Technical Will A 1963 Pontiac Grand Prix rearend bolt up to a 1961 Biscayne?
Discussion in 'Traditional Customs' started by oldschoolhemi, Jan 7, 2019.
  1. oldschoolhemi
    oldschoolhemi
    from Boring
    Hi all
    I need to get my sons 61 Chevy Wagon off my trailer (no rearend).
    If I recall correctly, my 1963 Pontiac rear is a bolt up, except it has two, instead of 1 half links. Any thoughts?
  2. No. Not even close, unless of course you are in Canada.
    No need to get into that it's too wide and 5 inch bolt pattern. Oh, the driveshaft and U joint won't fit either.
  3. low budget
    low budget
    from Central Ky
    Need to pick the backend up with a cherry picker, boom pole on a tractor, hoist tied to a big tree limb etc and drive out from under it while front tires role, then let it down on supports
    klleetrucking likes this.
  4. Flathead Dave
    Flathead Dave
    from So. Cal.
    Measure it out.
  5. Elcohaulic
    Elcohaulic
    The Pontiac is a four link..
  6. DDDenny
    Like some shop manuals are good for saying "reverse for ***embly".
    May have to rent a fork lift though!
  7. mrhp
    mrhp
    from MICHIGAN
    No it won’t. Sorry.
  8. 38Chevy454
    38Chevy454
    No, not a bolt-in swap. Different ch***is, different widths, different mounts, different bolt pattern. Get the idea this is not a bolt-in?
  9. oldschoolhemi
    oldschoolhemi
    from Boring
    Cool Thanks for the input
    My intent was to roll the wagon off the trailer. Not do a permanent install
    Thanks for the info. I was at a buds 6 or 8 years ago, he did it, but I've lost track of him and what all he had to do.
    All I remember is he had to put another upper link arm, as the chev has one, the poncho has two.
  10. oldschoolhemi
    oldschoolhemi
    from Boring
    Thanks man, I got that idea from the responses from all our brothers in arms.
  11. oldschoolhemi
    oldschoolhemi
    from Boring
    Thanks to everyone who took the time to respond to my question.
    I was just trying to get my trailer back. Was hoping for an easy solution.
    My intent was to roll it off my trailer. Not do a tree lift or fork lift.
    That's always an option, but puts a cork in the road.
    Just tired of waiting on my kid to buy his rearend (6 months) . And I have lots of Poncho.
    Happy Trails...
  12. oldschoolhemi
    oldschoolhemi
    from Boring
    Happy Trails...
  13. Look at it
    If all your looking to do is tool the car off your trailer,
    Just about anything can be made to fit with some long u-bolts a few bits of 2x4 and some macgyvering !
  14. ****, even a trailer axle would work!
    I moved my 50 Chevy around ar one point with the rear end out on axle stands set on moving dollies!
    How high or steep is your trailer?
    Can’t move it with a floor jar back there somewhere?
  15. Got the picture here now. But, seeing the Chev has the springs on the trailing arms, wouldn't it be easier to just rig up some small , hard wheels and bolt them to the arms?
