Hot Rods Front end too low on a 1939 ford
Discussion in 'The Hokey Ass Message Board' started by wilnov, Jan 6, 2019.
  1. wilnov
    wilnov
    I just bought a 1939 ford coupe, sits too low in the front . Has a 4 " dropped axle and a reversed eye spring. Besides changing the front axle what can I do to raise the front a few inches? Thanks
  2. mitch 36
    mitch 36
    Pull the spring apart and un- reverse the main leaf. Simle procedure, just use the search function. That wouid be my first step. Maybe the previous owner removed too many leafs trying to tune the ride ?? Mitch
  3. redo32
    redo32
    If you ain't draggin', you ain't low enough.
  4. wilnov
    wilnov
    Thanks , but I dont have the tools to reverse the eye. I was thinking of replacing the main leaf with a stock one . Or someone mentioned installing a spacer between the spring and crossmember
    Atwater Mike likes this.
  5. Replacing with a non reversed eye spring would be my first change
    It’s the easiest
    AVater likes this.
  6. wilnov
    wilnov
    I was thinking the same , but not having luck finding a stock type of spring
  7. Posies doesn’t have one?
  8. alchemy
    alchemy
    Every 39 came with one and every hot rodder would rather have a reversed eye spring. Put a cl***ified ad on the HAMB to trade.
    olscrounger likes this.
  9. nugget32
    nugget32
    scrap metal 48 likes this.
  10. okiedokie
    okiedokie
    from Ok
    Tire size?
    X38 likes this.
  11. jimmy six
    jimmy six
    You don't "reverse" the eyes, you re-arch the spring back to original. A good vice and heavy sledge hammer is all that's needed. A piece of thick 1/2" steel with a section of a Grade 8 bolt welded to it would be better and easier. It's not rocket science.
  12. e z i
    e z i
    Yeah..pics..
    lothiandon1940 likes this.
  13. jimmy six
    jimmy six
    I don't have a spring apart to show photos. It takes time hitting the spring between the bolt and where it touches the plate. The distance should be 3-4" and hit it in the center moving the spring 2-3" between hits. It's easier to add arching in the same direction. To Reverse it, the process needs to be above the ground. I usually do it on the garage floor.
  14. Mr48chev
    It shouldn't be hard to find someone in the area who would swap springs with you. I would count leaves and compare the count for a stock spring for that car though as someone may also have removed leaves to get it that low.
    A search shows that there are a number of spring shops in your area with Somerset spring and ch***is LLC in Bridgwater being not much more than a beer run away.
    568 Central Avenue Building 3
    Bridgewater, New Jersey 08807
    Get Directions
    They can probably rework the main leaf or all of the leaves easily enough.
  15. 19Fordy
    19Fordy
    First, make sure you have the correct number of leaves for a '39 spring. If you do, reversing the main leaf back to original will raise the car 1 inch. Installing the stock axle will raise the car 2 inches. You could also add leafs to the stock spring but then you will need new U-bolts. You will also need longer U-bolts if you add a spacer. What size tires are you running? Installing the correct OEM tires and rims will raise the car too. If you want to do it right, install the OEM axle. Double check to see if your steering arms have been dropped. To avoid changing the axle you could also install a complete original 1939 or 40 Ford front suspension. They are frequently posted for sale.
  16. e z i
    e z i
    You can reverse the spring yourself in about 20 minutes with a cheap *** harbor freight press.. IMAG0513.jpg
  17. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Dropped axle and reverse eye spring shouldn't be too low at all on a 39.
    Post a pic.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    yeah, lets see a pic of the car, I can't imagine a 39 ford too low.....
  19. Atwater Mike
    Atwater Mike
    My wife does all of our spring leaves on a souped-up HF press. Air over hydraulic ram made it much faster...foot operated valve.
  20. wilnov
    wilnov
  21. wilnov
    wilnov
    Thanks for the feedback I located a stock spring that I'm installing
  22. slim39
    slim39
    from pa
    Call Stanley Spring Dayton Corp. Harrisburg Pa. They will have one or will make you one. They make the springs for Posies
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    have we seen a pic of the car yet? I want to see what too low is....
    Baumi, X38, 302GMC and 2 others like this.
  24. 19Fordy
    19Fordy
    First photo is of a stock 40 with stock OEM front spring. Click on the link and look at Post #3 which shows same 40 with only a Posie #2040 reversed eye spring installed.
    It lowered the car 1 in. You can barely see the rake. See first photo in post #3 in thread below. The "red wheels" photo is the way the car looks today.
    https://www.fordbarn.com/forum/showthread.php?t=77931&highlight=reversed+eye+spring
    Please post a photo of your 39.:cool: The OEM spring for a 39 and 40 Ford coupe was a 10 leaf spring,#01A-5310B. Number should be stamped on top leaf of the spring.
  25. You could add a little arch to the spring. Sometimes we forget that a spring can be arched as well as dearched.
  26. HOTRODPRIMER
    HOTRODPRIMER
    A 1939 /40 Ford too low, Blasphemy! :D HRP
    Moriarity and Paul B like this.
  27. Petejoe
    Petejoe
    from Zoar, Ohio
    More than likely the rear axle is too high.
    Show a picture.
  28. Pics
    Pics
    Pics
    Pics
  29. HOTRODPRIMER
    HOTRODPRIMER
    Looking at your other rides, they are all jacked up.
    We need pictures of this too low front suspension. HRP
    Blue One and Moriarity like this.
