Projects Bagged 55 Buick build
Discussion in 'The Hokey Ass Message Board' started by EVL401, Feb 6, 2015.
  1. mgtstumpy
    mgtstumpy
    Getting there, I hope you kept the old motor as someone might need a baby nailhead for their project.
  2. EVL401
    EVL401
    The rebuilt 401 in place. Everything brand spankin!!
  3. looking fantastic, great to see!!
    EVL401 likes this.
  4. EVL401
    EVL401
    How it sits now. Pretty happy with how it’s turning out!! Boot floor, wiring, Fuel & brake plumbing, shifter install & dynamat etc up next [emoji869]
  5. EVL401
    EVL401
    Some new shoes fitted on the old girl yesterday
  6. Top stuff, looking great.
    Did you get that steering arm topic addressed?
  7. EVL401
    EVL401
    Yeah mate just gave em a little tweak [emoji106] not running drop spindles now either
    Drewfus likes this.
  8. farmer12
    farmer12
    Good to see you're back at it! (talk to me about a long gap between posts ;)) Great build so far!
    EVL401 likes this.
  9. EVL401
    EVL401
    More Buick spam!! Apologies but I’m just loving the new tyres. Almost looks like a complete car again!
  10. bobss396
    bobss396
    That is a great looking Buick, you have done well.
    EVL401 likes this.
  11. Baumi
    Baumi
    Great car and a great build! Very well done!
    I just noticed you decided to skip the rubber motor mounts, and welded tabs to the crossmember. Won‘t that transfer quite some vibrations and noises into the rest of the car? I know nailheads usually run pretty smooth so maybe it‘s most likely no problem . I just wondered what was the reason for skipping them...
    EVL401 likes this.
  12. Baumi
    Baumi
    That stance is killer btw
    EVL401 likes this.
  13. EVL401
    EVL401
    Sorry mate I’ll post some pics today. There’s some rubber mounts in there!! I made engine mounts, gearbox mount & 4 link all share the same bush [emoji106]
  14. Baumi
    Baumi
    Ahh, Isee, ok the rubber bushing sits inside... ok , I was looking for the big factory chunck of rubber. Thanks for answering!
    Now go get her on the road, hahaha
    EVL401 likes this.
  15. 31hotrodguy
    31hotrodguy
    I just came across this build! I love what you are doing with the car. We have a 57 Super that we have hopes of building someday. Your fabrication skills are far above mine at the current but your build will be very helpful for the future. A big thank you from Bakersfield California!!! I’m officially subscribed! [​IMG]
    EVL401 likes this.
  16. EVL401
    EVL401
    Nice one mate!! Does it have the factory 364 in place?
    31hotrodguy likes this.
  17. 31hotrodguy
    31hotrodguy
    Thank you. They are not as popular as other cars but I think they are a great example of GM styling of that era for sure! It has the 364 in the engine bay and it came with a 425 in the trunk (one of the reasons I got it) [emoji3]
    chryslerfan55 and EVL401 like this.
  18. rabounce
    rabounce
    Awesome updates, after doing a bunch more research I still like your rear notch the best as well as how you did your front notch. Did you keep the uprights, I know you said you ditched the dropped spindles ?
    ///Relaxed Atmosphere
  19. EVL401
    EVL401
    Thanks for the kind words!! Kept the stock stubs etc [emoji106] Just fitted new kingpins & all new bushes throughout whole front end.
    31hotrodguy and Drewfus like this.
  20. EVL401
    EVL401
    Bit of an update!!
    Car went on the dyno 2 weeks ago to get properly broken in & tuned by the guy who built the engine. Going like a beauty!!
    However, there was a problem with the car getting hot after 30-40mins of driving @ 100kph/60mph on the dyno.
    New water pump wasn’t turning water hard enough!! Pulled the water pump out & checked clearance between impeller to back of timing case - ok.
    Pulled new radiator & electric fan out & took it back to my mate who built it & mounted the fan. Got them both double checked - ok.
    Hmmmm what to do? Then mate says check the crank pulley to water pump pulley ratios. They were almost the same size!! (6”) He recommended I get a smaller water pump pulley made - should be Atleast 10% smaller for Australian climate.
    I contacted another mate who has a few nailheads & asked what size his water pump pulleys are? All were 4.5” !!
    No f*ckin way!!
    Note; There’s 2 different sized water pump pulleys for 401 nailheads!! Got his one copied & I’m going to bolt it up tomorrow. Hopefully on test run it will work ok. Wish me luck!!
    31hotrodguy and 54EARL like this.
  21. Your ride looks pretty sweet...I've got a 55 Roadmaster that I'll get around to one day and will be going for the same look.
    31hotrodguy and EVL401 like this.
  22. EVL401
    EVL401
    So the car is finally on the road & we just drove it interstate to Sydney for the Hotrod & Custom show. Trouble free trip too which was surprising!! More pics to follow
  23. EVL401
    EVL401
  24. EVL401
    EVL401
    [​IMG][​IMG]
  25. EVL401
    EVL401
    Only got the white tuck n roll trim in it the night before we left.....
    [​IMG][​IMG]
  26. EVL401
    EVL401
    I’ve also always wanted to do something a bit whacky with the car so I covered the tailshaft in flake & candy & built a clear acrylic cover over the top for p***engers viewing pleasure!! Happy with how it came out [emoji106]
    [​IMG][​IMG]
  27. EVL401
    EVL401
    I was also even more stoked after my good mate Smith Concepts striped the bonnet at the show. Then even more blown away when Shige of Mooneyes signed the dash!! What a top weekend
    [​IMG][​IMG][​IMG][​IMG]
  28. 31hotrodguy
    31hotrodguy
    Awesome car friend! A big thumbs up from bakersfield California! Thank you for sharing your pics
    EVL401 likes this.
  29. dans chevy
    dans chevy
    from Canada
    Sweet ride man. I'm in the process of replacing the floor pans in my 55 Buick special, your build has me inspired to bag my buick. In regards to bagging it. What size front cups/ spacer tubes did you use?
    EVL401 and chryslerfan55 like this.
