Projects The Brooks Special - louisb’s 29 lakes roadster build
Discussion in 'Traditional Hot Rods' started by louisb, May 11, 2018.
  1. louisb
    louisb
    @1-SHOT I cut it per the recommendation in the Bishop/Tardel book. I actually bolted it on to the new radiator last night but don't have a pic. Like your hood. You make it?
    --louis
  2. 1-SHOT
    1-SHOT
    from Denton
    IMG_1242.JPG IMG_1256.JPG IMG_1247.JPG Yes and have changed the look, changed the windshield and added a couple of louvers
    BigO, 54reno, dlw1932 and 1 other person like this.
  3. louisb
    louisb
    Nice! I really like the split windshield. I just picked up a set of folding posts for mine. I need to find a good tutorial on making a hood for mine. Who did your louvers?
    --louis
    29AVEE8 likes this.
  4. 1-SHOT
    1-SHOT
    from Denton
    I built my own louvers machine with the parts and plans from Mittler Bros. And then louvered everything in sight. The layout time takes longer than punching it.. I have the flat and domed dies in 3 and 4 inch. I built my own hood rolled it around a acetylene bottle.
    I believe Brookville Roadsters have hoods give them a call (937) 833-4605 and see if they can help.
    louisb likes this.
  5. 1-SHOT
    1-SHOT
    from Denton
    I bought my windshield frame from Sellers years ago and I think OBrian now has the molds. Google Duvall windshield on 29 and you will get a idea how much work it is to put one on and make the dash look right.
    louisb likes this.
  6. 1-SHOT
    1-SHOT
    from Denton
    When you lean the windshield back it does not line up with the dash rail. It touches in the middle and leaves gaps at either end and you may not be happy with that, looks good buts let's a lot of air in while driving.
    If you search the HAMB http://www.jalopyjournal.com/forum/threads/the-arin-cee-roadster.1025634/ you will see what Eric went thru on his build
    louisb likes this.
  7. deluxester
    deluxester
    Nice work in a short time. Can’t wait to see it done. I dig the rear bung/shock mounts on the differential!
    louisb likes this.
  8. 1-SHOT
    1-SHOT
    from Denton
    Over the years I seen a lot of radius arm ends used for shock mounts.
    When these cars were built we used what ever we had at hand, there was no
    1-(800)-HOT-RODS
    deluxester likes this.
  9. louisb
    louisb
    I got the idea from the Bishop/Tardel book.
    ---louis
  10. oldbanger71
    oldbanger71
    Cool build well done, where did you buy the 32 repro dash ?
  11. louisb
    louisb
    Spent cool grey fall day in the garage working on the roadster. goal was to get the radiator, grill, headlights and spreader bar done.
    Started off doing some mods to the Brassworks radiator to get it ready for mounting. The radiator is a stock style '32 that has been chopped 2". Had to shorten a set of '32 radiator rods to fit.
    IMG_20181209_122804.jpg IMG_20181209_124709.jpg IMG_20181209_125806.jpg IMG_20181209_125823.jpg
    Next up was rebuilding a set of Guide 903-J headlights. I like these better than the larger Guides on a roadster. Replaced everything but the cup with new gear from OTBGear.
    Last project for the day was to make a new spreader bar from a Model A brake cross bar and some spreader bar spacers. Ran out of time before I could finish it but at least got it mocked up and spot welded into place.
    That's it for this weekend.
    --louis
    Stogy, sloppy jalopies, brEad and 6 others like this.
  12. Aaron D.
    Aaron D.
    Looking good Lois, I'm liking the way the front end is coming together. Nice and traditional.
    What's the plan for front blinkers?
    Aaron
    louisb likes this.
  13. louisb
    louisb
    Good question. Not sure yet.
    --louis
  14. oldbanger71
    oldbanger71
    how about the Kellman LED indicators, they are so tiny ( like a small fingernail ) that you can build them in your headlight cups, if you use the LED AND NORMAL indicator relay, you can use the Kellerman turnsignal together with your non-LED taillights. You get them with amber, clear or black lense. Thats what i'm going to do this winter, when i change my headlights. Just my cents... kellerman turn lights.jpg
    Outback and louisb like this.
  15. louisb
    louisb
    Pretty nifty idea.
    --louis
  16. sloppy jalopies
    sloppy jalopies
    Can't speak for roadsters but ; To see the difference between straight up closed car windshields and tilted back check out a stock '30 filler panel [ between w/s frame and gastank] with a slant windshield unit...
    The offsets [grooves] tell how much change...
    my $0.02 .
    Outback likes this.
  17. louisb
    louisb
    Early Christmas present to myself. Got these from John Williamson here on the HAMB. 2" chopped folding posts. I have been hemming and hawing on these for almost a year and finally decided I really wanted them. While not a bolt on, notice there are no holes, the quality is good.
    I am sending my windshield frame out this weekend to get glass cut and then I will install it all.
    Thanks,
    --louis
    Outback, Stogy, Tim_with_a_T and 3 others like this.
  18. Aaron D.
    Aaron D.
    Those look really nice!
    louisb likes this.
  19. louisb
    louisb
    Spent some time this weekend finishing up the spreader bar and installing the folding windshield posts.
    For the windshield posts I had to drill the holes and do some reshaping to the sheet metal where they mount. Some minor adjustments with a body hammer and they slipped right on.
    Unfortunately, I managed to scrape up the paint on the windshield so I need to redo it before sending it off to have glass cut. Two steps forward, one step back. At least the front of the car is now finished except for brakes and paint.
