Projects Assembling Brookville Roadster/ 40s style Build Thread
Discussion in 'Traditional Hot Rods' started by Nick Agius, Mar 4, 2018.
  1. Nick Agius
    Nick Agius
    It’s a 1970, pretty funky year.
  2. The37Kid
    The37Kid
    That under the door trim piece is one major pain to get in place, be sure it is ok before paint time. Bob
    48fordnut and loudbang like this.
  3. 48fordnut
    48fordnut
    Thanks for all the info in this . Just finished reading and saving pics.
    Oh boy this is going to be a trial.
    jim
  4. Nick Agius
    Nick Agius
    Glad it’s been of some help!
    Best of luck!
    Stogy and loudbang like this.
  5. Nick Agius
    Nick Agius
    Well,
    It’s been a few months since I last posted on here. Progress has been slow, but it would seem as if we are nearing the end on trying to make this all fit..
    Honestly, if I had the choice again I would recommend buying a pre built body from brookville or if your in the us have someone like flop ***emble for you..
    It hasn’t been easy.
    Here’s where it’s at, quarters are pinned, floors are spot welded. Some extra bracing to compensate where the frame step through the subrails has been installed & a seat frame brace has been done,Doors are opening & closing nicely now and a little cowl tank brace has been installed.
    Here’s some pics, really looking forward to having this thing painted and home for final ***embly [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Stogy, brEad, kidcampbell71 and 7 others like this.
  6. sloppy jalopies
    sloppy jalopies
    Good stuff... good tips... keep 'em coming...
    The second pic above shows the flange you left when you cut out the tank...
    IMO... drill 1/8" holes every 8", you can anchor your wiring harness to them...
    they may help support a heater, the back side of a glovebox, mount a dome light...etc.
  7. 48fordnut
    48fordnut
    These pics help.
    I copied Missiesdad1 on his cowl braces. Plan on using the wall of the tank for mounting places like the wire panel.
    Thanks,
    jim
  8. 1-SHOT
    1-SHOT
    from Denton
    IMG_0996.JPG IMG_1575.JPG I have been following and see the skills you have developed during the process, this is how we learn to fix **** that others can't. I have a 29 on 32 rails now, but I have had several before this and have a 29 tub, I have traded a few things with Missiesdady1 he lives about 40 miles south of me . Attached is a pic of my tub and roadster both on 32 frames. Keep up the good work. Frank
  9. Nick Agius
    Nick Agius
    Yep! That’s the idea.
    Fuse panel will be mounted behind there, I also plan on putting a full stereo in this car so speakers under the cowl panel also..
    I’ve also heard ( may have even been posted in this thread) people welding washers on there end to route wiring and easily hang stuff from
    Hopefully not to long before all the fun stuff begins
    Stogy, loudbang and 48fordnut like this.
  10. nailhead terry
    nailhead terry
    I have followed yours heres mine Brookville doors parts of 3 bodies IMG_E2795.JPG
  11. 48fordnut
    48fordnut
    Looks really nice. Doors are hard to find.
    jim
  12. Nick Agius
    Nick Agius
  13. Nick Agius
    Nick Agius
    Well a little more progress, I spent my Saturday with my panel beater friend and we got the majority of the panel work required finished on the roadster, over the next few weeks it’ll be prepped for paint and hopefully have it back home mid February.
    Managed to finish up a lot of welds, weld up a lot of holes, fill the gap on the rear quarters where the doors were supposed to sit into originally, finish that frame right up and get the cowl tank shaved.
    I’m getting really excited to have it home
    Here’s some photos of the weekends progress
  14. 48fordnut
    48fordnut
    Your pics are really inspiring me.
    Nick Agius and loudbang like this.
  15. p__moore
    p__moore
    Good job man! Exciting times looking like a hotrod now.
  16. Bruce Lancaster
    Bruce Lancaster
    Fantastic thread, and the several dimensioned charts are priceless!
    I noticed this in one post above: "Can anyone tell me where these four pieces need to go?"
    Well...beware of jokesters and sadists working for brookville! My wife bought me a factory ***embled '32 body from a fleamarket from a guy who wanted to start over with a kit to make it easier for some customizing. He was a very experienced restorer/builder who ran a successful restoration shop.
    About a year later he appeared at my house clutching several little triangular braces and asked to look over the complete body. We crawled all over it inside and out, then rolled it over on its side and looked again. No sign of anything like them, and no vacant corners where they might fit. None in the real henry car either.
    He installed them in the trash can and left. There were 4 pieces that looked like two sets...I think they tossed some random bits into his box just because he had ***ured them that he was an expert who would have no problem...
  17. Nick Agius
    Nick Agius
    Thanks man! On the home stretch now, sort of....
    brEad and loudbang like this.
  18. Nick Agius
    Nick Agius
    Little bit of fill work, recessed license plate to come then it’ll be ready for paint [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  19. 48fordnut
    48fordnut
    It really is coming together. Congratulations.
    jim
  20. 48fordnut
    48fordnut
    At the b pillar there is a bracket that is welded to the pillar. Could you sand a pic of that? I also need the pic of where the trunk hinge is.
    Thanks,
    jim
  21. 42˚18'N 83˚09'W
    42˚18'N 83˚09'W
    Congratulations on a job well done Nick. The "Finish Line" is in sight. This will all become a distant memory when you take your first blast down the road with a grin on your face so big it hurts. Glad I could be some help during the "Dark Days". PM me and I'll give you the names of a couple of hot rod friends in Brisbane you may be able to hook up with. Great folks.
    Later,
  22. oldbanger71
    oldbanger71
    nice progress, i will follow your thread.
    48fordnut likes this.
  23. Nick Agius
    Nick Agius
    Car is now primed & recessed licence plate just about done!! [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  24. Nick Agius
    Nick Agius
  25. Nick Agius
    Nick Agius
    Been a minute. But finally looking like something, makes me so happy to have it sitting like this.
    Engine & diff rebuild still to come,
    Here’s some pics [​IMG][​IMG]
  26. 1-SHOT
    1-SHOT
    from Denton
    Nick, you have came along way, your A is looking really good. You have increased your skill level a lot, you have something you can be proud of and best of all you can say I built it with the help of a few friends. The cowl brace that you built will keep your cowl in alignment and your doors fitting good, because when you cut the tank out the cowl it looses all it's strength. I know Missiedaddy and he lives about 40 miles from me and he is a great person
    Beside saving on the freight you earned a (I Can Do It ) at***ude. That will get you further in life than anything else.
    Nick you did it. I can't wait to see pictures of you driving it.
    loudbang, brEad and 48fordnut like this.
  27. 48fordnut
    48fordnut
    Nick ,between you, Missydad, and several others I hope to have my car in a box close in 6 mos. B'ville 1/4s and doors. I have a good cowl.
  28. A Boner
    A Boner
    Looking great!
    loudbang and Nick Agius like this.
  29. 1-SHOT
    1-SHOT
    from Denton
    Nick Is that a David Mann poster on the wall ?
  30. Nick Agius
    Nick Agius
    Thank you, but I mustn’t take the credit. I’m lucky to be surrounded by some truely talented people without them none of this could happen. Bartering and making deals to get things done always helps!
