Technical Making a 31 ford deck lid
Discussion in 'Traditional Hot Rods' started by ventura, Jan 9, 2019.
  1. ventura
    ventura
    from central NY
    3/4 in. square tubing. Will post more 20190103_133447.jpg
    Doug B, 48fordnut, chev34ute and 2 others like this.
  2. nice work so far, should save some $$$$ are you going to have a crown to it?
  3. ventura
    ventura
    from central NY
    Yes. My oldest son is building a 30 and has a mint lid, which I used for contour guide.
    Doug B, lothiandon1940 and loudbang like this.
  4. chev34ute
    chev34ute
    image.jpg I am rebuilding a 29 Cabriolet and I am making my own, I will be following this.
    loudbang and 48fordnut like this.
  5. Good question, let's say you don't have a English wheel, is there a way to get some crown?
  6. you could find a piece from a donor car with the correct shape
    loudbang and 46international like this.
  7. great idea
  8. Bandit Billy
    Bandit Billy
    loudbang and kidcampbell71 like this.
  9. pitman
    pitman
    Draw a grid on the new skin.
    Roll it to fit the edge curves.
    Then 'stretch' it carefully
    via hammer and dolly/backer.
    HAMB has a thread on this method,
    Lots of region-based taps create the crown.
    loudbang and Shadow Creek like this.
  10. sloppy jalopies
    sloppy jalopies
    repop Brookville decklid skins are under $200.00 …. probably a second ! … mine was... DSCN3305.JPG
  11. chev34ute
    chev34ute
    If you can’t afford a repro decklid, another way would be to use the roof skin from a large car or station wagon. Before I got my English Wheel, this was what I used. I may even end up going back to doing this for my own decklid because my efforts so far to shape one up are not yielding results.
  12. I have an old bowling ball I use to hammer countours with
    Use it as a dolly
  13. mr.chevrolet
    mr.chevrolet
    my 31 chrysler coupe came with no deck lid. i saved a chunk of a 39 chevy sedan roof to cut and GLUE to a frame I am slowly building
    loudbang and lothiandon1940 like this.
  14. X-cpe
    X-cpe
    When I built mine I made the frame out of sheet metal U channels and curved them with a shrinker/ stretcher, then welded a lip on the outside edge to fasten the skin on. For the skin I made a template of the crown and went to the junk yard and found a roof section with the right crown. At the shop I trimmed it to size plus 3/4" on each side. Then I folded the extra 3/4" 90*. A couple of light pops with the shrinker/stretcher on the top and bottom edges put the crown back in. After that it was a whole lot of witness marks and shrinking to get the side curves correct and even. The final step was hammering it over the lips on the frame and tacking it, just like doing a door skin.
    I bought my shrinker/stretcher for this project because it was the same price as a deck lid.
    loudbang, brEad and RMONTY like this.
  15. Doug B
    Doug B
    Following. Lot of similarities between your car and the red coupe!
