMBer who’s no longer with us (Fab32) his wife was kind enough to let me set up shop here.
    97, robber grin, wheeldog57 and 18 others like this.
  6. glorydime
    glorydime
    from Austin, TX
    Lucky77 likes this.
  7. cball
    cball
    Neat project!
    nunattax and Lucky77 like this.
  8. Jalopy Joker
    Jalopy Joker
    looking great - only takes about an hour on TV shows
    hotrodtom, Stogy, slv63 and 2 others like this.
  9. Mr48chev
    That is going to be killer when it is done and have "the look" to boot. And a reminder to me that I need start busting my **** on mine as I have six months to get it on the road. It won't make it to Trog though a it has too many spark plugs in the row.
  10. Lucky77
    Lucky77
    As long as it’s a flathead. I’ve seen some straight eight and bigger cars out there.
  11. brady1929
    brady1929
    Man, you are living a great life. Looks great.
    Stogy and Lucky77 like this.
  12. GordonC
    GordonC
    I love the way some of you guys can knock out a car for this event or that event like its nothing! It keeps me inspired to get my *** off the computer and out in the shop and finish up my car!:D
  13. rusty rocket
    rusty rocket
    Looks fast just sitting there.
  14. Lucky77
    Lucky77
    Made a little progress before heading to work. I swapped in the transmission I’ll be using and mocked up a torque tube. I was worried about misalignment with the ch***is being this low, but I think I’ll be alright.[​IMG][​IMG][​IMG][​IMG]
  15. Kiwi 4d
    Kiwi 4d
    Love the look . If the flathead sits where it appears you will need a dam in the Torque tube to stop the oil from the rear axle flowing into the transmission . Tardel and sea bright hot rods make something and probably others. Even with a stock frame and a mild 4” axle and rubber rake oil flows forward.
    Though you probably were already aware of this.
  16. Lucky77
    Lucky77
    Actually I wasn’t, thanks for the heads up. This is only the second torque tube car I’ve built and I hadn’t even thought of that.
    Ron Funkhouser, Stogy and rpm56 like this.
  17. flatheadpete
    flatheadpete
    from Burton, MI
    Lookin' good. It better...Frank is watching. ;)
  18. Squablow
    Squablow
    Love the build. Body looks like a creampuff by my standards. Looking forward to seeing more.
  19. Kiwi 4d
    Kiwi 4d
    Will keep an eye out for you when we get to Wildwood in October.
  20. Bandit Billy
    Bandit Billy
    You mentioned the word Flog
    That I note rhymes with Trog,
    I'll will be following your Blog,
    With a nice mug of Grog.
    Sincerely Bandit...and Frog.
  21. Lucky77
    Lucky77
    It’s actually pretty rough, basically just good enough for a racecar body, but I’ve definitely seen worse.
  22. Lucky77
    Lucky77
    I’m planning on showing it at the Detroit Autorama in seven weeks[emoji15]
    Stogy and spurgeonforge like this.
  23. rpm56
    rpm56
    Did you fab the rear crossmember from rectangle tube? Love your shop, and your work.
    chryslerfan55 and Lucky77 like this.
  24. Lucky77
    Lucky77
    Thanks! Yeah it’s just 2X4 .125 wall like the rest of the ch***is with one side cut off. It’ll get boxed in and gusseted as well. The shop belonged to Fab32 he was a prolific HAMBer and my mentor. When he p***ed away his wife was kind enough to let me set up in his shop.
  25. loveoftiki
    loveoftiki
    from Livonia,Mi
    Looks awesome...and I’m always amazed at how fast you get things done..one question...is it to low to run on the sand?
    Lucky77 likes this.
  26. Lucky77
    Lucky77
    Thanks man! I love the thrash! And I work a 3 on 3 off 12 hour swing shift for my regular job. Yeah I’m definitely getting stuck, it’s getting some sort of pan or flat floor on the bottom of the frame.
  27. Tin Lizzie
    Tin Lizzie
    from Ohio
    Go ! Go! Go!
    Lucky77 likes this.
  28. heavydumper
    heavydumper
  29. Great work on this thread!
    Poetry not so much.:)
  30. Bandit Billy
    Bandit Billy
    ^^^there's always a critic in the room :cool:
