Technical Model A gas gauge removal, any advice??
Discussion in 'The Hokey Ass Message Board' started by VinnieCap, Jan 7, 2019.
  1. VinnieCap
    VinnieCap
    Hello,
    So I want to replace the bad float in my '28 Model A. I've tried the gas gauge wrench, which is not the greatest quality, but seems to me the one everyone sells. I have also tried a pretty large adjustable wrench.
    Not sure how it was put on during the restoration, but it is SUPER tight. It won't even budge, both wrenches just seem to eventually slip off.
    Any advice or help is greatly appreciated!
    Thanks
    Vinnie
  2. mike657894
    mike657894
    i used a pipe wrench with tshirt around it . if that doesnt work and your willing to buy a new nut you could use a chisel and punch.
  3. J. Corrigan
    J. Corrigan
    I just recently had the same problem on my car too. Because the repop wrench is made for the repop gauge bezel it doesn't work well on an original bezel. Try using a pair of channel locks.
  4. denis4x4
    denis4x4
    from Colorado
    Try the wrenches from Bert’s Model. Cheaper than screwing up an original bezel with a pipe wrench, channel locks or vise-grips. Phone 800-321-1931
    stillrunners, woody45 and 1oldtimer like this.
  5. Get the steel tools not the aluminum or pot metal one.
    stillrunners likes this.
  6. woody45
    woody45
    X2 denis4x4. Bert's wrenches worked on my gas gauge that hadn't been touched in at least 50 years.
    3340 likes this.
  7. goldmountain
    goldmountain
    Don't get out the torch.
    warhorseracing, Truck64, oj and 2 others like this.
  8. VinnieCap
    VinnieCap
    lol... I figured heat won't work as gas tank is still on car and half full.
  9. stillrunners
    stillrunners
    from dallas
    yep....them babies been in there for years....not giving up easy.....what was said go with the steel.........
  10. VinnieCap
    VinnieCap
    Ordered the wrench from Bert's last night... the better steel one. Hopefully that will work. Just have to wait for it to arrive.
  11. tb33anda3rd
    tb33anda3rd
    looks dry, a little penetrant will help while you wait for the wrench.
    Redrodguy likes this.
  12. Kiwi 4d
    Kiwi 4d
    Berts wrenches work well for just a few bucks. Though you will probably only use them once or twice.
  13. Redrodguy
    Redrodguy
    I agree - equal parts of acetone and transmission fluid works wonders on stubborn (rusty) nuts/bolts.
  14. thirtytwo
    thirtytwo
  15. VinnieCap
    VinnieCap
    Thanks all... used the Bert's higher quality tool and it came out easily. I now have a working gas gauge.
    warhorseracing, OFT and egads like this.
