Projects Winter project- half ass 1956 F100
Discussion in 'The Hokey Ass Message Board' started by Chris, Jan 8, 2019.
  1. Chris
    Chris
    late this past summer I ended up buying a 1956 F-100 pickup. It ran and drove and I cruised it around while summer dwindled into fall, and kind of took inventory of what it needed and what I wanted to do to it. It’s a pretty original truck, one old repaint, rebuilt 223 6 with a factory OD. I wanted to build a mild custom- lowered, caps, chrome, merc tail lights, etc. what you may see cruising the streets or pushing a digger in like 1961. A few weeks ago I decided to get going, and started with the rear first. It’s half *** because I’m not restoring it, I’m trying to give it all I can as my time and budget allows. The truck needs some dent and rust repair. Some it will get, some it will wait. I just want to have it on the road by spring. Hang out if you want. I’ll try to update this as I go....
    This is what I am staring with, sits like a marmon Harrington. All the springs, suspension, shackles, pins are all new in this truck. Someone put a lot of time into it...and I’m gonna **** it all up
    166D2549-C1B5-4311-A0F8-AAF0C928FF32.jpeg 6C13583B-B40C-4770-888E-3021E3C0530C.jpeg BACC9FCF-A716-487F-894B-CAA82D384EC8.jpeg BAE7A1F8-C15B-47D8-AE3E-0D6849AB46DF.jpeg
    A week ago I started prepping the bed to come off. I removed what was left of the wood and started buzzing/breaking bolts
    2AB4312A-14FF-49C1-AB36-F90D06AE5008.jpeg A6A07D52-994B-4912-96D1-7815149DC2B8.jpeg
    This is my pile of springs and axle I had dropped.
    Once the bed was finally off, I used a wire wheel and wire brush to clean the frame the best I could. Then took advantage of a warm afternoon and washed the whole rear of the frame with simple green.
    I let it dry for a coupe days and removed the rear end, springs, and front spring hangers for the rear spring. Then started pairing it using some Zero Rust I had left over from another project. My lil buddy even chipped in on labor
    F3DFAF1F-1886-4172-A61F-CE352DEFCF19.jpeg C9F586FD-784E-43B4-A6EC-C6618679FDE1.jpeg 7DCBCDE7-AD99-42ED-BFFC-7F21697F5EA4.jpeg
    Tonight I installed some modified front spring hangers and longer rear shackles, along with Posie springs. I estimate the drop to be 6-7” total. With no weight on the rear the chrome running boards are 10” off the ground and plenty of clearance between the rear end and frame. The rear end is just mocked back in it, I have an early F100 9” going under it.
    C760D9DB-84F5-4D53-98D5-33325DC6B2FA.jpeg C41B7315-5112-4A28-8827-40B0869187BF.jpeg 1E996CA6-99D5-4D48-92C9-F9CF8EB4103D.jpeg 3B62401F-C0FB-4B53-AC27-53F7FA401256.jpeg C62A07C4-287E-4682-973D-AA1CE175579E.jpeg
  2. scotts52
    scotts52
    You're on fire with trucks this last year. Love the 56s. Looking forward to seeing it come together.
  3. BJR
    BJR
    Looks like you are starting with a nice solid truck. I like the direction this is going.
  4. Frankie47
    Frankie47
    from omaha ne.
    I love the simplicity of this dash layout. Could you post a few different angles please?
    OahuEli, greener200, loudbang and 2 others like this.
  5. catdad49
    catdad49
    Ok, great starter truck, great help, great plan. Redoing the suspension was made a lot easier because of the recent redo ( recoop money by selling to a restorer), the body looks like it needs minimal rust repair and you're spending quality time with a potential future hot rodder. Fantastic! Oh, almost forgot...... Chrome running boards! Now, where's that Digger.
    brad2v and loudbang like this.
  6. robber grin
    robber grin
    looks great!
  7. topher5150
    topher5150
    Seeing that pic of that kid helping out brought back a few fuzzy memories of "helping" dad on his 56 F-100, probably about the same age
  8. Go Swensons!
    scott27, brad2v and loudbang like this.
  9. HOTRODPRIMER
    HOTRODPRIMER
    Really like the truck and love the build it simple idea.
    The photo of the little guy painting is so cool! HRP
    catdad49 likes this.
  10. Latigo
    Latigo
    That is a nice truck. I like the direction you’re taking it. Had one once. Lots of fun.
  11. okndnx
    okndnx
    from Porum, OK
    this is a great truck
  12. Chris
    Chris
    Here’s all I have, 56 was a one year old cab and dash lay out. I am going to run a 59-60 Ford Custom Cab steering wheel (needs repainted white) and my friend Bruce found me chrome dash cluster, ash tray and glove box door. I’m having the seat and door panels done right now as well. I need to do some floor repair, and will clean that original paint on the dash and doors up the best I can.