    --louis
  20. Aaron D.
    Aaron D.
    Looks good with the windshield laid back.
    louisb likes this.
  21. louisb
    louisb
    Stripped down a second '32 column drop after my first one broke. This one came apart pretty easy with a little heat.
    First step is to get the column pinch bolt out by building it up some with weld and then welding on a nut. Just don't weld the bolt to the body.
    There is a small pin in the back that has to come out. I usually end up breaking it so be careful. Then a little heat on the body and you can drive out the shaft from the top.
    There is a little pin that needs to be drilled out that holds the lock cylinder in place. If you plan to reuse the cylinder be sure to stop as soon as you see brass shavings. Then tap out the lock cylinder with a small punch.
    The pin was already drilled out on mine and you can see they went to deep. Not a problem since I was going to replace it anyway.
    I have yet to be able to take off the tag without destroying it. The brass tacs that hold it in are easy to break too. I was able to gently pry them out.
    Here it is mocked up in the car.
    The shaft jacket is out of an F3 which I shortened to fit the '32 shaft. I need to modify it to work with the column lock and then reassemble the drop with all new parts.
    Thanks,
    --louis
    oldbanger71, brEad, bct and 3 others like this.
  22. alchemy
    alchemy
    Cool! I've never messed with restoring a 32 column drop, but thanks for the instructions in case I do it some day. Hopefully the angle is nice and you fit well.
    Stogy, bct, louisb and 1 other person like this.
  23. louisb
    louisb
    kidcampbell71 and Stogy like this.
  24. louisb
    louisb
    Put in the rear floors today. I just reused the sheet metal that came with the Brookville body and made it fit the ‘32 frame. 3rd shot is the T gas tank where I think it is going to go. Though I need to fit a battery in there somewhere too.
    03D80319-9F6F-4A38-8099-B41AD3EF63F8.jpeg B0EE7BCE-0E04-45EA-B93D-9E9DC4838B3C.jpeg 1C22ACFB-AD8B-42D0-96D5-082504726C8D.jpeg
    I am an ass man. At least people are always telling me “You’re an ass, man.” So it must be true. :)
    Thanks,
    —louis
    Outback, slv63, Tim_with_a_T and 6 others like this.
  25. louisb
    louisb
    Been making slow but steady progress on the roadster. It is getting closer to being done but still so many little things to finish. I was telling a friend sometimes it feels like death by a 1000 little things.
    Got the seat mounted and then took it to the upholster. Hopefully I will have it back in a couple of weeks. Also put in some seat belts. Not era correct but I think they look okay and I can put them behind the seat when I don't want them to be seen.
    IMG_20190101_132217.jpg IMG_20190101_144630.jpg IMG_20190104_182535.jpg IMG_20190104_182550.jpg
    Made a spacer and backing plate for the '32 column drop. The mast jacket is out of an F3 pickup and needed some mods to work with the drop. Finishing up the rebuild of the column drop now and will post some pics when it is done.
    IMG_20190105_132038.jpg IMG_20190105_133151.jpg IMG_20190105_143158.jpg IMG_20190105_143216.jpg IMG_20190105_155451.jpg IMG_20190105_155511.jpg
    I am using an F100 steering box which looks close to a stock '32 box. The down side to this box is the huge pittman arm. Spent some time slimming it down and improving the clearance to the mounting bolts.
    IMG_20190106_124302.jpg IMG_20190106_131442.jpg IMG_20190106_135141.jpg IMG_20190106_135148.jpg
    I have been looking for a battery box to hide a new 12v battery and found this one from an International Harvester farm tractor. I like the looks and may even keep the orange paint.
    Need to get the tank and the battery box permanently mounted but it looks like a nice fit.
    So the plan right now is to try and get it on the road by the end of Spring. To do that I am probably going to end up leaving it in primer for a while. That should give me enough time to work out any issues before TROG in October and let me enjoy driving it this summer. Not sure if I will make it but going to give it that good ol college try.
    Thanks,
    --louis
    Metaltwister, brEad, bct and 2 others like this.
  26. Aaron D.
    Aaron D.
    That's some good progress Louis. I agree with the 1000 little things, just keep knocking them off one at a time; I try not to get overwhelmed with it all. I don't think I could build with a deadline, I'd never make it!
    Aaron
    brEad and louisb like this.
  27. louisb
    louisb
    If I didn’t have a deadline it would never get done. :D
    —louis
    Outback likes this.
  28. louisb
    louisb
    C8B598E6-318E-47F1-B440-474F8C8B8FB9.jpeg BB92D86A-3E9F-4EAA-846D-71B275FDA3B3.jpeg 4044C843-EBFA-4259-960D-F0C75B98397A.jpeg E99FE6DD-B746-482F-96E3-FAC94704639C.jpeg D1CD916E-47EA-44E6-A3C3-16CAEC44CECC.jpeg 16A30175-473C-48D6-9797-7529E39D4D31.jpeg
    Got the gas tank and battery mounted. Also decided to redo my seat mounts with some 1”x2” rectangular tubing. Rolled it outside today to get a good look at her and start laying out a hood.
    Thanks,
    —louis
    Outback, Metaltwister, brEad and 6 others like this.
  29. louisb
    louisb
    Rebuilt column drop mounted.
    --louis
    Outback, lodaddyo, brEad and 2 others like this.
  30. 1-SHOT
    1-SHOT
    from Denton
    Outstanding
    louisb likes this.
