Motion Pictures Small block engines, Picture thread
Discussion in 'The Hokey Ass Message Board' started by Flogknaw, Dec 18, 2018.
  1. sunbeam
    sunbeam
    So what's the criteria for small block? A Studabaker never got bigger than 289 but weighed 25 lbs more than a 500 Cadillac.
    enloe likes this.
  2. robber
    robber
    An easy visual determiner... small blocks typically have center exhaust ports next to each other while big blocks have exhaust manifold ports evenly spaced... :) cp 925.JPG
    loner2, Stebo27, enloe and 5 others like this.
  3. Evenly spaced like 221-351W Fords. JW
  4. sunbeam
    sunbeam
    You mean like that 700lb Cadillac in your picture?
  5. RmK57
    RmK57
    It should be block deck height. Oh, I'd say 9.6 should be the cutoff point.
  6. BigO
    BigO
    My old Model A with 289. R.I.P.
  7. sunbeam
    sunbeam
    For overheads a flat head is over 10" and weighs 550
  8. robber
    robber
    Good point, I stand corrected... Fords are evenly spaced. I should have probably thought this through a bit more. My visual comment was referring to period correct GM motors, and even then there may be exceptions to the rule that I didn't think of.
    loudbang and 26 T Ford RPU like this.
  9. robber
    robber
    Yes... this Caddy is a small block and yes they are a**** the heaviest GM small blocks. Who cares, it's COOL!
  10. robber
    robber
  11. robber
    robber
  12. robber
    robber
  13. Lumpy Camsworth
    Lumpy Camsworth
    327 for a 62 Corvette. Looks like a 300hp on the outside, but the inside says it's a 340hp. IMG_20181209_130355.jpeg IMG_20181209_130322.jpeg IMG_20181103_194717.jpeg
    Sent from my Nokia 6.1 using The H.A.M.B. mobile app
    loner2, Stebo27, enloe and 10 others like this.
  14. Black_Sheep
    Black_Sheep
  15. 427 sleeper
    427 sleeper
    loner2, Stebo27, enloe and 8 others like this.
  16. DDDenny
    Deuces and Lumpy Camsworth like this.
  17. loudbang
  18. loudbang
    1962 Fuelie
    1963 Fuelie
    loner2, Stebo27, enloe and 7 others like this.
  19. sunbeam
    sunbeam
    I keep seeing early Olds and Cadillac as small blocks they are wider and heaver than a 454.
  20. I think that it is because of their relatively small displacement more than their physical size.
    1947knuck, Deuces and loudbang like this.
  21. ShortyLaVen
    ShortyLaVen
    Lots of great looking small blocks in this thread!!! Here the engine in my '60.
  22. captain scarlet
    captain scarlet
    from Detroit
    The heart of my coupe[​IMG]
  23. pecker head
    pecker head
  24. pecker head
    pecker head
  25. jbarker
    jbarker
    Nothing special. Just mundane stuff in my impalas. Numbers matching block in the convertible with long tube headers and stainless exhaust. 20181121_191619.jpg 20181121_191619.jpg 20181007_161439.jpg
  26. jbarker
    jbarker
    The 305 i got from a guys alley he was gonna s****. Originally a 82 crossfire. These engines have the HO cam and good heads with flat top pistons. I put a new timing chain in and some gaskets. No smoke and has good oil psi. Its now in my 64 until i get the 327 done. I beat the piss out of it and run it 3k on the interstate. FB_IMG_1547086689477.jpg FB_IMG_1547086898800.jpg
    loner2, enloe, cruiserjohn76 and 3 others like this.
  27. MercDeuceMan
    MercDeuceMan
    from Indiana
    loner2, Speed Gems, Stebo27 and 9 others like this.
  28. loudbang
    loner2, enloe and 1947knuck like this.
  29. loudbang
    265 paint
    283 270 HP
    loner2, Stebo27, loner1 and 7 others like this.