    780A3AA6-5096-43DB-AA51-F6062C50767A.jpeg D4D76C6E-309C-4BF8-814C-07A7F87E1504.jpeg 79DD37CF-9092-4AD6-85AA-8AA4C7FAA7CC.jpeg
    scott27, 1947knuck, JUNK ROD and 16 others like this.
  13. Frankie47
    Frankie47
    from omaha ne.
    Wow....thank you Chris. If that were my dash I would fill the ash tray door, glove box door and hide the controls.....thank you again!
    46international and loudbang like this.
  14. Chris
    Chris
    Currently accepting donations for a FED :D
    scott27, OahuEli, loudbang and 2 others like this.
  15. Chris
    Chris
    My upholster sent me these pics tonight, he got my seat and door panels done! I wanted a mainly stock Custom Cab Interior, because I think it looks so *****in
    25341FA4-EE36-4CA4-8CDE-75DECDD8BFDA.jpeg 41041478-7C2A-4E21-ABF4-16539DF8C83E.jpeg 2D8A8BD7-59B2-4518-99D4-F0B7AE75DB7C.jpeg 4D63E9A5-475D-41B9-B3BA-E35CD8A70869.jpeg
    dwollam, scott27, 1947knuck and 17 others like this.
  16. Atwater Mike
    Atwater Mike
    My '55 F100's down right now, tore the engine mounts clean out! (needed to re-do those anyway)
    Really enjoying your approach to this, Chris! Chrome boards are the cat's ***...and, the F100 9" rear is a good fit. (my '50 Merc wheels are reversed with 6" Buick outers, 'taper-out'. Look GREAT with my new '50 Merc stainless 'Ash Can' caps...)
    I used a '59 F100 front axle, same width, but has nearly 1" more drop. Had to mill 1/8" inboard on spring bores, as '55 springs are 1/4" narrower.
    Wife dis***embled and flattened leaves in my 20 ton press.
    What are you going to use for wood in bed???
    scott27, brad2v, loudbang and 2 others like this.
  17. rob-redm
    rob-redm
    Chris, I did find the chrome heater box ***y.... its yours if ya want it.... The Chrome heater core face went with my old truck... I'm sure this 56 will be killer like most of cars you own...
  18. There are '56 Ford old chrome inner fenderwells for 200.00 on the Orange Co. Ca. Craigslist. You like old chrome.…:D
    scott27, OahuEli, brad2v and 3 others like this.
  19. Rocky
    Rocky
    Classified Editor
    Love it, Chris but w***up with the red and cream interior in a green truck? Was red and cream the only colors available with the custom cab interior? It'd look really nice with green and cream IMHO but it's your hauler.
    Hell, mine didn't have any upholstery except the bucket seats. 53truck.jpg 53truckred.jpg
  20. Chris
    Chris
    Oh man, I need those. Are they close to you?
  21. Chris
    Chris
    Yes, I believe red and creme was the only color in custom cabs, regardless of exterior color. My old 53 was dark green and had a red and light gray seat like factory. I’m not going for stock, but I do like loud contrasting colors of paint and interiors that so many 50’s hot rods and customs had. @Ryan shoe box is one of my favorites: a heavy creame and green exterior with orange and white interior. It’s not safe, and it reminds me of that colorful late 50’s. It’s not for everyone, but I like it. This interior will be mainly mint green an off white, with a splash or red and chrome
    197DFA5A-5EB4-43A2-9C97-7539EDD569CB.jpeg 5B5D7436-E517-4C61-9F51-AE3E7B5E9C09.jpeg
  22. Was that a thing back then, I also have a chrome glove box lid and ash tray (came with my old '54 panel).
  23. 53olds
    53olds
    Your an inspiration my friend!
  24. brady1929
    brady1929
    Nice Effie.
  25. Elcohaulic
    Elcohaulic
    Love the Moon discs on old pickups!! You can buy good aluminum wheels and cover them up with the discs. Most seem to like the screw on version.
    I love the simplicity of these old cars and trucks. I also love the sound of a straight six with three on the tree with a regular muffler.. .
  26. Not too far. Set the deal up and I'll pick them up for you. Tell the guy where I live and maybe we can meet somewhere. Are you coming to GNRS?
    scott27, chryslerfan55, Stogy and 2 others like this.
  27. flyin-t
    flyin-t
    It was a thing back when I got my first '56 in '72. My dad had all the same items chromed on his first 2 '56s in the 60s-early 70s. My old girlfriend swore I used the chromed glovebox door to look up her dress.....but she always next to me in the middle?
  28. NashRodMan
    NashRodMan
    Saaweeet! This is gonna be nice....like all your others builds.
  29. loudbang
    Along for the ride. :)
  30. Chris
    Chris
    I am going to buy a bed wood kit, I need the wood, strips and all hardware. They range from 450-550.00 depending if I want stainless or plain strips. Leaning towards stainless beings it's not much more. The bed does need some rust repair on the very bottom in some places before I can do any wood stuff.
