Technical 1961 Pontiac Hydromatic to a 455?
Discussion in 'Traditional Customs' started by oldschoolhemi, Jan 2, 2019.
  1. oldschoolhemi
    oldschoolhemi
    from Boring
    Im building a 455 to put in my 1962 Bonneville coupe. It came without a trans, with the 455 lying on its side on the front crossmember.
    I have a 61 Bonne with 389/automatic parts car. Is there a way to use its 4-speed automatic on my 455? The 455 is a 1974. Also looking for parts for this car.
  2. Elcohaulic
    Elcohaulic
    No..
    If you want to use the Super Hydramatic (315), you need to use the 64 unit.. I had a 64 Superhydro behind a built up 462 with ported 6X heads and 041 cam. It handled all that power without any issue. I eventually went to the Turbo 400 so I could wind out first longer.
    Frankly, I liked the overall performance with the hydro better. That cool "grounded" third gear lug is so nice.. I should of swapped cams from the 041 to the 068 instead of swapping transmissions.
    The overall swap from the good running 389 to the 455 wasn't what I expected it to be. I should of just left the 389 alone. If you have a good running 389 I'd use it. They are excellent street motors with the Carter AFB and there closed port heads. I used to pound freeze plugs into the exhaust crossovers to keep the intake cool Todays gasoline doesn't need or like to be heated!
    When racing with one of these ******s, you leave the lever in L and let the hydro do all the shifting.
    kidcampbell71 and Todd553 like this.
  3. Well, there's an adapter to go late trans with early block, because on 1964-back the starter mounts to a bellhousing while 1965 up bolt to the block. The ear was added in 1964, some even drilled and tapped.
    But you want to go late block with early trans and that may work, I would take a bell and see if it will bolt to the block. Guessing you'd have to run a bellhousing mount starter on it, so the next step would be seeing if one will mesh up to the flexplate.
    So far as I know all of the four-speed Hydros have a separate bellhousing that bolts to the trans case, so if you need the 1964 bellhousing to bolt to the block, that is the only part you need. But I believe that part is Bonneville only, I can't remember if the Gran Prix I parted out the slim-jim used them or not. It could have, but it could be different on the trans side for the different transmission.
    On the other hand a BOP case TH400 should be easy to find and cheap to have rebuilt, it may be simpler to just use one of those. I think it will fit under a Bonneville floorpan okay.
    Elcohaulic likes this.
  4. BJR
    BJR
    Don't bother messing with a Slim Jim roto hydromatic. Bolt the 455 to a Turbo 400 and drive the **** out of it. I have a 400 behind a 472 Cadillac in my 49 Buick and love it.
  5. Bonneville doesn't have the Slim Jim. It has the dual coupling Hydro that all 1960 cars used.
  6. Hnstray
    Hnstray
    from Quincy, IL
    Those trannies are not the cat's *** either. Often are replaced in stock applications by TH400 with an adapter ....readily available from Wilcap and others. Since the OP already has a BOP pattern engine block 455 the TH400 is a bolt on, no adapter needed and retrofitting the old Hydro would not yield any benefit.
    Old wolf likes this.
  7. Poncho60
    Poncho60
    from N Illinois
    61 thru 64 Bonneville & Star Chief would have the 4 spd super hydro in as built condition. Short wheelbase models got the roto rooter.
  8. oldschoolhemi
    oldschoolhemi
    from Boring
    Thanks for the responses. Sorry for the late reply to you all. Im slow learning the HAMB and how to interact with it. Wish I could figure out how to search for threads and parts.
    I liked the 4-speed hydro idea, for stock, and nostalgia. Turbo 400 is easy, guess Ill go down that path.
  9. oldschoolhemi
    oldschoolhemi
    from Boring
    Man you've got a sweet Bonny!
  10. oldschoolhemi
    oldschoolhemi
    from Boring
    Thanks!
    My 61 eng trans are in my parts car so it would be a bit to pull it and check.
    How do I search the cl***ifieds?
    I going in circles trying to figure this stuff out.
  11. Having driven both the Hydro is much more pleasant to drive. The problem with them is few know how to rebuild them or care for them.
